Arborwear
Author Topic: Cant hook, or peavey? (Logrite, of course ;) )  (Read 10950 times)
Offline rebocardo
  • Atlanta GA
Re: Cant hook, or peavey? (Logrite, of course ;) )
« Reply #20 on: October 26, 2007, 12:57:31 AM »
> any experience straightening out a Logrite peavey
Not a peavey, but, other things. You can't straighten it out. When you bend it back from that kind of angle it will be basically work hardened. If you did manage to get it back without cracking, it might break under use.
What I would do is cut 1-2" back from the bend on each side. Then have someone very skilled in MIG welding alumnum, weld it back together first with a sleeve on the inside and then one on the outside.
If you can't find a welder, you could try bolting it. Basically, freeze the bolts, heat the aluminum slightly, and slide the bolts through a camfered slightly undersized hole. Grade 8 x 1/4" bolts should do.
Offline Stan P
  • A bad day in the woods is better than a good day at work.
« Reply #21 on: October 26, 2007, 08:02:23 AM »
I will say customer service for Logrite seems great.  Tammy from the company read my post and offered to replace it if it was damaged during normal use (which I dont think is the case).   Probably wont help me but good for you all to know.
Stan
Offline Frickman
  • Ouch, that hurt!
« Reply #22 on: October 26, 2007, 09:08:29 PM »
The baking at Log-Rite is pretty good too. Tammy makes excellent brownies.  :)
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #23 on: October 27, 2007, 02:02:28 AM »
Well, my Logrite peavey has a bent handle, and it wasn't caused by a vehicle or log running over it. Yep, a normal-weight person can bend a Logrite tool.
A couple of years ago, one of my customer's employees was staging logs for me. He was using my peavey to try to lever a 26" x 32' Douglas-Fir off another pair of logs and couldn't quite get it to the balance point. So he hung onto the end of the handle, lifted his feet onto the log, and starting bouncing with his body completely suspended by the peavey.
When I saw this, I asked him what he thought might happen if the log did finally go past the balance point. That's when he thought about consequences: log rolls onto peavey; peavey crushes his chest; 4000 lb log drops onto his legs. So he decided to move it a different way :D.
I didn't notice the bent handle until the next day >:(.
But that wasn't what I'd call normal usage, and I won't fault Logrite for not making a tool that could stand up to that kind of treatment. Don't matter how tough you make it, there'll always be some DanG fool that can wreck it.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Engineer
« Reply #24 on: October 27, 2007, 12:34:40 PM »
I'd bet anything that you could leave a Logrite tool (or just about anything else, for that matter) in an empty, sealed room with my kids, and at the end of the day whatever you left with them would be broken and mostly disassembled, and one piece would be permanently missing.   ;D
Offline musikwerke
« Reply #25 on: October 27, 2007, 08:43:55 PM »
I have the small mill special, a peavey, cant hook and log carrier - all Logrite.  This Summer I built a one-man log arch and I used the hooks from the log carirer.  What a slick rig if I may say so myself.  I can pick up, off the ground entirely, a softwood log up to 14"X14' and move it to where I can get my tractor or crane truck --- as long as it doesn't have to go uphill.
John
Offline customsawyer
    • The Custom Sawyer
« Reply #26 on: October 28, 2007, 07:51:51 PM »
I have a Logrite peave with a slite bow in it. Hired man like to let it lean up agains the mill frame so he wouldn't have to bend over to pick it up, one day log gets loose from me and I don't have the loader up so big log rolls down and bend peave almost to a U so I took the back-hoe and got the peave braced up on a cant and held it in place with one of the down riggers reach over with the hoe and just pushed it back down, now it is not perfectly strait but it is pretty close and still works like this every day, try that with a wooden handle. ;D
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #27 on: October 28, 2007, 08:39:15 PM »
I've decided that old style peavey handles make good kindling. ;) Or punji sticks for elephant traps.
Dave
Offline LT40HDD51
  • WM Sales & Service for N.S., N.B., P.E.I., NFLD., custom sawmilling in Atlantic Canada
    • Valley Custom Lumber
« Reply #28 on: October 28, 2007, 09:01:55 PM »
We bent one: http://www.forestryforum.com/board/index.php?topic=23106.80  page 5
I stand by it that we didnt abuse it. Logrite got a replacement handle off to us right away  8).
The name's Ian. Been a sawyer for 6 years professionally, Dad bought his first mill in '84, I was 2 years old :). Factory trained service tech. as well... Happy to help any way I can...
Online Dave Shepard
    • My homepage
« Reply #29 on: November 01, 2007, 07:33:25 PM »
I now have a 60" Stihl orange cant hook! 8) 8) I'll be trying it out tomorrow, I can hardly wait. 8) 8) I got a PM from Tamiam late yesterday to confirm the order, and she said she'd ship it out this morning, and it showed up this afternoon, now that's service! :D :D ;)
Dave
« Reply #30 on: November 01, 2007, 07:59:29 PM »
Holy smokes!!  What did you do, go over there and pick it up? :D
Online Dave Shepard
    • My homepage
« Reply #31 on: November 01, 2007, 08:40:42 PM »
I haven't figured it out yet. :D My reply PM cofirming the order was sent at 2:23 pm. :o The 60" hook is a bit taller than the old style peavey I have been using, and I am predicting no flexing of the Logrite handle, I think I need to go find a big log to saw tomorrow. :D
Dave
Offline trapper
« Reply #32 on: November 08, 2007, 01:38:45 PM »
just ordered a hookaroon from baileys for my wife.  she says i pile the firewood for our outdoor furnace too high.  getting the 60 inch canthook for myself.  They have them on sale in their christmas catalog  Logrite of course
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline bandmiller2
« Reply #33 on: December 04, 2007, 05:47:03 AM »
It's called a cant hook for a reason,use it to turn cants.   Humping logs use the peavey or the first one you can get your hands on.Frank C.
Offline stonebroke
« Reply #34 on: December 04, 2007, 09:03:22 AM »
Should you have a cant hook or a peavey with the stand to cut firewood?
Stonebroke
Offline Nate Surveyor
  • If you like work, you will always be happy!
« Reply #35 on: December 04, 2007, 09:41:57 AM »
Thanks guys for the re-direct to this thread, which has all the info I needed.
Cant hook for squared cants
Peavey for logs.
Now, I want to get one too. I have been doing it all with a 42" wood handled cant hook.
Nate :) :)
I know less than I used to.
Online Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #36 on: December 04, 2007, 09:51:40 AM »
sometimes you can use a cant hook to drag a small log, a peavey doesn't work very well for that.
lots of dull bands and chains
Offline treenail
  • I hope to still be wood turning when I'm 90
« Reply #37 on: December 05, 2007, 09:11:12 PM »
I use both Logrite cant hooks (which are pretty darned good) and regular wood handled peaveys around the sawmill.
Norwood Lumbermate 2000 sawmill , Ford 4wd tractor,Grimm/Leader maple sugaring equipment, Ford F-350 12' flatbed truck
Logrite Peavey/Cant Hook
Started by Magicman on Sawmills and Milling
Last post March 18, 2012, 10:20:54 PM
by zopi
Peavey-cant hook ???
Started by Beaudeane on Sawmills and Milling
Last post January 20, 2013, 07:21:17 PM
by SwampDonkey
Cant hook vs. Peavey
Started by ljohnsaw on Sawmills and Milling
Last post November 11, 2012, 08:06:46 AM
by bandmiller2
Cant Hook, vs Peavey
Started by Nate Surveyor on Sawmills and Milling
Last post December 03, 2007, 11:07:10 PM
by Dave Shepard
