Author Topic: How do I cut a stump REALLY low.  (Read 9379 times)
Offline Steven A.
« on: March 12, 2007, 04:12:50 PM »
I have 8 fir and pine landscape trees in a lawn that I am cutting down. About 12 to 20 inches on the stump. I want to cut the stumps flush with the lawn and let them rot away or something.  I want to just be able to mow over them. The money I save by not hiring a stumpgrinder I'll use to buy some other landscape plants.
So, this may be a stupid question but.... whats the easiest way to cut them close and minimze the wear on my chain and bar.
In the past I've cut them a little above ground when I dropped the tree and then dug down around the stump, sprayed it off with a hose and then just sawed it off as low as possible.
I cannot think of any other way to do this but maybe someone here has a majic technique.
Please, majic?   :)
Offline Troy
  • Good help is hard to find!
Re: How do I cut a stump REALLY low.
« Reply #1 on: March 12, 2007, 05:23:22 PM »
That's the way I do it Steven.  I also make a few plunge cuts into the face of the stumps to help in the rotting process.
Peterson ATS 8" 27hp
Offline Kevin
« Reply #2 on: March 12, 2007, 06:32:24 PM »
Did you consider renting a stump grinder and doing the work yourself?
Offline SwampDonkey
  • Large Tooth
« Reply #3 on: March 12, 2007, 06:34:22 PM »
That's the way I do it Steve, and the ones I get lazy about I let rot for 10 years and break up with a pollack or axe. Although softwood, even fir, is a lot more resilient than a hardwood stump.
Move'n on.
Offline stonebroke
« Reply #4 on: March 12, 2007, 07:35:46 PM »
After you cut it as low as you can take a drill witha cheap spade bit( the bigger the better) and drill as many holes as you can stand to do in the stump. Then fill the holes with manure or compost and cover the stump with compost. Plant flowers and give it a few years. this will accelerate the rate of decay.
Stonebroke
Offline Stephen Alford
« Reply #5 on: March 12, 2007, 09:37:58 PM »
Hi ya Stephen (great name) ,when you get it cut as low as possible cover it with barbaque brickets, lots or some starter stuff , remember fire is our friend.  fire it up and throw a couple of hot dogs on it so neighbors pay it no attention  and bye stump repeat if necessary. fire causes it to rot really quickly if there is anything left. Stephen
logon
Offline pineywoods
« Reply #6 on: March 12, 2007, 10:10:16 PM »
Cut both ends out of a 55 gallon drum. Set the drum down over the stump with 3 or 4 bricks under the drum to allow airflow.. fill the drum with scrap wood and set it on fire. Not only burns the stump, will even burn out the roots.  Not recommended on a lawn with dead dry grass.. don't ask how I know.....
Offline jonsered
« Reply #7 on: March 12, 2007, 10:24:43 PM »
Only other way I can think of is to : start on one side of the stump cutting at an angle towards the ground on the side.Don't cut all the way through and mind the tip of the saw  does'nt go accross the stump to the other side but try to cut as close as possible. Then cutting at an angle to ground level on the other side again don't cut all the way through for this cut you. To see where your chain is cutting remove your saw from time to time and with an axe simply chop off the pieces as you would firewood when you do this you should see how far you are from the edge and when you only have a little bit to cut you should be able to cut that with the axe. Do the same to the other side. If you are left with a high centre as it is all timber you can lay your saw flat and cut it off. Hope this helps as I can't think of any other way. Cheers J.S.
Offline wiam
« Reply #8 on: March 12, 2007, 10:35:30 PM »
I just throw on an old chain and have at it.  What I miss, I will clean up with the mower. :D :D
Will
Offline SwampDonkey
  • Large Tooth
« Reply #9 on: March 13, 2007, 07:42:04 AM »
I did the fire thing to. But it was to kill the boxelder stumps we cut after the '98 ice storm. If ya didn't burn the darn things they'd sucker for ever. Yup, fire will fix them up right. ;D
Move'n on.
Offline Onthesauk
  • Still learning!
« Reply #10 on: March 13, 2007, 11:16:33 AM »
I've always used the fire method but every once in awhile I seem to hit one that gets "fire hardened" by the process.  Must be too wet, too green or something.
John Deere 3038E
Sukuki LT-F500
Donít attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Offline PB Logging
  • Just ask and I suppose if you don't ask I'm bound to offer up my opinion anyway, just give me time.
« Reply #11 on: March 13, 2007, 11:51:51 PM »
I protest!!!!
We stump grinders must eat too (and with a 25hp, 65 hp and 105hp grinders it takes alotta feed).
Offline rebocardo
  • Atlanta GA
« Reply #12 on: March 14, 2007, 02:58:05 PM »
You do not have many stumps, I would just rent a stump grinder at Home Depot. Four hours is about $80. You should be able to do all those softwood stumps in three hours if you are in good shape. It takes about 1/2 an hour for a 20 inch stump.
I use to rent from a commercial place and get the big tow behind model that uses teeth instead of a blade (Home Depot). As long as you like a good work out, it is much quicker.
True, but, they would be done in an hour's worth of time, tops. Plus, get much deeper. Winter time is a good time for a deal.
Offline SwampDonkey
  • Large Tooth
« Reply #13 on: March 14, 2007, 03:22:20 PM »
I've never looked into such a thing for rent around here. Don't even know if they are available. Most likely the closest would be Moncton, a 3 hour drive from here. Glad I don't run some of this big harvest equipment. Every time something breaks they all have to head for a 3 hour drive one way for parts. I guess they figure we don't have forests up here. Go to Moncton on that marginal low land and you'd wonder what they could ever cut there in 100 years.  ::) But I digress. Being raised on a farm we just did it ourselves, even if it took more time and was the hard way. At least no one can tax me on my own time. ;D
Move'n on.
Offline D Martin
  • Work is always interfearing with my playtime
« Reply #14 on: March 14, 2007, 04:07:05 PM »
I once heard rocksalt made a stump decay fast, probably like the manure with a drill bit. I'll check back on this thread in a few years to see how you made out
Offline beenthere
« Reply #15 on: March 14, 2007, 05:32:38 PM »
I think of salt as more of a preservative than a decay inducement. Not sure how come I think that....... ::)
Offline SwampDonkey
  • Large Tooth
« Reply #16 on: March 14, 2007, 05:45:14 PM »
Salt might possibly be used to kill a stump. Although, ,my uncle tried it for a few years on a box elder and it just grew faster and greener. ;D
Hmm, 'spose it was Ammonium-Nitrate? ;D  :D
Move'n on.
Offline Kevin
« Reply #17 on: March 14, 2007, 09:01:45 PM »
Be careful cutting large stumps while on your knees.
Lots of cases where the saw kicks back and cuts into the side of the leg.
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #18 on: March 14, 2007, 09:55:43 PM »
Stump + Salt + Porcupine = No Stump  ;) ;D
Offline LT40HDD51
  • WM Sales & Service for N.S., N.B., P.E.I., NFLD., custom sawmilling in Atlantic Canada
    • Valley Custom Lumber
« Reply #19 on: March 15, 2007, 06:43:47 PM »
I heard once about pounding short pieces of copper pipe into the stump to speed the rot up. Dont know if it works, never tried it...
The name's Ian. Been a sawyer for 6 years professionally, Dad bought his first mill in '84, I was 2 years old :). Factory trained service tech. as well... Happy to help any way I can...
Stump Not tree stump remover?
Started by gspren on Ask The Forester
Last post April 29, 2013, 12:56:50 PM
by gspren
stump removal - best way to rot a stump
Started by PB Logging on General Board
Last post October 18, 2018, 09:54:04 AM
by Al_Smith
ERC on the stump
Started by Farm29 on Sawmills and Milling
Last post February 24, 2017, 08:46:50 AM
by Farm29
Stump
Started by Larry on General Board
Last post December 16, 2005, 08:09:07 AM
by Tom
