Arborwear
Author Topic: Mold on popular boards  (Read 1111 times)
Offline sport500ho
« on: December 02, 2007, 07:56:01 AM »
Hi I got a question I need a little help with. We have a little LT10 and sawed some popular boards and stacked them up in our pole barn. They developed mold on them in a few weeks. They are up off the floor about 10" and had stickers between them but still molded. Should we keep them in an open barn with a roof but one end open for better airflow or something? Thanks for your time
Offline woodmills1
  • the truth shall set you free
Re: Mold on popular boards
« Reply #1 on: December 02, 2007, 08:23:46 AM »
as a test I would plane one or two of the boards to see if there is stain that goes through the boards.  I have had stain/mold on boards that were stacked inside of an open ended building and also when my stack was outside but was too wide.
Offline Qweaver
  • The cabin is done and we love it
« Reply #2 on: December 02, 2007, 09:10:27 AM »
Mold has been a real problem for us also and I've come to the conclusion that it's mainly a factor of how humid it is during the first few weeks of drying.  The summer of 2006 was rainy and almost everything that we cut and stacked in our shed mildewed.  It was a constant fight.  As we used the boards we had to power wash and clorox most of the boards that we were not going to plane.  That's time consuming and costly but we had no choice.  This summer was pretty dry and we had no mildew problems at all.  So short of setting up a kiln, I don't know what to do when conditions favor mold.  I think that using fans to keep fresh air moving across the wood may help.  I did this on some stacks that I had under my house and I had very little mold there.  Some have suggested a light bleach spray before stacking...I have not tried that and can not say if it will help.  It is important to get all of the sawdust off.  I've had no mold when cutting in cold weather either.  So bottom line, cut and stack only during periods of dry or very cold weather.  :D ;D ;)
Welcome to the forum  8)
Quinton
Offline Ron Wenrich
« Reply #3 on: December 02, 2007, 05:01:16 PM »
One problem that some people get into is air flow.  If you have no air flow, your moisture content on the surface will remain high, and that allows for the growth of mold.  We don't get mold very often in piles that are stickered. You must also use dry stickers.
Staining in poplar is another issue.  You have to saw your logs while they are fresh.  Leaving them lie around in hot, humid weather is just the ticket to have the logs start to stain.  Once the stain is started, it is really hard to get rid of.  Logs that are damaged from things like log forks, splits, grapples and loaders will also stain.  Logs that are bucked and not seperated will also stain.   Air flow around the logs also help.
So, you need fresh logs, dry stickers, and good air flow to avoid the staining and mold.
Offline sport500ho
« Reply #4 on: December 09, 2007, 06:42:10 PM »
Thanks everyone for your help!!
No Mold on my Pine Boards
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post September 13, 2013, 06:39:34 PM
by Dave Shepard
mold and degrade on oak boards
Started by paul case on Sawmills and Milling
Last post June 15, 2011, 06:51:55 PM
by tyb525
preventing mold on green oak boards
Last post December 02, 2010, 03:21:39 AM
by weisyboy
Fungus/mold on White Pine boards
Started by rlueth on Sawmills and Milling
Last post February 13, 2018, 05:20:29 PM
by Don P
