Author Topic: Tordon question  (Read 17525 times)
Offline Steven A.
Tordon question
« on: January 23, 2007, 11:31:09 AM »
I am killing 4  mature spruce trees with Tordon. Drilled holes around the trunk and into exposed roots last august and put Tordon in the holes. Its working but very slowly.
If I repeat the application now in winter will it be effective or does the tree need to be actively growing? I'd like them to be dead and brown by May.
I'm in  northern Wisconsin.
Thanks, Steve.
Offline chet
Re: Tordon question
« Reply #1 on: January 23, 2007, 11:50:36 AM »
Which Tordon product are you using, and what are you using for a carrier?  Or are you using a RTU product?
Offline Steven A.
Re: Tordon question
« Reply #2 on: January 23, 2007, 11:56:35 AM »
RTU undiluted.
Offline chet
Re: Tordon question
« Reply #3 on: January 23, 2007, 12:41:55 PM »
A frill or girdle treatment will work much better than the method you used, with the RTU product. If it is truly a Spruce you are trying to kill you may have problems. This product normally works well on Cedars and Firs, but the Spruces and Pines are very tolerant. Be very carefully with this product as it will "move" within root systems and in the ground and you may kill way more than you bargained for. Cutting may be a better option.  :)
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
Re: Tordon question
« Reply #4 on: January 27, 2007, 12:22:35 PM »
Drilling holes in the trunk may be putting the Tordon too far into the tree.  It needs to reach the cambium layer just underneath the bark, which would mean only 1/2 an inch or so into the tree.  Deeper holes might be putting the herbicide past the cambium where it would not be absorbed by the tree.
On the label I have seen for Tordon RTU, it's not labeled for treating spruce. But since this is the herbicide you have, I feel it would work if you instead used it in a cut-surface style of application.  Cut the trees down and apply the Tordon immediately to the outer 1" of stump so as to put it right on to the cambium layer where it will be absorbed into the tree.
But mature spruce might not sprout anyway.  Big conifers don't, usually. You might just cut them down and forego the Tordon application.
Or if you don't want to cut them down, just remove a strip of bark all the way around the trunk with an ax or chainsaw.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline Steven A.
Re: Tordon question
« Reply #5 on: January 27, 2007, 12:34:14 PM »
Thanks for the help.
I need to kill these before they are cut. Heres why.
The trees are growing over the 30 year old steel septic tank and drainfield at my second home where my mother lives.
I want the trees gone so when the septic tank fails in the next year or so [ Its rusting away on top] I don't have to do a tree removal project on short notice so the plumber can replace the tank.
My mother is elderly and will have a fit if I cut the nice trees even though they have to go. She is a gardener however and understands removing dead plants. So...... I am making the plants dead.
No there is not another place the septic can go. No, she will not listen to reason. Yes I have tried to think of any other alternative.  Unfortunately sometimes you just gotta do what you gotta do.
I'm going to drill shallow holes again and apply some more.
Will this work in winter when the trees are not really growing or will it be better to wait till spring?
Offline Phorester
Re: Tordon question
« Reply #6 on: January 27, 2007, 12:37:00 PM »
We're talking back and forth at the same time.  I revised my previous message before I read your last one, check it again and see if this answers your question.
Offline Steven A.
Re: Tordon question
« Reply #7 on: January 27, 2007, 12:46:21 PM »
Can that strip just be a chainsaw cut wide?
I'd prefer to not make this too noticeable to an 83 year olds eyes.
Will the tree be affected by a winter application of Tordon?
Offline Texas Ranger
  • Texan, by God and by choice.
Re: Tordon question
« Reply #8 on: January 27, 2007, 04:03:32 PM »
Frill the bark with an hatchet,, one whack per diameter inch around the stem, put tordon in the frill, will hardly be visible.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Tordon question
« Reply #9 on: January 27, 2007, 11:16:18 PM »
I don't know much about spruce, but I think you will be more successful if you wait till spring after the buds break.
Offline Phorester
Re: Tordon question
« Reply #10 on: January 28, 2007, 10:23:06 AM »
Yep, a chainsaw cut wide will do it.  It can be done any time in the year.  However, a tree is weakest in late spring - early summer just after it has put on it's new foliage.  Hardwoods especially.  It has just used all its winter food reserves to make new foliage, and hasn't yet had time to photosynthesize new reserves.  So in general, the best time to kill a tree is then.
But different herbicides have different times of the year when they are most effective, based on how the herbicide works.  Most herbicides can be applied with more than one method. Each herbicide label gives the best time for using it in different application methods. So the label directions need to be followed.  The tordon RTU label says any time is good for the frill method as TRanger describes.
Offline Pilot
Re: Tordon question
« Reply #11 on: March 20, 2007, 01:08:01 AM »
Crossbow mixed in oil, 2 oz/gal (diesel works, but they prefer you buy a special vegetable oil for lots more $) sprayed on the outside of the bark will be carried thru the bark & kill the tree.  Works great on cascara, Scotch broom and blackberries, but I have never tried it on conifers, 'cause they are the good guys around here.  Works at any time of the year.  Spray from ground level up to about 6" all around the tree.
Offline gtraxler
  • Member*
Re: Tordon question
« Reply #12 on: May 31, 2017, 04:08:13 PM »
there is rain in the forecast for Saturday, and I have a group of family coming to eradicate Amur Maple.  if it rains a bit on freshly treated areas, will it still work?  i am not overly concerned with the stuff killing surrounding vegetation, it is mostly grass.  Using Tordon RTU.
Offline Claybraker
  • Mostly New!
Re: Tordon question
« Reply #13 on: June 02, 2017, 07:55:02 AM »
As long as it's not raining while you are applying it should be fine. I like a quart spray bottle for injecting Tordon instead of the applicator tip, I can be more precise. With the applicator that comes with TordonRTU too much of the material leaks out of the frill or hack and dribbles down the bark, where it's wasted, and would be susceptible to washing off. I also use a cordless drill with a 3/8" bit to drill a very shallow hole and wallow that hole out to form a pocket for 1 ml of herbicide. One of the keys is a very shallow hole. You don't want to drill deep, just past the bark, and then move the drill motor so you are drilling almost parallel to the bark, not deep into the trunk. One hole for every 3-4" of dbh has smoked everything I've tried it on. Another Pro tip, if you use a quart spray bottle, take a few seconds to label it with the contents.
Tordon question
Started by gspren on Ask The Forester
Last post June 09, 2018, 08:09:21 PM
by Larry
Tordon and T.S.I.
Started by Smitty316 on Forestry and Logging
Last post November 02, 2014, 09:54:17 PM
by chain
Band selection question (boring question but includes bonus pics!)
Started by Piston on Sawmills and Milling
Last post October 15, 2010, 05:39:58 PM
by barbender
angry
Question for you surveyors (sorry but it's a touchy question)
Started by SwampDonkey on General Board
Last post September 25, 2008, 10:55:40 PM
by cheyenne
