Author Topic: Question about Outdoor boilers  (Read 13502 times)
Offline Dana
    • Green Leaf Farms
Re: Question about Outdoor boilers
« Reply #20 on: January 20, 2007, 07:36:36 AM »
Central Boiler recommends the shallow bury depth in case you have ground water near the surface. Water will conduct heat out of the plumbing much quicker than frozen earth.
Offline woodmills1
  • the truth shall set you free
« Reply #21 on: January 20, 2007, 08:54:23 AM »
Yes, ground water in contact with the heat pipes would be a much larger problem.  My pipes are shallow, around 2 foot.  They have a 1 inch black foam insulation and then a styrofoam box around that.  The whole outside run was then encased in a 9 mil poly sock, one piece from cellar to stove, being careful not to perforated it during installation.  I also lined the trench with sawdust and then covered the pipes with sawdust to keep from puncturing the bag.  My company, Free Heat Machine, made a big deal about excluding water from contact with the pipes.  Waters ability to either hold or remove heat is amazing.  I can still see the look on my students faces when I boiled water in a plain dixie cup using a bunsen burner. :D :D
Offline Furby
  • Blurb....
« Reply #22 on: January 20, 2007, 02:51:45 PM »
That's why dirt is such a poor insulation.
Offline OneWithWood
  • I am happy!
« Reply #23 on: January 22, 2007, 03:06:45 PM »
Much to my horror I discovered that wrapping the pipes in plastic was a big mistake.  It just traps condensation, saturating the styrofoam  :(
One With Wood
Offline woodmills1
« Reply #24 on: January 22, 2007, 08:43:18 PM »
my plastic is a one piece bag from back of stove to inside the house.
Offline Mtnjack
  • Bear Hunter
« Reply #25 on: January 22, 2007, 09:17:17 PM »
Remember insulation only slows heat transfer, does not stop it,just have to start mowing before every one else.I heat with a taylor 165 feet from house and lose 10 to 20 degrees,180 to 160 not a problem. Just taped bbq meter to pipe in basement.House is plenty warm. Mtn Jack
moved
MOVED: Question about Outdoor boilers
Last post January 22, 2007, 03:33:51 PM
by Jeff
question
Outdoor wood boilers
Started by icefishingrulz on Firewood and Wood Heating
Last post March 23, 2014, 08:53:55 AM
by spyder68
Started by delvis on Firewood and Wood Heating
Last post April 01, 2014, 09:26:35 AM
by thecfarm
Outdoor Wood Boilers....using more than one together...
Started by Captain on Firewood and Wood Heating
Last post April 16, 2007, 05:16:57 PM
by thecfarm
