Author Topic: Bearing of a different type.  (Read 43090 times)
Offline crtreedude
  • A proper coffee break...
    • Finca Leola Reforestation
Re: Bearing of a different type.
« Reply #180 on: October 24, 2006, 06:40:52 PM »
Or perhaps the bear was watching over Jeff's shoulder from another window... which would explain why Jeff never saw him in front.  ;)
So, how did I end up here anyway?
Offline johncinquo
  • Oh Boy A place to cut up!
    • My Pictures
« Reply #181 on: October 25, 2006, 11:01:35 AM »
The last 2 years at Elk camp my grand dad was recovering from cancer so he stayed at the camp while we all went out.  He told me at 11:00 to get up, walk around, eat some of my lunch, take a good stretch, walk out as far as I could see from where I had set up to check for an elk hanging out just outside of where I could see.
Both years he shot an elk at camp between 11:15 and 11:30.   :D
To be one, Ask one
Masons and Shriners
Offline Onthesauk
  • Still learning!
« Reply #182 on: November 05, 2006, 05:21:01 PM »
I'm still dealing with a couple of bears around the house.  Finally went down yesterday in the pouring down rain and picked the last of the apples they have been working on.  Today I go down and they have pulled the cap off the pipe that covers my drain field distribution valves.  This thing is two feet in diameter and screwed down, they just flipped it off.  Based on the sign, appears to be one big one, one small one.
They are using trail up the hillside behind the house, accesses thousands of acres of timber.  Beginning to wonder if I shouldn't start packing, I hike up there nearly every day.  Can't tell how far up they travel during the day.
John Deere 3038E
Sukuki LT-F500
Dont attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Offline Ron Scott
« Reply #183 on: December 07, 2006, 07:23:01 PM »
Jeff needs to bear hunt close to home!
One of my clients told me today that a farmer near Big Rapids, MI got this bear last Friday with the combine. He was combining corn in a neighbor's field and fell into a big hole. The combine was stuck, and the hole was about 5 feet deep. He thought that it was a badger hole until a big black paw came out and pretty soon a head appeared.
The bear was trying to dig out from under the wheel but could not get out. They then knew for sure that it was no badger and he wasn't very happy either.
The DNR told them to shoot it. It dressed out at 287 pounds, and was a male.
~Ron
Offline Paul_H
« Reply #184 on: December 07, 2006, 11:45:04 PM »
How's that for bad luck.You're having a well deserved nap and some farmer runs you over but some how you manage to survive.At first you're irritated but then you remember to count your blessings because you survived a combine accident for Pete's sake. whiteflag_smiley
                                           go_away
As you're busy counting and taking stock of damages,the sodbuster brings out a rifle and puts one between your eyes smiley_dizzy
It would be diificult to Bear  :)
eg  tregar  meste  p  Tulla, for  ho  var  krulla  i  ulla.
Offline SwampDonkey
  • Large Tooth
« Reply #185 on: December 08, 2006, 06:56:58 AM »
In October there was a bear den in the middle of our thinning operations. But, he never appeared. It was probably too early, but I would think he would be hanging around close.  :o
Move'n on.
Winch-line Hook, ring type vs. sleeve type
Started by CuddleBugFirewood on Forestry and Logging
Last post March 23, 2013, 12:25:58 PM
by lumberjack48
Bearing went bad!
Started by dovetails on Sawmills and Milling
Last post May 30, 2007, 09:08:43 PM
by thecfarm
bearing preload
Started by 240b on Forestry and Logging
Last post August 17, 2010, 02:02:50 PM
by mad murdock
bearing problems
Started by sabre_tooth on Sawmills and Milling
Last post February 08, 2005, 06:18:21 AM
by Swede
