Arborwear
Author Topic: Points gap  (Read 4976 times)
Offline Faron
Points gap
« on: February 02, 2008, 08:02:48 AM »
Does anyone know what the proper gap is for points  on a  ford 300 6 cyl engine?Burning propane if that makes a diference.
Democracy is two wolves and a lamb voting on what to have for dinner.  Liberty is a well armed lamb contesting the vote. - Ben Franklin
Offline Burlkraft
  • Professional survivor......Still a wooodturner
Re: Points gap
« Reply #1 on: February 02, 2008, 08:12:52 AM »
.030....If I remember right. Been a LONG time since I installed a set of points  ::)  ::)  ::)
Why not just 1 pain free day?
Offline Faron
Re: Points gap
« Reply #2 on: February 02, 2008, 08:59:38 AM »
Thanks, Burlkraft.  Been meaning to get an electronic deal to put in there.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Points gap
« Reply #3 on: February 02, 2008, 09:45:32 AM »
 30 on points  :o :o  Seems a bit much, no ???   But, then, it IS a ferd.
  I'm thinkin more like 16-20 ,EH ???  ;D ;D :D :D
  Wadda I know  ::) ::) ::)
Offline sawguy21
Re: Points gap
« Reply #4 on: February 02, 2008, 10:38:22 AM »
I would suggest .020, that seems a good starting point for most 4 cycle engines. .015 will get most 2 strokes started. I think I can still remember how to do it. ;D
Offline logwalker
  • Got Logs??
Re: Points gap
« Reply #5 on: February 02, 2008, 11:27:45 AM »
In a pinch you can use a matchbook cover. It gives about .015" as a result. One thing we miss when setting points is that it directly effects the timing of the engine. A wider gap advances the timing I think. If you have a dwell meter that is the best. Set the points to 15 and then start it and set again to the proper dwell. Points also close as they wear the little rubber. Setting them a little bit wide gives longer lasting results.
But if you have a timing light use it last to reset the timing.  Joe
Offline Burlkraft
Re: Points gap
« Reply #6 on: February 02, 2008, 04:28:44 PM »
Propane....
Offline mike_van
Re: Points gap
« Reply #7 on: February 02, 2008, 04:42:29 PM »
I'd set 15 or 20 thou, 30 is more a plug gap.
Offline rebocardo
  • Atlanta GA
Re: Points gap
« Reply #8 on: February 02, 2008, 05:18:20 PM »
For a 1973 300 I-6
plug = brf-42b
gap=.035
dwell = 33-39
point gap = .027
timing = 10 degrees btdc
idle = 600 manual, 550 automatic
Offline Slabs
  • It don't get no better than flyin' sawdust
Re: Points gap
« Reply #9 on: February 02, 2008, 07:48:28 PM »
I was gonna vote .015 - .016.  On older engines especially if they're running constant speed a few thousandths probably won't make much difference.
If you're serious about a solid state unit, Google up " PERTRONIX".  We found a distrubutor for an old Clark fork lift from them.  Probably $250 range.
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.  Woodshop, metal woorking shop and electronics shop.
Offline olyman
Re: Points gap
« Reply #10 on: February 02, 2008, 08:52:02 PM »
cant remember the year-----but go get the electronic setup in a later ford pickup---distributor,wiring,and control box-------------only two wires on the silver electronic module--red and white--and the red hooks to key hot------and can get parts anywhere----- ;D ;D
How do you set points?
Started by Mac 6-10 on Chainsaws
Last post November 13, 2013, 01:16:17 PM
by Al_Smith
Some good points here
Started by ladylake on Sawmills and Milling
Last post May 24, 2016, 04:41:05 PM
by ladylake
Stihl 031 points
Started by bandmiller2 on Chainsaws
Last post January 30, 2009, 02:24:32 PM
by bandmiller2
Setting Points Gap
Started by AdkStihl on Chainsaws
Last post January 27, 2014, 10:23:12 AM
by AdkStihl
