Arborwear
Author Topic: Can wood dry too slowly?  (Read 1944 times)
Offline bkhunter
« on: February 15, 2006, 09:41:12 AM »
I was talking to someone about drying wood too fast and all the problems that creates, when I started to wonder: Is it possible to dry wood too slowly, either in a kiln or air-dried? If it takes longer does that have any negative side effects? Is it different for hardwoods or softwoods? Help me out if you know!
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
Re: Can wood dry too slowly?
« Reply #1 on: February 15, 2006, 09:55:20 AM »
Yes, you can dry to slowly.
You need adiquate air flow to remove the moisture other wise you get mold.
The drying times for wood depend on species, there is a very good publication you can get from the Forestry Products Lab; titled "Drying Hardwood Lumbers" , another one is "Kiln Operators Manual" both offer good ideas on drying lumber.
Hyster H80, Kubota B2710, Conventional Kiln, 2008 Corvette, AV-028 Super, MS361, MS460 Mag
Offline WkndCutter
  • So much wood, So little time.
« Reply #2 on: February 15, 2006, 09:55:48 AM »
Wood is going to dry out as fast as the conditions it is in allow for.  As long as there is good air circulation slow is good but the wood will dry out at a rate depending on the environmental conditions the wood is stored in, how it is stacked/stickered...
Mark has the right idea though about preventing mold.  Both books referenced are good guides also.
Andy
Offline jimF
  • Go for it!
« Reply #3 on: February 15, 2006, 11:10:55 AM »
other reasons to increase drying rate :is discoloration from oxydation reactions (although I prefer this), increased final drying stresses, if you are in the business decreased production and increased inventory costs.
Offline Larry
« Reply #4 on: February 15, 2006, 11:56:39 AM »
Mold, although undesirable isn't much of a defect in hardwoods as it rarely effects the finished product.
Stain is a defect that ruins hardwoods unless ya plan on painting them.  General rule is light woods such as maple, ash, basswood, and hackberry need to be dried fast to avoid stain and keep the white.
I've pretty much figured out every way possible to mess up hardwoods.  Ash with reverse sticker stain caused by to slow of drying.  The stain went all the way through the board.  Shown with a good board in the middle.
Larry
Nine out of ten trees recommend wood for your building project.
Offline Charles
« Reply #5 on: February 15, 2006, 10:31:39 PM »
then I have a question of similar nature.
I dry for myself and have a small 300bf kiln that I set dry bulb for 105f. Why can't I dry at 85-90f. Is there a temp to low. I was thinking that because this is a small homemade unit, it would be easier on the equipment if the temp was lower. I have dry/wet bulb, heat control and fan control etc. Not having a problem just thinking maybe "off", temp would be 90f and "on" be 85f. The evaporator temp is 22f less than the ambient at 95f so that's not a problem. Can the temp be to low I know it takes longer to dry but that is not an issue. I guess the question is can you dry lumber to 6% at 90f cause I know you have achieve 30% RH. Can you get this at 90f. Or do you have to achieve a certain temp to get the bound water to move. And I am lucky at 105f. Also I usually dry air dried and am very aware of mold.
thanks
charles
ps larry
Am interested in what is too slow drying to get the sticker stain on the ash
Offline jimF
  • Go for it!
« Reply #6 on: February 16, 2006, 11:01:33 AM »
Charles, assuming your lumber is exposed to the ambient air vapor pressure, you would need to have a dew point temperature below 50F to get about 4% EMC which is what you would need to dry to 6% MC.  Lower temperatures help reduce oxidative stains but if you dry too slow because of low temperature and not low enough EMC the increased resident time increases oxidative stains.   I know this is all qualitative but I know of no research that has quantified all these variables to various degrees of stain.  Bound water can be removed at low temperatures if the EMC is low.
Offline Charles
« Reply #7 on: February 18, 2006, 10:37:27 PM »
Thanks Jim
I"m going to stick with 105f I've never had a problem and don't need one. Never thought about the low temp and stains.
charles
Wood splitter hydraulic ram moving erratically/slowly
Started by roadrunner36 on Firewood and Wood Heating
Last post September 20, 2014, 08:45:18 AM
by John Mc
Progress. Slowly, but surely.
Started by tcsmpsi on Sawmills and Milling
Last post August 24, 2006, 12:15:01 PM
by solodan
Coming Along Slowly but Surely
Started by Glenn1 on Drying and Processing
Last post July 06, 2015, 09:09:07 PM
by Tree Dan
Starting a mill build... slowly
Started by wooddust on Sawmills and Milling
Last post October 19, 2017, 06:56:05 PM
by wooddust
