Arborwear
Author Topic: Water supply "spring water" to camp  (Read 1314 times)
Offline sbishop
« on: June 02, 2006, 07:38:58 AM »
Hi All,
 I finally dougged my spring out 2 weekends ago. I placed a 45 plastic barrel in the ground. the spring is coming out of hill in 2 places so what I did was place the barrel out 8ft down the hill...sunk it about 2ft in the ground. I install a piece of eavesthroufing from where the 2 springs come together to the barrel...works great i'm catching 100% of the water supply.
Now my question. I would like to install some type of screen on top of the barrell to keep, insects, worms, stuff like that out of the barrel.
Any suggestions on what type of screen? the water will be going through the screen has the piece of eavesthroufing is just sitting on the top of the barrel!
thanks for any suggestions
PS. got 200 feet of pipe ran, going to lay 400ft today...only 400ft more to go!
Sbishop
Offline submarinesailor
  • LT15 and a wife of 45 yrs
Re: Water supply "spring water" to camp
« Reply #1 on: June 02, 2006, 08:19:52 AM »
sbishhop,
A quick search with Google and I found these companies.  I would go with a stainless steel screen at has about 1/32 openings - one of them had a "20 mesh" that meet this requirement.
Bruce/subsailor
http://www.newarkwire.com/wwc.htm
http://www.wovenwire.com/index.html
http://www.bwire.com/
Offline beenthere
« Reply #2 on: June 02, 2006, 09:34:42 AM »
Any pics of that project?   ??? :)
Offline sbishop
« Reply #3 on: June 02, 2006, 09:41:54 AM »
will take some pics this afternoon for sure!
Submarine, you think they would be something else that is easyly available from harware store? what about material for a screen door? you think it would last?
Sbishop
« Reply #4 on: June 02, 2006, 09:53:46 AM »
In all my travels thru many a hardware store, big box and Mom & Pop, I haven't seen any stainless steel wire cloth.  I don't think aluminum or nylon would hold up to the environmental elements.
The best I have found was hardware cloth with 1/4 holes in it, at the blue big box store.  And that was only once.
Bruce
Offline DanG
« Reply #5 on: June 02, 2006, 10:26:04 AM »
I think I'd go with ordinary aluminum screen wire.  It should last a couple of years or more, and would be cheap to replace.
I'd like to see pics, too.  Is this a gravity feed system, or are you using a pump?
Offline GF
« Reply #6 on: June 02, 2006, 02:28:41 PM »
After awhile wont algae build up on the screen and block it if the climate is warm?
Offline Gary_C
  • Sunrise on the Prairie
« Reply #7 on: June 02, 2006, 03:03:07 PM »
Would it be better to cover the entire barrel and inlet to keep debris out rather than try to screen it out after it gets into the system?
No matter what size screen wire you use, the junk will build up and plug up the screen or be totally ineffective. You will need some type of self cleaning screen.
water supply for camp
Started by sbishop on General Board
Last post May 09, 2006, 11:23:54 PM
by toxedo_2000
Thomson "natural" water sealer
Started by Max sawdust on General Board
Last post August 22, 2006, 10:45:52 AM
by Percy
Getting a "rich" Cherry red with water oak
Started by fishfighter on General Woodworking
Last post January 31, 2018, 07:29:03 AM
by PA_Walnut
"Gray Water" Processing and using
Started by fencerowphil (Phil L.) on Alternative methods and solutions
Last post June 25, 2008, 09:58:46 PM
