Arborwear
Author Topic: electric mill  (Read 1829 times)
Offline james
  • truck drivin fool
electric mill
« on: October 22, 2006, 01:18:55 PM »
trying to find a manufacturer of a 5- 8hp ELECTRIC mill(220 1 ph)
aprox equivelent to a 10 to 13 hp gas manual
not much luck with google searches
any help would be appreciated
thanx  james
Offline Bibbyman
    • Warden Sawmill
Re: electric mill
« Reply #1 on: October 22, 2006, 01:32:18 PM »
The only mill I know of that's available in single phase electric nearly in that range is the Wood-Mizer LT15.  It's available in 10hp single phase.
Wood-Mizer LT15 info.
You may talk to some of the other manufactures and see if they'll put an electric motor on one of their small mill.
Sawing since '94
Offline JimBuis
Re: electric mill
« Reply #2 on: October 22, 2006, 05:33:07 PM »
I'm not certain if the HP fits into your range or if the mill's specifications fit your other requirements, but you might want to check out Peterson's new Skillmill, i.e. small electric Swinger.
www.skillmill.com
Jim
Jim Buis                             Peterson 10" WPF swingmill
Offline jim blodgett
Re: electric mill
« Reply #3 on: October 22, 2006, 10:34:50 PM »
I went down to Linn Lumber Company to check out their mills a couple years ago and they offer a small electric motor as an option.  I'm not certain but I THINK they had a 10hp electric set up as a demo.  I ran it, very quiet, smooth.
Anyways, check them out.  Nice little mills.
Offline flht01
Re: electric mill
« Reply #4 on: October 24, 2006, 07:01:14 PM »
Take a look at model 21 Mister Sawmill in Arkansas
I don't know anything about them, just remembered see it when searching for a starter mill.
Kevin
Offline james
  • truck drivin fool
Re: electric mill
« Reply #5 on: October 25, 2006, 06:58:18 PM »
thanx the b-21 is sorta what i was lookin for since i all ready hav power why buy a expensive gas motor
james
TECH: portable electric mill, powered by portable electric generator
Started by woodbowl on Sawmills and Milling
Last post July 16, 2005, 06:11:01 AM
by rebocardo
Looking for an electric mill
Started by WoodenHead on Sawmills and Milling
Last post March 21, 2017, 07:32:05 PM
by paul case
Looking for a used electric bandsaw mill
Started by Clay Johnson on Sawmills and Milling
Last post February 22, 2013, 11:10:53 PM
by UN Hooker
How to connect an electric mill ????
Started by roger 4400 on Sawmills and Milling
Last post October 04, 2008, 04:12:41 PM
by roger 4400
