Tally-I/O
Author Topic: Purchasing black cherry  (Read 25125 times)
Offline SwampDonkey
  • Large Tooth
Re: Purchasing black cherry
« Reply #60 on: December 20, 2007, 08:37:43 PM »
black cherry then, your my eyes.  ;)
Move'n on.
Offline Furby
  • Blurb....
« Reply #61 on: December 20, 2007, 08:43:39 PM »
First Black Cherry I've ever found that wouldn't split no way, no how! :-\
Course, when I try to get a piece of it to put on a lathe...... it's checked all the way through. ::)
Offline SwampDonkey
  • Large Tooth
« Reply #62 on: December 20, 2007, 08:48:57 PM »
Sounds like the cherry I have. You have some pith in the piece? Firewood.  ::) Some of that cherry I bought from PA doesn't have as distinct growth rings on the flat sawn surface as my local cherry. On my local cherry the rings are as distinct as spruce rings. But mine oxidizes to the red brown color like the stuff I bought.
Move'n on.
Offline Furby
  • Blurb....
« Reply #63 on: December 20, 2007, 08:51:50 PM »
I can get some pith, but not right now, my table saw won't go in far enough.
I need to buck this piece with the chainsaw and then I should be able to get a piece.
Offline SwampDonkey
  • Large Tooth
« Reply #64 on: December 20, 2007, 08:57:06 PM »
I mean the pith and the juvenile wood surrounding it will split to pieces. Avoid it.  ;) I tried some on the lathe and it pulled apart in front of me.
Move'n on.
Offline Furby
  • Blurb....
« Reply #65 on: December 20, 2007, 09:02:18 PM »
Ah yeah, well when it won't split and it's firewood length, it just gets tossed in the pile. ;)
I took the saw to it yesterday and squared it up, but it really isn't useable as it has already checked all over. ::)
Think I've got a nice chunk of spaulted Maple to mess with though. :)
Offline SwampDonkey
  • Large Tooth
« Reply #66 on: December 20, 2007, 09:07:24 PM »
I have 6 or 8 - 6x6" and I have turned and looked them over a dozen times to see if I could buck a turning block out. Nope, no way. Only thing I can do is run some sections through the band saw and maybe slice some 2" stuff out. And I'm not going to put a lot of time into it. I might just need some nice cherry firewood.  ;D ;D
Move'n on.
Offline Furby
  • Blurb....
« Reply #67 on: December 22, 2007, 05:58:18 PM »
Well I milled up the two logs from up at the lake that the scan in reply #40 came from.
No question....... they were Black Cherry. :)
Offline SwampDonkey
  • Large Tooth
« Reply #68 on: December 23, 2007, 07:42:37 AM »
Glad ya solved it. Now what are you are going to make?  ;)
Move'n on.
Offline Furby
  • Blurb....
« Reply #69 on: December 23, 2007, 11:37:27 AM »
No clue! :)
black cherry ?
Started by pitsaw on Sawmills and Milling
Last post April 14, 2011, 07:35:49 AM
by WDH
black cherry
Started by Curtis Koth on Forestry and Logging
Last post December 16, 2002, 08:29:52 AM
by OneWithWood
Black Cherry
Started by Dixiebonsai on Firewood and Wood Heating
Last post September 13, 2015, 09:20:47 PM
by Warped
Pin and Black Cherry
Started by thecfarm on Forestry and Logging
Last post January 24, 2008, 11:23:49 AM
by roger 4400
