Tally-I/O
Author Topic: "Vacuumterm" drying of a bar a pine, a fur-tree  (Read 3632 times)
Offline nick
  • www.vacuums.ru
    • www.vacuums.ru
« on: February 06, 2007, 03:08:20 PM »
Hello!
I am Sergey assistant
Drying kiln " Vacuumterm " is capable to dry a bar 100 х 200 mm, 150 х 150 mm, 150 х 200 mm, 200 х 200 mm.
After drying passes processing in temperature 180 degrees C. Water does not absorb. The oak, an ash, a beech, a hornbeam changes color.
Board for a floor well holds water.
What you think, in construction of houses and windows it is possible to apply such bar?
Nick.
Online beenthere
Re: "Vacuumterm" drying of a bar a pine, a fur-tree
« Reply #1 on: February 06, 2007, 04:10:11 PM »
Nick
Welcome to the forum. Great pictures you posted.
I'm trying to sort out the word you use, "bar".  Is this a size of a piece of wood (what we might call a cant or a timber) or does "bar" refer to a treatment to the wood, or maybe one vacuum kiln charge (load).
With a little more discussion, we can probably figure it out.
Say hello to Sergey for us, please.
Offline Dana
    • Green Leaf Farms
« Reply #2 on: February 07, 2007, 06:15:47 AM »
The term "bar" is it a measurement of pressure or lack of? Hydraulic gauges are often measured in bars.
Offline Den Socling
  • just wondering
« Reply #3 on: February 07, 2007, 08:03:03 AM »
Hi Nick,
Did I hear that you are Sergey's son?
I do believe that he is referring to a beam when he says bar. But that might be wrong.  ;)
Den
Online beenthere
« Reply #4 on: February 07, 2007, 10:25:32 AM »
Den
That interp would fit Nick's explanation. thanks :)
Offline nick
  • www.vacuums.ru
    • www.vacuums.ru
« Reply #5 on: February 07, 2007, 01:19:38 PM »
2 beenthere: Bar - is a size of a piece of wood.
2 Den- I am a husband of Sergey's daughter.He have two daughters.Look fotos on gallery (User galleries > nick > Our Family)
Offline serg
  • http://www.vacuums.ru
    • www.vacuums.ru
« Reply #6 on: February 08, 2007, 10:04:03 AM »
Hello friends!
I made new vacuum drying with the big temperature. I am helped by members of my family.
I have dried up in the vacuum chamber  pine 200 200 mm, 150 - 200 mm and another up to W = 6 %.
Part of a bar I have dried up in "Vacuumterm" up to W = 2 %. Temperature of 180 degrees .
For 6 days humidity has risen up to 12 % without "Vacuumterm" other 4 days there are on place W = 12 %. In total has passed 10 days.
After processing began W = 4 % and more moisture from air does not take.
Den.
This technology will allow to build houses near ocean from pine 200 200 mm? ???
Sergey.
Offline nick
  • www.vacuums.ru
    • www.vacuums.ru
« Reply #7 on: February 12, 2007, 11:05:45 AM »
Hi! We continue to make experiments with construction of houses of an integral bar of a pine.
The first drying has passed 8 months back. The bar from the first drying had 6-7 % on an output. In 8 months humidity in the centre of 6 %, on a surface of 9 % (month lays in heated workshop) and 17 % lays in not heated to shop.
Units of connection for construction of houses from an integral bar of a pine.
Nick
Offline logwalker
  • Got Logs??
« Reply #8 on: February 20, 2007, 01:04:05 AM »
I don't know exactly what you are doing Nick, but it looks very cool. Show us some more. Joe
Offline serg
    • www.vacuums.ru
« Reply #9 on: February 21, 2007, 07:50:15 AM »
nick dries a bar for construction of houses a pine.
http: // www.profbrus.ru/catalog.phtml? section_id=38
 Thickness 200 200 mm. It is speed, quality of construction of a house. We do not use a bar, three layers a pine of 50 mm. When there passes processing of a dry bar humidity of 6 % at 180 degrees C, the bar of a pine in itself does not take water. Humidity of 4 %.
I wanted to have contact to that who dries such bar a pine in America?  ???
America builds houses of a pine? ??? What thickness is dried as much as possible? ???
Sergey.
Offline nick
  • www.vacuums.ru
    • www.vacuums.ru
« Reply #10 on: February 28, 2007, 01:06:26 PM »
The pine a bar 150 х 200 mm after vacuumterm - humidity is stable W = 4 %. 30 days was on open air.
Such bar can be applied in housing construction.
What your opinion?
Nick.
Offline low_48
« Reply #11 on: February 28, 2007, 01:33:26 PM »
Nick,
While looking at your process I find the following term, Vacuum pyrolysis. Is this the technology that you are working on? I found this at the following site;
http://en.wikipedia.org/wiki/Pyrolysis#Vacuum_pyrolysis
Do you know if material like this is being sold in the United States?
This all sounds very interesting. Should be a much better process than adding dangerous chemicals to change the characteristics of wood.
Offline nick
  • www.vacuums.ru
    • www.vacuums.ru
« Reply #12 on: March 01, 2007, 12:40:03 PM »
Pyrolysis  makes coal of a tree for a barbecue. Processing wood for building needs demands a soft mode up to 180 degrees C. It needs good drying up to humidity of 6 % - 8 % without deviations.
I think, that this technology can replace a multilayered bar in housing construction and manufacture of windows.
I have learned to modify an oak, an ash, a maple, a birch, a hornbeam, a beech. I   continue experiences.
In US somebody makes modifications with temperature? I can have useful contact.
Offline serg
    • www.vacuums.ru
« Reply #13 on: March 08, 2007, 11:12:36 AM »
Hello!
The architect Lena makes the project of the American house. A skeleton from a pine humidity of 3.2 % processing "Vacuumterm". Our way of construction correct? Look a breadboard model the house.
Sergey.
Work "Vacuumterm"
Started by serg on Drying and Processing
Last post July 18, 2007, 06:01:32 PM
by Den Socling
Drying "Cookies" or "Rounds"
Started by Greg Cook on Drying and Processing
Last post September 21, 2008, 09:51:57 PM
by woodbowl
Microwave drying small Maple. 8" X 8" X 12"
Started by Jim Spencer on Drying and Processing
Last post February 28, 2007, 05:15:38 PM
by low_48
Re: Drying 2" pine in a nyle L 200
Started by Don_Lewis on Drying and Processing
Last post August 30, 2004, 04:22:19 PM
by Don_Lewis
