AVAILABLE
Author Topic: Echo 670 carb adjustment  (Read 2502 times)
Offline davefrommd
  • pm-10-10s
« on: October 16, 2006, 08:33:46 AM »
I have a new Echo 670 I bought last year and only used it a couple of times. The engine cuts out when I give it gas. I believe the carburetor needs to be adjusted to give it more gas. How do I adjust the carburetor with those plastic H&L screws. When I start the engine it idles perfectly. dave
Offline sawguy21
Re: Echo 670 carb adjustment
« Reply #1 on: October 16, 2006, 05:29:08 PM »
Was it left sitting with fuel in it? Stale gas is the source of most problems. The fuel lines, carb diaphragms and fuel filter may need to be replaced.
Offline ladylake
« Reply #2 on: October 16, 2006, 05:35:47 PM »
Dave Most new saws are set real lean from the factory. Just got a echo CS440 both the high and low were lean and against the stops. They aren'e there anymore and it runs perfect.   Steve
Offline sawguy21
« Reply #3 on: October 16, 2006, 07:11:53 PM »
Steve, it should still start and rev up but you are right, the EPA mandates it has to run too lean for my liking too. Course I would never suggest anyone tinker with the limiter caps ;)
Offline ladylake
« Reply #4 on: October 16, 2006, 07:41:05 PM »
Sawguy
I guess we could take it back to the dealer every time we need to turn the adjustment screws 1/8 of a turn. Would more than likely cause more pollution hauling the saw 20 miles one way with the pickup than the saw will make in a lifetime..    Steve
Offline jacob j.
« Reply #5 on: October 16, 2006, 10:55:05 PM »
As carb components age, especially rubber metering and fuel pump diaphragms, usually the saw will have to richened. Especially after sitting. What I've done on the Echo saws is use my dremel to take a little material off the stops of the limiter caps and that works pretty well. The caps stay in place and 'look' stock but allow for a little adjustment.
Offline davefrommd
  • pm-10-10s
« Reply #6 on: October 17, 2006, 01:14:36 AM »
Thanks for the good help and suggestions. Yes the saw still had fuel from before. I did drain it and added fresh gas/oil mix. When I had just bought the saw it had hesitation as I gave it gas then I was able to rev it up like it should run. I knew then that the carb needed adjusting but figured I'd get to it later but never did. Appreciate all the good help. dave
Carb adjustment
Started by waho on Chainsaws
Last post May 30, 2017, 12:06:08 AM
by joe_indi
026 carb adjustment
Started by pesaventoc on Chainsaws
Last post December 20, 2017, 11:47:39 PM
by Ashbored
Carb adjustment
Started by chainsaw man on Chainsaws
Last post April 25, 2006, 01:00:23 PM
by scottr
Echo CS-346 bar adjustment.
Started by Sparkkky on Chainsaws
Last post March 06, 2005, 06:41:55 PM
by Sparkkky
