Author Topic: wood fired hot waterheater  (Read 3685 times)
Offline mad dog
« on: March 13, 2008, 09:07:19 AM »
        Does  anyone still make a wood fired hot water heater for home use? Or a wood stove with a water jacket?
mad dog 78 acres,pasqualli tractor,L-15 woodmiser
Offline StorminN
Re: wood fired hot waterheater
« Reply #1 on: March 13, 2008, 12:05:18 PM »
mad dog,
I'm not sure about here in the US, but where my Dad retired to in southern Mexico, wood-fired hot water heaters are still very common... any plumbing store will have a couple of different models. I have pictures somewhere, I will try and find and post them...
-N.
Happiness... is a sharp saw.
Offline sawdust
    • Dream Dovetail Co.
« Reply #2 on: March 13, 2008, 03:31:20 PM »
mad Dog, have a look in my images there are a few photos on the one I built. Actually I had built for me I used bout a dozen of these things over the years.
sawdust
edit... sorry maddog my brain was thinking hot tub heater. You are talking domestic hot water.
comforting the afflicted and afflicting the comfortable.
Offline jpgreen
  • My Boy- Snoopy Dogbone Green
« Reply #3 on: March 16, 2008, 01:09:12 PM »
I've built them and will be building them to offer for sale come next winter, and maybe this summer for the outdoor models, but depends on how buys I get with other stuff..  8)
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
Offline RSteiner
  • God is good, all the time.
« Reply #4 on: March 16, 2008, 08:52:29 PM »
A number of years ago I purchased a wood stove that had a hot water heating coil in the fire box.  It worked pretty good when the stove was used in the winter for heating the house.  I moved the hot water tank close to the stove so I wouldn't need a pump to circulate the water.  The original coil was mild steel so it lasted about 10 years before the creosote ate a hole in it.  I was given a stainless steel coil but never installed it.  With the kids out of the house we would have too much hot water.
When the kids were home in the morning we would have a 40 gallon tank full of
180 F hot water.  This was enough for the 5 of us to take quick showers before getting to cool.
Randy
Randy
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #5 on: March 17, 2008, 10:30:17 AM »
I've got a swedish aguatherm heater kicking around.  Brand spanking new but 30+ years old!  I once filled it up with water and lit a little fire to see how quick it got hot.  Had steam and water gushing all over the shop!
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #6 on: March 17, 2008, 03:35:21 PM »
 These are easy to build. I used a used GAS waterheater tank, and cut the center out of 2 car wheels. Put a bottom in one wheel, welded it to the other, for a firebox, cut an opening for a door, and fabbed a door.
   Used TWIGS and cereal boxes to get a fire going. ONE fill of that small firebox, would supply hot water for the 4 of us, + a baby. Never had a problem, then built the water heater over the Propane tank woodstove, and gave the wood fired heater to our STOOPID neighbor. He blew the crapper out from under him one cold morning, with hot water going into the ceramic crapper tank.  ::) ::) ::) ::) ::) :D :D :D :D :D :D :D :D
Offline RSteiner
« Reply #7 on: March 18, 2008, 06:18:19 AM »
Now, there is where a picture would be worth a thousand words !  :D
I installed two high temp./ pressure blow-off valves on my system, one on the outlet of the coil at the back of the stove and the other on the top of the hot water tank.  Many times with a good fire going the blow-off valve at the back of the stove would go off, I ran a hose from it to the sink in the cellar to avoid a flood of water on the floor.
Randy
Randy
Wood fired dehydrator
Started by Paul_H on Alternative methods and solutions
Last post October 12, 2015, 12:35:47 PM
by Paul_H
wood-fired kiln
Started by brdmkr on Drying and Processing
Last post July 03, 2005, 08:32:38 AM
by sawmillsi
Wood fired dry kiln
Started by Eljay on Drying and Processing
Last post January 21, 2011, 07:17:04 PM
by Troublermaker
Wood Fired Kiln
Started by Todd on Drying and Processing
Last post September 12, 2005, 08:26:49 AM
by Todd
