AVAILABLE
Author Topic: sick of frozen snow  (Read 1786 times)
Offline woodmills1
  • the truth shall set you free
sick of frozen snow
« on: January 20, 2003, 03:36:05 AM »
I have definately had enough of this frozen siberian wasteland scenerio.  tried to hook the forwarder to the trailer and the thing would'nt raise up high enough for the hitch, had to shovel the snow so the tractor would be low enough then block up under the stabilizers.  then i had to plow out the back yard and part of the orchard to get the sawmill a jump start from the toyota since the tractor battery is kinda hidden for using cables.  gotta think about that one this spring.  now I gotta plow out to the firepit to dump the slabs. ::) ::) o well enough complanin, if this here sawin thing was easy then everybody would be doin it :D ;D
Offline Rob
Re: sick of frozen snow
« Reply #1 on: January 20, 2003, 03:51:54 AM »
James I'm with ya on this one I'm sick of it also but the one thing I do like is the $65.00 hr I iget for plowing for the town it's nice when you get a check 30 days later for 4-5,000  ;D
                     Later Rob.
Offline Noble_Ma
  • Have logs? ............. We'll travel!
« Reply #2 on: January 20, 2003, 05:33:39 AM »
Hey woodmills1, it looks like it's time to get that mill under a roof!  Mine is covered and snowed in until spring or the next thaw.  That's fine with me seeing that I have lots of other work to keep me busy.
« Reply #3 on: January 20, 2003, 05:41:18 AM »
Hey James,
You can cheat a little length to the battery by hooking onto the positive at the starter and ground at the frame.
Every year I threaten to put a battery post outside of the tractor housing somewhere.   Gonna get to it one of these days. ;D :D
Offline beenthere
« Reply #4 on: January 20, 2003, 07:25:38 AM »
The bayonet connectors similar to welding cables seem to work well (also used by towing co.'s on service vehicles) for a quick battery hook-up system, and can be enclosed (female end) so accidental shorting isn't so likely. Only problem, the connectors seem to be plenty expensive.
Offline woodmills1
« Reply #5 on: January 20, 2003, 12:04:59 PM »
hey i like that trick using the starter.  outside terminals would be real nice.  and yes rob the snowplow checks are lotsa fun, but the after plow repairs and before plow prep gets old, along with staying up long enough to not need alarm clock for the day job. :D
Offline Rob
« Reply #6 on: January 20, 2003, 12:09:53 PM »
Yes James you are right the lonnnnggnggg hours do sux but it's well worth it in the long run...I usually gross $18-22,000 a winter for plowing but most of that is from salting..Nothing like gettin up 1am and firin up the 10 wheeler and not comin' home till 5pm the next day  ::)
                          Later Rob..
Offline woodmills1
« Reply #7 on: January 20, 2003, 12:33:53 PM »
lets see I plowed steets for Dracut Ma for 9 years with my chevy 86 one ton 4x4 dump and made good money, but with less than 60,000 miles ive done: 2 trans jobs(turbo 400), dump bed, front and rear springs, 3 oil pans, 1 rear pumpkin cover, all U-joints on all driveshafts, dump control cables, fenders, doors, and entire cab replacement, 2 gas tanks, 2 sets of brake lines, fuel lines, radiator, heater core, heater box,
and fuel pump. well at least the motor works, if the block will continue to hold water, and add 3 exhausts one set of manifolds and more exhaust donuts than I can remember.
Offline Rob
« Reply #8 on: January 20, 2003, 12:41:31 PM »
WOW now thats what I call a salty list the salt in New England seems to eat alot of parts up and spit them out as rust believe me I know the feeling.. >:( ;D
              Later Rob.
sick of snow
Started by woodmills1 on Sawmills and Milling
Last post January 28, 2011, 09:10:52 PM
by terrifictimbersllc
smiley
Snow... Needed a snow related project ! It's done !
Started by isawlogs on General Woodworking
Last post February 17, 2013, 10:09:22 PM
by lowpolyjoe
Snow Snake & Snow Flea pics
Started by chet on General Board
Last post March 27, 2005, 09:49:21 AM
by Mark M
Sick Cat 518
Started by IMOWOOD on Forestry and Logging
Last post December 08, 2011, 04:08:30 AM
by John Woodworth
