Author Topic: Woodmizer Accuset  (Read 2369 times)
Offline jdgese
Woodmizer Accuset
« on: May 09, 2007, 01:51:57 PM »
Hello,
 I'm Joel from Spokane. Have been reading this forum for a few weeks now and suprised it
took me so long to find it. I have been sawing for the last 13 years with a little Ripsaw and
recently moved up to an LT 40G28 (2005) with the add-on hydraulic loader. Maybe I should
say moved waaay up! This mill is so awesome by comparison that I'm still in culture shock.
 My question to you so willing to share experts is about the accuset. When I change from
autodown mode to manual mode after a couple of times in the process of sawing a log the saw head will stop moving up and down and I have to shut off the mill and restart to get the
head to move up and down. The message on the screen is "ERROR CHECK MOTOR CIRCUITS". Am I doing something wrong or does it need to be reprogramed?
                    Thanks very much for your help, J. Gese
Offline Bibbyman
    • Warden Sawmill
Re: Woodmizer Accuset
« Reply #1 on: May 09, 2007, 03:05:02 PM »
It's likely there are a couple of parameters that need adjusting in the programming.
Call Wood-Mizer and talk to Rick Leuman a.k.a. Sparks.  (If you follow the instructions when you call in and replay "electrical", they'll likely route you to Sparks.)
He can help you get down inside the programming to fix your problem.
Oh yea....   One other thing.  Welcome to the Forum..   8)
Sawing since '94
Offline Bibbyman
    • Warden Sawmill
« Reply #2 on: May 09, 2007, 05:38:32 PM »
I should probably add
To avoid errors on the Accuset it is important to keep the chain that the up/down motor uses to pull the head up and down at the right tension, clean and oiled.  Its also important to keep the pads on the mast rails clean an oiled.  I think the extra friction keeps the head from reaching the right location to satisfy the Accuset thus it puts out an error and stops working.
Sawing since '94
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
« Reply #3 on: May 10, 2007, 08:17:32 AM »
Since you can shut the key off then back on and it works again I believe there is a setting not programmed correctly. Call me when you are at the mill and I can walk you through the settings over the phone. 1-800-525-8100 ext 1620. If I'm on the phone leave me a number where I can call you back.   Thanks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Offline jdgese
« Reply #4 on: May 10, 2007, 09:38:18 AM »
Thanks  Bibbyman  and Sparks I will be working with the mill on this coming Mon. @Tues.
Will give you a call then if the phone will work up there in the woods.
                                                   Thanks again, JGese
Accuset questions on Woodmizer
Started by woodworker9 on Sawmills and Milling
Last post December 03, 2014, 10:31:18 AM
by woodworker9
Accuset or simple set on a non woodmizer mill
Started by rs1626 on Sawmills and Milling
Last post June 16, 2010, 06:15:13 PM
by Bibbyman
Woodmizer Accuset one parts. SOLD
Started by ShowMeSawyer on For Sale
Last post July 14, 2018, 10:41:14 PM
by stihltoomany
Woodmizer accuset glass cloudy
Started by just_sawing on Sawmills and Milling
Last post July 11, 2007, 06:35:33 AM
by treetech
