Arborwear
Author Topic: sawblade modifications-edger/planer  (Read 1004 times)
Offline amberwood
    • www.amberwood.com.au
« on: June 04, 2006, 07:35:50 PM »
Morning all.
I have been trying to work out a design for a edger/jointer similiar to a PH230. It will have a staggered bedplate with cutterhead like a jointer, and a vertical staggered fence with a sawblade midway. Combined with a powerfeed I should end up with a device similar in function to 2 sided planer.
Is only intended to resize/square up timber so a fine finish is not required. All material would then be passed thru the thicknesser to acheive final sizing/finish.
The question is. I only need a a coarse finish and a high tooth count blade(24) will only suck up HP. Has anyone seen a small diameter blade (with standard arbor) with low tooth count such as used in lucas/peterson? Alternatively has anyone modified a standard blade to achieve the same effect?
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
Offline getoverit
  • freeing trees from silence
Re: sawblade modifications-edger/planer
« Reply #1 on: June 04, 2006, 10:28:31 PM »
What you are looking for is a strob blade. Check out THIS LINK for an idea on what is available. They make them as small as 8" and go up from there... teeth from 6 teeth per blade on up also.
Hope this helps !
Ken
Offline amberwood
« Reply #2 on: June 04, 2006, 10:48:03 PM »
thanks..the design continues.
DTR
MS460 Magnum
MS250
DAF CF85-430
Lane moulder, 30in planer, twin blade edger
Started by farmer on Sawmills and Milling
Last post September 15, 2006, 08:15:52 PM
by ddan7
Woodmizer LT40 Super hydraulic 51 hp CAT diesel, Edger, planer, kiln
Started by Jeff on For Sale
Last post November 21, 2008, 04:26:53 AM
by customsawyer
sawblade.com
Started by trapper on General Board
Last post May 24, 2017, 11:17:17 PM
by trapper
What sawblade to use cutting ash
Started by highlandsaw on Sawmills and Milling
Last post February 22, 2016, 02:52:45 PM
by ladylake
