KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Chains stretching question. Oregon vs. Stihl.  (Read 12430 times)
Offline Steven A.
« on: October 01, 2006, 02:17:12 PM »
I was in talking to a Stihl dealer the other day and a man brought a few stretched chains in to have a link taken out.
The Stihl dealer told me after the customer left, " Its these cheap Oregon chains. I see it all the time. The Stihl chains are prestretched and never have that problem."
True or just the Stihl man promoting his chain? I need to buy a few extras for my new Jonsered and I wondering which to buy.
Offline SawTroll
Re: Chains streching question. Oregon vs. Stihl.
« Reply #1 on: October 01, 2006, 02:38:27 PM »
Mostly BS/Hype, I believe, I have never had a stretching problem with either Stihl or Oregon, but I mostly prefere Stihl for other reasons (better stay-sharpe and lower price, at least at my Stihl dealer).
Information collector.
Offline sawguy21
« Reply #2 on: October 01, 2006, 02:49:03 PM »
I agree with SawTroll. Stihl makes a big deal of their 'prestretched' chain and it is good quality. However, most chain stretch is the result of wear from abrasion and poor lubrication.
Offline fishhuntcutwood
  • I love the smell of two-stroke and wood chips.
« Reply #3 on: October 01, 2006, 05:03:19 PM »
Agreed!
And agreed!
MS 200T
MS 361
044
440 Mag
460 Mag
056 MII
660 Mag
Offline beenthere
« Reply #4 on: October 01, 2006, 05:33:58 PM »
I agree with SawTroll. I don't think chains "stretch" like the name implies. Wrong adjustment when new, and/or unclean bar rails or sprocket when new, and then wear.  My experience is with Stihl (since '75) and never experienced any stretch in a new chain. Have heard about it however. And maybe Stihl does something to avoid the apparent problem.  ::)
Offline Kevin
« Reply #5 on: October 01, 2006, 07:31:17 PM »
Chains stretch with heat, that's why they tell you never to adjust a hot chain.
They should be cooled off by the time you get to the shop though. :D
Offline MDP
  • Logger, and proud of it.
« Reply #6 on: October 01, 2006, 08:59:34 PM »
My personall experience has been that oregon chain stretched 1/3 more than stihl chain, not a huge difference for me, just have had better luck with the stihl chain, it just seems tougher.
Offline Al_Smith
« Reply #7 on: October 01, 2006, 09:20:51 PM »
 Stihl does make good chain,can't argue that.Now weather it's worth about double the price of Oregon from Baileys I'll leave up to the user.
« Reply #8 on: October 02, 2006, 02:35:51 AM »
Hey Al, good to see ya.
MS 200T
MS 361
044
440 Mag
460 Mag
056 MII
660 Mag
Offline RSteiner
  • God is good, all the time.
« Reply #9 on: October 02, 2006, 06:43:16 AM »
Kevin is correct, chains stretch because of heat.
At work we run roller chain, which is very similar to saw chain in a hot environment under vacuum.  You would not believe the change in length after a few cycles.
Saw chain will change in length more or less depending on the amount of heat you subject the chain to.  Trying to make that last cut with a dull chain puts a lot of heat in the chain, enough to take some of the temper out of the cutters.   Once this happens the chain never holds an edge like it did when new.
Randy
Randy
Offline Steven A.
« Reply #10 on: October 02, 2006, 06:58:35 AM »
Thanks for all the good advice guys.
I just looked at Baileys website and I see they have a 16" bar and chain for $16.95.
Carlton Brand. That sounds cheap to me. Is Carlton a lower quality brand?
Offline RSteiner
« Reply #11 on: October 02, 2006, 07:21:01 AM »
Carlton has been around for a long time.
My only experience was over 20 years ago with a length of saw chain, I liked the Oregon chain better.  However, the Oregon chain was a chisel tooth and the Carlton was not.
Randy
Randy
Offline rebocardo
  • Atlanta GA
« Reply #12 on: October 02, 2006, 08:44:45 AM »
I have used some Carlton chain. It was not good, it was not bad. No opinion really.
I have never had any chain stretch enough where it could not be adjusted. Stihl, Oregon, or Husky.
Offline treeape
« Reply #13 on: October 02, 2006, 04:17:59 PM »
        In a year i me and my tree svc crew go through about 4-5 hundred feet of chain. I prefer to run Oregon and i have NEVER had to remove a link because of chain stretch. Some thing else is wrong.
Offline outdoortype
Re: Chains stretching question. Oregon vs. Stihl.
« Reply #14 on: October 03, 2006, 08:03:18 PM »
I think the Stihl dealer was either misinformed or pulling your leg.  I say this because I bought a brand new Stihl chainsaw w/Stihl chain & it stretched more than my new Oregon chain on my new Husky.  Also when I put a new Stihl chain on that same on Husky, It seemed to stretch more than the oregon did. I was amazed because I expected exactly the opposite.  I prefer the Stihl brand because it seems to stay sharp longer but it doesn't cut much faster if at all.  Oregon makes a pretty good chain.  From what I've heard, Stihl has yet to find an answer to Oregon's 95VP.
Offline ehp
  • logger/chainsaw hack
    • ehpsaws.com
« Reply #15 on: October 09, 2006, 10:32:56 AM »
some of the stihl chain is based off of .063 then the driver thinned down to the gauge of the bar but the top of the driver where the rivets are is still .063 so that makes the chain stretch less but also makes the chain cut a wider path threw the log, the stihl chain forsure is a harder metal but that can be good and bad  it depends more on what you are cutting .
I know on the 044's stihls with a 20 inch bar and 7 pin gear you can stretch the chain to where you need to pull a link out very easy cause when brandnew you are about half way threw your chain adjustments  so it doesnot leave much left , guys falling trees donot have much trouble but the guys cutting the trees up on the landings do
Stretching chains
Started by cutter88 on Chainsaws
Last post September 04, 2014, 02:37:10 PM
by John Mc
Oregon Saw chains
Started by Bert on Chainsaws
Last post January 14, 2016, 06:36:09 AM
by Bert
moved
MOVED: Oregon Saw chains
Started by chet on Forestry and Logging
Last post January 13, 2016, 04:25:38 PM
by chet
32 inch Oregon bar, skip chisel, ripping chains new Husqvarna 372, 395, 3120
Started by mmartone on For Sale
Last post January 02, 2014, 11:56:35 PM
by mmartone
