Author Topic: husky enuff?  (Read 7693 times)
Offline turningfool
husky enuff?
« on: December 23, 2006, 06:53:03 AM »
i have a husqvarna 365 with a 36" bar/chain..i was wondering whrther its gutsy enought tohandle a 72 " bar temporarily..i have a monster oak to drop and the 36 just plain aint gonna cut it..it is well maintained and runs like a champ with the 36..but certainly dont want to mess it up ..they dont give huskys away :)
Offline sawguy21
Re: husky enuff?
« Reply #1 on: December 23, 2006, 11:34:13 AM »
Where are you gonna find a 72" bar? ;D Even a 36" is a lot on your saw. I liken it to towing a big gooseneck travel trailer with a 6 cylinder half ton, it will hook up but don't ask it to go far. You need to work from both sides of the tree, a "west coast" full wrap handle makes this a lot easier and safer.
Offline SwampDonkey
  • Large Tooth
Re: husky enuff?
« Reply #2 on: December 23, 2006, 11:48:31 AM »
Furby said he's got one, but no functioning saw.  I wonder if that means anything. ;D
Move'n on.
Offline MDP
  • Logger, and proud of it.
Re: husky enuff?
« Reply #3 on: December 23, 2006, 11:51:14 AM »
You can cut an awfully big tree with a 36" bar, like sawguy said, you just have to work both sides of the tree. Take your time make sure all your cuts match  be safe and keep the chain real sharp too, if I had to guess a 36" bar might be about the max for that saw. it'll hit the ground no problem.
Online Furby
  • Blurb....
Re: husky enuff?
« Reply #4 on: December 23, 2006, 07:50:34 PM »
Yup, my bar. :D
I know how it handles on the 3120xp and I'm pretty concerned about messing up TF's 365.
I'm also wondering if one guy can even pick up the 72" with the 365. The 3120 acts as a counter balance. ;D
Offline SwampDonkey
  • Large Tooth
Re: husky enuff?
« Reply #5 on: December 23, 2006, 08:25:51 PM »
Furby, did you use it on a chainsaw mill, or were you out cutting Doug. Fir and western red cedar in a past life? ;D
Move'n on.
Online Furby
  • Blurb....
Re: husky enuff?
« Reply #6 on: December 23, 2006, 08:40:55 PM »
Only time I've actually used the 72" was on the cookies for the piggy roast.
Still working on the slabber. Would rather use a 4 stroke for the slabber, but have been slowly picking up parts for an Alaskan to be used with the 3120 until I can build a real slabber. Almost there on the Alaskan.
Offline Ianab
Re: husky enuff?
« Reply #7 on: December 23, 2006, 10:02:13 PM »
Having a look at the other post I see your tree measures out about 56", so the 36" bar wont be a problem  :) You can allways trim away some of the butt flare if you need to.
Have a look at this post, it's felling a 52" tree with a 28" bar, and a few diagrams and discussions. As your tree doesn't have much lean you probably dont need to bore cut it, just back cut from both sides and have plenty of wedges in place  ;)
http://www.forestryforum.com/board/index.php?topic=22582.0
Cheers
Offline Ironwood
    • http://www.branchandburl.com
Re: husky enuff?
« Reply #8 on: December 23, 2006, 10:30:38 PM »
The problem with the 72" bar is deflection. You would need to start a cut with a shorter bar and insert the 72" in after that as the chains like to come off the bigger ones due to deflection when laid sideways to cut. Unless you use a helper handle but ............anyone want to hold the other end of THAT?. Not me!! Reid
Offline SwampDonkey
  • Large Tooth
Re: husky enuff?
« Reply #9 on: December 23, 2006, 10:45:51 PM »
I was wondering the same exact thing about deflection and holding it. Don't look at me neither for nominations.  :P
Move'n on.
Online Furby
  • Blurb....
Re: husky enuff?
« Reply #10 on: December 23, 2006, 11:09:08 PM »
It is VERY hard to keep the nose out of the dirt! :o
Don't have to worry much about kickback though. ;D
Was actually thinking about a bracket that I could pop on and off real fast to hold the belly of the blade when starting a slab cut and then pop it off once the cut is started.
Offline turningfool
Re: husky enuff?
« Reply #11 on: December 24, 2006, 08:10:33 AM »
you catch on fast swampdonkey
Offline turningfool
Re: husky enuff?
« Reply #12 on: December 24, 2006, 08:15:58 AM »
the tree in question is in thr forstry/logging section on here..i dont think that the 36 will do it,but i,ve been wrong before!..being in a residential area ,i'd hate to leave it with a foot of solid wood in the middle uncut and have it drop unexpectedly in high winds when there are kids around
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: husky enuff?
« Reply #13 on: December 24, 2006, 10:21:51 AM »
Why would a 36 not do it?  Our forefathers did it with an ax.
Offline TexasTimbers
    • Dovetail Spline Jig
Re: husky enuff?
« Reply #14 on: December 24, 2006, 11:12:04 AM »
tf,
what ARE the details about the drop? Not the tree; the environment it is in. As you mention kids etc. certainly you aren't considering dropping it without at least 1 ground personell. Are you sure this thing doesn't need to be limbed first? Not  that you can't handle it but to make life easier for you maybe you could find a local arborist who would be willing to take it as aside job for a portion of the wood plus a little coin . . . i.e. a lot less coin that he normally would have to have ???
Offline SawTroll
Re: husky enuff?
« Reply #15 on: December 24, 2006, 11:48:55 AM »
This is just redicilous, even that 36" is far too much on a 365!! smiley_whacko smiley_tom_dizzyguy01
..hopefully the saw on question is a 395, not a 365.....
Information collector.
Offline Ianab
Re: husky enuff?
« Reply #16 on: December 24, 2006, 03:47:55 PM »
Yup.. you need a bit of accurate measuring and a plan BEFORE you start. Technically it's possible to drop a tree thats 3 times your bar length, but you have to bore through the hinge wood and hollow out the centre of the tree BEFORE you start the back cut. It's not something you can do later  :o
It's a technically advanced cut, but more practical than waving a 72" bar around on an underpowered saw I think  ;)
Cheers
Offline Simonian
Re: husky enuff?
« Reply #17 on: December 24, 2006, 05:21:24 PM »
You are better off leaving the tree alone. Even if it is dead. Cause with your lack of skill, that tree will kill you.
And if it is alive. it has seen too much history to kill for your own personal good. It is like shooting an elephant for sport. Totally point less.
You know what a Redneck says just before he dies?
Offline jokers
  • Chainsaw Freak
Re: husky enuff?
« Reply #18 on: December 24, 2006, 09:37:34 PM »
No, why don`t you tell us?  :D
Sorry Simonian, nothing personal, just that you put that one right out there and I consider it bad karma to walk past sitting ducks.  ;D
Online Furby
  • Blurb....
Re: husky enuff?
« Reply #19 on: December 24, 2006, 09:38:59 PM »
This tree is not a tree, it is a 35' plus stump.
There is ONE dead branch at the top, and I agree, I'd probly take that off before dropping, but is nothing that will really affect the stump.
There is some rot in the butt and I fear there is a fair amount, so that boring the hinge may not be needed. That can be determinded after cutting the notch, like always.
There is plenty of wood there to hold the stump up while the notch is worked on.
Yes, I have read that a 36" bar is too much for a 365, thus my concern for the 72".
Here is a link to the thread with pics for those who have not seen it.
Link
I do have a few more pics, but they are pretty much all the same.
Been Lurkin' long enuff....
Started by zopi on Sawmills and Milling
Last post January 08, 2008, 01:57:25 PM
by zopi
Husky Prestique 61 (1980) Vs Husky 562XP
Started by Mikeinkaty on Chainsaws
Last post June 13, 2016, 06:09:49 AM
by SawTroll
Husky 268
Started by Ivey on Chainsaws
Last post September 26, 2006, 04:25:01 AM
by SawTroll
Husky 51
Started by naturaledge1 on Chainsaws
Last post April 10, 2019, 11:16:57 AM
by dougand3
