Tally-I/O
Author Topic: yellow poplar mc  (Read 1929 times)
Offline 1953greg
yellow poplar mc
« on: January 21, 2007, 12:42:14 AM »
what is the "assumed" moisture content of green yellow poplar?
the toolbox calculator says it weights 3.2 lbs/bf green
what is the weight at 10% ??? ??? ??? ???
good day    greg
Offline Den Socling
  • just wondering
Re: yellow poplar mc
« Reply #1 on: January 21, 2007, 09:22:10 AM »
The DKOM says the heartwood starts at 83% and the sapwood 106%. The DKOM also says it weighs 2.549 pounds per boardfoot at 15%and 2.454 at 6%. A handy book, the DKOM!
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
« Reply #2 on: January 22, 2007, 06:35:56 AM »
Greg,
Instead of using assumed MC use your microwave to oven dry a sample.  You can also check out the lab auction sites and pick up a nice little Blue M Lab oven for a few hundred $$.
Offline OneWithWood
  • I am happy!
« Reply #3 on: January 22, 2007, 01:45:11 PM »
A word of caution - dry the piece in the microwave in steps.  If you are too agressive your microwave will never smell the same  :D  If you take your time the odor is actually quite pleasant-you may even begin to wonder just what poplar taste like  ;)
One With Wood
Offline Warren
  • Whatever you do, work at it with all your heart, as working for the Lord.... Col. 3:23
« Reply #4 on: January 22, 2007, 09:46:23 PM »
Ditto what OWW said.  It took several weeks to get the "smoke" smell out of my microwave the first time I tried that method.
Warren
LT40SHD42, Case 1845C, W&S Forklift, Baker Edger ...  And not near enough time in the day ...
Offline Homer
« Reply #5 on: January 26, 2007, 03:20:11 AM »
Hello again.  When I dry wood samples I use lowest power and run first time for twenty to thirty minutes. Paper towel under sample. weigh and run lowest power for ten minutes. Run the rest low power/ five minutes until no weight change. Moniter first long run, may have to modify time.    [/size] Homer
Got Yellow Poplar and Southern Yellow Pine...Which One, Or Both?
Started by Woodmonkey on Timber Framing/Log construction
Last post April 16, 2016, 09:49:49 PM
by ChrisGermany
Yellow Poplar Fence?
Started by ebath on Sawmills and Milling
Last post March 30, 2008, 09:48:34 AM
by rewimmer
Yellow Poplar log prices
Started by JRC on Sawmills and Milling
Last post October 20, 2009, 10:47:05 AM
by MTrim
Yellow Poplar blocks - 4'' x 4'' x 96''
Started by Kelvin Kendall on Wanted
Last post April 08, 2013, 09:53:51 PM
by Kelvin Kendall
