Arborwear
Author Topic: 12v motor to raise and lower sawhead  (Read 7118 times)
Offline jrokusek
    • DIY Bandmill
« on: December 10, 2007, 05:42:42 PM »
I've been reading the thread entitled "Power feed plans" and it got me thinking that using a 12v motor to raise and lower the sawhead of my homebrew mill may be a good idea.  I built the mill plenty tall and have it mounted about 6" off the ground.  I stand at 6'1" and have to stretch on my tiptoes to turn the handle to move the head.  It's a shelby-style winch so I have to turn the crank about 20 times to move the head one inch.
Someone please enlighten me as to what I need for a 12v motor.  I was thinking of using a 12v winch with power in and out to raise and lower the head but I don't know if the winch will hold the sawhead in one spot or if it will creep under a load.  So my other idea was to use one of the motors below and connect it to my winch:
http://www.surpluscenter.com/item.asp?UID=2007121016203005&item=5-1566-R&catname=electric
http://www.surpluscenter.com/item.asp?UID=2007121016203005&item=5-1623&catname=electric
Am I on the right track?
Offline submarinesailor
  • LT15 and a wife of 45 yrs
Re: 12v motor to raise and lower sawhead
« Reply #1 on: December 10, 2007, 06:00:42 PM »
Why don't you look at a 12VDC boat winch.  If the heads not too heavy, a boat winch should be able the handle it.
Bruce
Offline mike_van
« Reply #2 on: December 10, 2007, 06:29:51 PM »
The first motor [link] won't work, power window motor just won't have enough snot.  The second one only has 30 inch pounds of torque, I think it's too small too, but to be sure, you'd have to put a torque wrench on the nut where your handle attaches, and see what it takes to move it.  I'm guessing you have 12V at the mill?  Any of the small ATV type winch's would work, I don't think they creep, the planetary drive in them tends to self brake them.
Offline pineywoods
« Reply #3 on: December 10, 2007, 06:57:12 PM »
look for a wheel chair motor. They have a worm-drive gear box built in, won't creep down. Most are 24 volt, but they are beefy and should will work well on 12 volts. Ask around rehab centers and nursing homes.  Junked wheel chairs are pretty common.
Offline Tim L
« Reply #4 on: December 10, 2007, 08:39:20 PM »
Turner uses a run of the mill atv winch
Do the best you can and don't look back
Offline jrokusek
    • DIY Bandmill
« Reply #5 on: December 10, 2007, 09:31:32 PM »
I checked out the Turner Hydraulic Mill and sure enough there's a 12v winch on top of the thing.  If you all think a 12v winch won't creep this may be the easiest thing to do.  I don't have 12v to the mill yet, however I have 2 deep cycle trolling batteries that aren't always used on the boat!  :D  I can't be in 2 places at once so I can steal one of the batteries from the boat and be in business.
Offline bedway
« Reply #6 on: December 11, 2007, 11:38:40 AM »
I agree with what mike said. Find out what torque it takes to move your head up. I put a torque wrench on mine and it read 5 ftlbs to raise mine. I got a 12 volt gearmotor off ebay thats rated for 100 inlbs. Ive got a 16 tooth sprocket and a tarp switch in shipment. When i get things together ill post some results.,,,,,,,,bedway
Offline StorminN
« Reply #7 on: December 12, 2007, 08:21:30 AM »
The electric wheelchair and scooter motors are very handy, and strong. Like pineywoods said, they are mostly worm gear and therefore won't creep. They are also mostly 24VDC... I've used them as 12V in a pinch and they seem to work just fine, but 1/2 the speed.
As far as strength, here's a pic of the Rascal Scooter motor I'm using as a lift motor on my Mobile Dimension mill... I'm not positive what my mill weighs, but between the VW motor, carriage, and truss, I figure this little electric motor is raising 1,000+ lbs. I got the broken scooter for free, so my total investment here was $4 for the correct chain sprocket from Surplus Center... I believe this one was a 3/4" shaft, to give you an idea of its size.
I've also got a couple of wheelchair motors that I'm using to move my sawdust conveyors. These are totally overkill, I could go with smaller motors... but again, these motors were free, so who am I to complain? I believe these were 5/8" output shaft.
-Norm.
Happiness... is a sharp saw.
Offline mike_van
« Reply #8 on: December 12, 2007, 10:01:38 AM »
Just a thought I had on using the cable/winch setup - Check those cables often, especially the imports from you know where - The little 1/8 or 3/16 don't have many strands to begin with, and if it [the cable] fails, that heads coming down - As opposed to the Acme thread type, if the chain breaks, it just sits there.
Raise and lower sawhead chain size?
Started by Kwill on Sawmills and Milling
Last post April 09, 2018, 02:55:51 PM
by york
Engine cuts out, trying to raise sawhead
Started by RENOV8R on Sawmills and Milling
Last post June 07, 2011, 08:46:35 PM
by Tom
Easier way to raise and lower saw head
Started by shortlogger on Sawmills and Milling
Last post July 11, 2013, 01:23:33 AM
by redbeard
Can or should Hydraulic cylinder's be used to raise/lower saw head?
Started by GAmillworker on Sawmills and Milling
Last post July 15, 2011, 12:19:34 PM
by Log-ic
