Arborwear
Author Topic: Please educate me on bandmill blades.  (Read 4756 times)
Offline flht01
Re: Please educate me on bandmill blades.
« Reply #20 on: June 08, 2007, 04:46:29 PM »
Brad,
I really don't have enough time using the monk's to know just how many bf I'll be getting. I like the way they saw and I've had good results with them after resharpening. I'm on my third resharpen with the two I've used, it'll be interesting to see if I experience breaking them too. One thing I've noticed (using the cat claw setter) is the lack of set in the new monks. I'm going to get a new one out of the box and check it to be sure, but (if  remember right) there was only about 15 thou on the one I checked. *** edit: Just checked a new blade and it averaged 16 thou set. *** I reset them to 21 thou on the first sharpening and they sawed good but were a little rougher. Keep in mind I'm still in the beginning of the learning curve.
Tom,
Thanks for clearing that up. I got two cams with the grinder and the other cam is ground for the cook's super sharp blades. Theres a difference in the looks of the profile for the monks and supersharps even though both are 7/8 pitch. The cook's also looks like it might be ground with less hook, I'll have a better idea after I get a chance to use them.
Bandmill blades
Started by tcsmpsi on Sawmills and Milling
Last post November 11, 2012, 02:37:28 PM
by Magicman
Bandmill Blades
Started by edsaws on Sawmills and Milling
Last post November 13, 2003, 05:05:43 AM
by solidwoods
Bandmill Blades
Started by Tom on Sawmills and Milling
Last post January 13, 2014, 09:23:32 PM
by Mountain Guardian
Bandmill Blades
Started by AnthonyW on Sawmills and Milling
Last post October 27, 2013, 03:58:43 PM
by terrifictimbersllc
