Author Topic: log Weight  (Read 1715 times)
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
log Weight
« on: November 27, 2007, 10:12:48 AM »
I am picking up some Douglas Fir damaged telephone poles that I have already trimmed the broken & heavy creosoted parts off. I need to figure how much weight these logs are while I am loading them on my trailer. I have gone to the tool box here and can figure out the weight while in front of the computer. My question, is there a printable table or formula I can use while I am at the site?
Steve
Offline beenthere
Re: log Weight
« Reply #1 on: November 27, 2007, 11:09:03 AM »
Could just figure the volume of the log (length time area) and multiply times the weight per cuft.
Estimate by using the diameter around mid length to account for taper in the pole.
The Wood Handbook will give some values for weight per cu ft.  Doug fir, at 12% is around 35 lbs per cu ft.
Offline Ron Wenrich
Re: log Weight
« Reply #2 on: November 27, 2007, 12:14:35 PM »
I believe the creosote would add some extra weight.
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
Re: log Weight
« Reply #3 on: November 28, 2007, 09:09:11 PM »
I can see everybody busting out laughing at this, but...... Are the poles pretty uniform in diameter?  If so, I would think if you could get a 1 foot long section, maybe about the middle diameter of the poles, and weigh it, you could then measure the length of each pole and multiply that by the weight of your representative 1 foot.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline Stephen1
    • muskoka Sawmill
Re: log Weight
« Reply #4 on: November 28, 2007, 09:17:21 PM »
I like that idea as formulas do not always agree with me. When I built my cabin i used a 12\12 pitch roof, simple, and  it was the only formula I remembered from school.
Can some one give the formula for a round log to figure out volume?
Offline beenthere
Re: log Weight
« Reply #5 on: November 28, 2007, 11:40:48 PM »
Add the area of each end, and divide by 2.  Then multiply that by the length.  If you keep the units right, you will have the volume.
Vehicle weight and towing weight limits
Started by Keith_A on General Board
Last post May 13, 2002, 07:26:52 PM
by Gordon
Over weight much?
Started by Ianab on General Board
Last post June 26, 2012, 10:13:46 AM
by bedway
weight on me
Started by caveman on The Outdoor Board
Last post July 02, 2016, 07:23:53 AM
by petefrom bearswamp
What do you use as weight
Started by TeenSwinger on Drying and Processing
Last post December 17, 2006, 08:43:37 PM
by metalspinner
