Author Topic: Little confusion when it comes to sharpening  (Read 4151 times)
Offline alsayyed
« on: November 07, 2006, 02:22:59 PM »
I am sorry to write after this time using the chain saw and know I ask the question which I should’ve asked before. When it comes to sharpening I hear people say sharp at 4 or 5 and 35 degrees, I normally sharp at 4 degrees maybe when I use Logosol bar and Stihl chain. Know the important question what do you sharp actually  underneath the plate or you sharp the curve which like half circle which is part of the top plate. I hope everyone understand what I am talking about.
When it comes to sharpen 3/8 chain I should use 9 mm round file or smaller or bigger
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Little confusion when it comes to sharpening
« Reply #1 on: November 07, 2006, 02:42:48 PM »
if you have the file held properly, you end up filing the top plate, and the curve.
9mm is roughly 11/32, a 7/32" file is what I use for 3/8 chain.  I'd think 9mm to be way to big, find something closer to 5.5mm
have I mentioned today how much I hate the metric system?
lots of dull bands and chains
Offline Kevin
« Reply #2 on: November 07, 2006, 05:11:59 PM »
What is the exact chain you are using?
Offline alsayyed
« Reply #3 on: November 07, 2006, 05:37:52 PM »
well mostly Stihl. I just purchased two from Logosol they are 3/8 x 050 and the rest of chain 3/8 x 063 and some ripping chain from Granberg international. i am trying to sharping them all. I have purchased the 12v sharpner form Granberg International with 7/32 sharpining burrs
Offline Dan_Shade
« Reply #4 on: November 07, 2006, 05:39:07 PM »
do you know the model of the chain?  is it 33rs?  33rm?
Offline alsayyed
« Reply #5 on: November 07, 2006, 06:01:00 PM »
thanks Dan for your help. i have check the box for the one that Logosol recommended 63 PMX 72 OILOMATIC 3 DOSE IT SOUND FAMLIAR TO YOU
Offline Kevin
« Reply #6 on: November 07, 2006, 09:06:19 PM »
PM is Picco Micro, calls for a 5/32" or 4mm file.
Offline rebocardo
  • Atlanta GA
« Reply #7 on: November 07, 2006, 09:24:18 PM »
The angle of the top plate differs depending on what the chain is being used, I assume you are talking strictly ripping for the Logosol. Some Stihl chain for regular cross cutting (normal use) does require 35 degrees.
Offline Kevin
« Reply #8 on: November 07, 2006, 09:31:22 PM »
What ever angle you decide on be sure the cutting or working corner of the cutter gets sharpened.
If you blacken the cutting edge with a black marking pen you will see where the metal on the tooth gets filed.
Offline rebocardo
  • Atlanta GA
« Reply #9 on: November 08, 2006, 11:11:58 AM »
Plus, on some chain you are not suppose to file down the depth gauge raker, learned that the hard way, because the chain tilts back towards its heel while cutting.
Offline Tony_T
« Reply #10 on: November 08, 2006, 07:38:41 PM »
Logosol 3/8 X 0.050 PMX ripping chain requires a 5/32 file and recommended angle is 5 degrees
Offline Raphael
  • Willing and able to do a boring job.
« Reply #11 on: November 08, 2006, 09:16:54 PM »
  Here is a link to Logosol's booklet on bar and chain care (pdf).
  I use 10° as 'The Logosol Filing Device' has 10° (& 35°) guide lines, Rob got me hooked on it a couple years back.  Combined with the Pferd file I can sharpen accurately by hand faster than I can with the grinder.
... he was middle aged,
 --Godley & Creme
Alert message confusion
Started by pine on Technical Support Topics
Last post February 15, 2019, 03:03:37 AM
by PA_Walnut
Site index confusion
Started by jeffreythree on Ask The Forester
Last post May 10, 2009, 11:22:50 AM
by woodtroll
Property Boundary Confusion
Started by chpalmer on Ask The Forester
Last post April 25, 2017, 08:47:52 PM
by dgdrls
Thrust formula confusion
Started by rkb5916 on Timber Framing/Log construction
Last post January 22, 2017, 10:07:46 PM
by Don P
