Arborwear
Author Topic: Converting furnace from propane to natural gas....  (Read 19674 times)
Offline PawNature
  • ADHDDDDDDDDD DA DDDD
« on: April 04, 2006, 12:45:37 PM »
I have a propane furnace and was wondering if anyone here knows if it can be converted to Naturas Gas.
GOVERMENT HAS WAY TO MUCH CONTROL OVER OUR LIVES!!!!
Offline Mr Mom
  • still alive!!!!
Re: Converting furnace from propane to natural gas....
« Reply #1 on: April 04, 2006, 12:54:04 PM »
     you should be able to.
     All you need is the orficie (spelling??) for natural gas that if your furnace has them.
     Call a furnace company they should be able to tell you.
     I changed mine from natural gas to propane.
     Thanks Mr Mom
Offline TexasTimbers
    • Dovetail Spline Jig
« Reply #2 on: April 04, 2006, 01:02:59 PM »
All you need to do generally speaking is to do like Mr. Mom said and swap the propane orifices (smaller holes tha the NG) for the natural gas orifices. You'll need to swap both the burner jets and the pilot orifice as well, unless it's an electronic ignition. You also may have to change out the diaphram spring in the valve which will give the proper regulator pressure.
Go to your local HVAC guy and give him your model/serial number and brand and he can give you the kit or order it.
Going from gas to propane is not a DIY if you ain't sure you know what your doing, neither is LP to NG but you're less likely to blow yourelf up.  ;D
Offline highpockets
  • I'm old
    • our page
« Reply #3 on: April 04, 2006, 10:14:51 PM »
In some models (2 each York Units I had) you also had to change the actual burner to.
Louisiana Country boy
homemade mill, 20 h.p. Honda & 4 h.p. for hydraulics.  8 hydraulic circuits, loads, clamps, rotates, etc.
Offline JimBuis
« Reply #4 on: April 04, 2006, 10:29:55 PM »
Reemphasizing what has already been said, unless you have had good training and/or experience with gas, do not attempt this.  With that disclaimer, a natural gas unit or propane unit can easily be converted back and forth.  It's all a function of gas and air ratio.  Therefore, the orifice size [controls the amount of gas] and the amount of air are the keys to the process.
Look around inside the furnace.  Sometimes they come with a conversion kit and the installer tapes it up inside one of the covers.
Just an idea.
Jim
Jim Buis                             Peterson 10" WPF swingmill
Offline PawNature
« Reply #5 on: April 09, 2006, 10:28:14 PM »
Thanks Guys for the imput.
Offline maple flats
  • Life is what you make it!
« Reply #6 on: April 12, 2006, 06:38:46 PM »
On an older cook stove to convert all that was needed was to drill out the orifice to the right size BUT I'll bet a furnace has a lot more to consider and to make sure everything is matched correctly to safely ignite every time and to burn properly and to give the safe BTU level it was designed for. I would think this be better done by a trained technition, not a DIY type project. You must have the correct specs and must change everything needed or you could have a bomb.
Offline JimBuis
« Reply #7 on: April 12, 2006, 06:45:20 PM »
Back when I used to be in this sort of business, we often drilled out orifices or silver soldered them shut and redrilled.  However, that was done with gas flow charts for reference, precision bits, and measurement instruments for measuring gas pressure in inches of water column.  Done right, this works as well as any factory kit.  However, without the instruments, charts, and know-how, this is the formula for disaster.
Jim
Offline woodhick
  • I hope it don't clear off cloudy and come a dry drizzle!
« Reply #8 on: April 12, 2006, 10:05:24 PM »
I picked up a warm morning natural gas stove last summer with the intentions of converting it to propane to heat my shop with.  I have called almost every warm morning dealer and lots of HVAC people to get an orfice to change it over.  No I repeat Not one of them would help me out.  They all said that it was impossible to get just an orfice anymore and I had to buy the whole burner assembly which for my stove was between $300 and $400 bucks. :o :o  They all said it was due to liability and the companies would no longer sell  just orfices' anymore.  I was tempted to due the solder and redrill aproach but bought another heater insted and sold the other.  I guess we can thank the lawyers again. :(
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
Offline logwalker
  • Got Logs??
« Reply #9 on: April 13, 2006, 12:45:24 AM »
I have converted two fireplaces to propane from N.G. I could never seem to get the right jets from the dealers so I brazed and drilled. Took a couple trys but came out fine. No soot on the glass in one year. LW
Offline Murf
  • The pitter-patter of little feet..........
« Reply #10 on: April 13, 2006, 02:58:58 PM »
I wouldn't try it in my house, or recomend anyone else do it either for that matter, but I was told that because Propane is hotter than NG, you can just run the propane appliance on NG directly, it just wont put out the rated amount of BTU's.
On a cubic foot basis natural gas has a little less than half the BTU's of propane. Accordingly then a 100k. Propane furnace running on NG would have an output of less than 50k BTU's.
I would want to be sure of things like pilot lights, safety valves, etc., would still work though.
Offline Trax
« Reply #11 on: April 21, 2006, 11:15:05 AM »
If the furnace is not to old there could be a conversion kit available for it. The kits consist of burner orifices and a spring for the pressure regulator, it is very simply to do. The kits are usually under $50 and will have very easy to follow directions. If it is an older unit  it can still be done by resizing the orifices (you will need a wire gauge drill bit set and a sizing chart)  You will also have to change the gas valve to one that is already set for propane,  if it is old enough to have a standing pilot the orifice in the pilot assembly will need to be opened up slightly which most time can be done with a pin.
propane bottle furnace
Started by sawdust on General Board
Last post April 07, 2005, 04:19:32 PM
by jjmk98k
Converting FBM to M3
Started by Woodlotguy on General Board
Last post April 28, 2002, 05:23:39 PM
by Ron Wenrich
Converting
Started by Fla._Deadheader on General Board
Last post October 31, 2006, 11:04:40 AM
by VA-Sawyer
Not converting- But
Started by Frank_Pender on Sawmills and Milling
Last post January 23, 2003, 07:36:43 AM
by Frank_Pender
