TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Synthetic winch line  (Read 3915 times)
Offline sprucebunny
  • Gender: Female
« on: March 14, 2006, 04:16:47 PM »
I bought some AmSteel Blue to replace my wire winch line. Here is an article about it's use and successfulness in the logging industry. The pdf was too big  :(
long link
Offline Woodhog
Re: Synthetic winch line
« Reply #1 on: March 14, 2006, 04:23:53 PM »
Thanks for the interesting link...
I noted the 1/9 as heavy comment, this is good, I get so tired dragging the other cable ..
Also I wonder how it behaves when it breaks under load compared to wire line...
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #2 on: March 14, 2006, 04:32:29 PM »
  I would like to see how it would react in the winch after having a load pulled with it , Sent it my way and will do the proper testing for you and will also provide a full report on its reactions to winching in different conditions .  ;D
   Marcel
Offline sprucebunny
  • Gender: Female
« Reply #3 on: March 14, 2006, 04:38:03 PM »
It doesn't whip. Just drops to the ground if it breaks.
Marcel, you will have to get your own piece ;D I would imagine if it is wound in with a load on it, it will be fine. It does not seem very 'fluffy' . It feels kind of hard .
Google AmSteel Blue. There are lots of testamonials from the 4x4 group. It is also used on tug boats.
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
« Reply #4 on: March 14, 2006, 05:56:43 PM »
How does the price compare?
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline sprucebunny
  • Gender: Female
« Reply #5 on: March 14, 2006, 06:43:09 PM »
It was 20% more $ than wire for me,
Here are some prices. They are not the cheapest I've found but have most of the sizes.
Offline sawguy21
« Reply #6 on: March 15, 2006, 10:06:23 AM »
We used a similar product called Spectra12 for helicopter longlines and once the crews got used to the idea they thought it was great. It was a fraction of the weight of steel which meant more payload or fuel and was a lot easier to handle. We developed a special technique for attaching the extension cord to operate the electric hook release as the stuff really stretches. We did find the material took a beating at the lower thimble from being dragged so we would cut it back and resplice until the line was too short to be useful.
Offline beenthere
« Reply #7 on: March 15, 2006, 10:53:48 AM »
Seems if it stretches, then it is building up energy and will 'unstretch' quickly if it fails. This could cause some real damage. I was under the impression the rope SB is talking about, does not stretch much at all.
I've been around a rope that failed after it was stretched and it wasn't pretty.
But am still interested in getting such a rope (non energy storing kind) for a capstan winch. I'd like it for short pulls, removing hung-up trees, and occasional pulls where the tractor isn't the handiest.
Offline logwalker
  • Got Logs??
« Reply #8 on: March 15, 2006, 11:54:26 AM »
The line I have used does not have any apreciable stretch. I did keep a couple pieces under strain for 34 hours once and after I removed the strain it stood out like a steel rod. Very strange to see that. Very slick exterior. May have some effect on a capstan. Easiest stuff there is to splice. I like it. LW
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #9 on: March 15, 2006, 12:49:39 PM »
It does stretch some as does steel but the low weight means much less energy in the line if it breaks.  Now if a chunk of metal rigging at the end breaks not the rope when it is in a stretched position it will fling the attached remains just like steel rope.
Their are two basic products competing and I have a table on my website.
EDIT: Hmm the code line doesn't seem to work, I'll try to edit it into the forum format.
Bah nevermind here is the link, just scroll down:
http://moose.ca/~slowzuki/slowzuki/body/winch/index.htm
Online barbender
« Reply #10 on: March 22, 2006, 11:48:23 PM »
 I was looking at the bailey's catalog, premium swaged wire rope 3/4"- $2.09/ft,  AmSteel Blue 3/4"- $5.99/ft. So it looks quite a bit more expensive, the breaking strengths were similar. I'd go for some though, if I knew it would hold up.  That would make a HUGE difference if you're setting chokers all day, being that light.  I'll let you guys be the guinea pigs and figure out if it's durable before I take the plunge though :)
Offline rebocardo
  • Atlanta GA
« Reply #11 on: March 23, 2006, 01:29:00 AM »
I have been thinking about syn line, my thing is how easy is it to do splices and loops?
With cable, it is basically 3 clamps and torque to spec.
Offline sawguy21
« Reply #12 on: March 23, 2006, 09:37:44 AM »
We used a something called a 3-2-1- splice. Don't ask me to describe it, there must be some riggers here. ;D The first splice we used pulled loose.
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #13 on: March 23, 2006, 11:46:39 AM »
BTW for guys considering this for their skidders, don't bother if you have rocky ground.  It gets abraded quickly on rocks.  Off-roaders doing self recovery don't slide the cable along rocks, they only reel it up as they drag themselves to safety.  Even so it is sold with a moveable rock guard/sheath the protect it.
Offline logwalker
  • Got Logs??
« Reply #14 on: March 26, 2006, 11:13:20 PM »
The line I use is a very simple 1 or 2 minute splice to a thimble. Easiest I have seen of any line. Lw
winch line
Started by Button on Forestry and Logging
Last post January 16, 2006, 09:31:50 PM
by twistedtree
question
winch line
Started by br389 on Forestry and Logging
Last post July 14, 2013, 10:32:04 AM
by thenorthman
Winch line twist
Started by ga jones on Forestry and Logging
Last post October 19, 2015, 08:55:14 AM
by teakwood
Replacing winch line
Started by Woodboogah on Forestry and Logging
Last post September 22, 2013, 08:19:05 PM
by Woodboogah
