EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: MS170 Oil Leak  (Read 4871 times)
Offline woodfirst
MS170 Oil Leak
« on: March 28, 2008, 08:52:41 PM »
I have a relatively new MS170 that has a slow oil leak somewhere from the bar reservoir.  I can't seem to find where it is coming from as the bottom is a sticky mess.  Has anyone else run into this?
Offline Kevin
Re: MS170 Oil Leak
« Reply #1 on: March 28, 2008, 10:08:06 PM »
Welcome to the forum woodfirst .
Is the saw under warranty, can you take it back to the dealer?
First thing to check is the bar to make sure it isn't filled with sawdust that's preventing the oil from entering the hole in the bar and getting into the bar groove.
Offline joe_indi
  • The older I get the more I learn
Re: MS170 Oil Leak
« Reply #2 on: March 29, 2008, 04:57:01 AM »
You will need to clean out the 'sticky mess' to solve the problem.
Once the bottom is cleaned out, if you look under the handlebar you should see a small tube connecting the oil tank to the oil pump.The oil leak occurs usually at the ends of the tube where it is connected.
If the saw is new, chances are that the debris buildup has dislodged the tube a little bit.
You will have to pull this tube out, clean both ends, and also where its connected on the saw.
A bit of liquid gasket applied to the ends will give an additional seal to prevent future leaks.
However, you will need to remove the handle to do all this.
If you dont know how, a shop should be able to do it for you.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: MS170 Oil Leak
« Reply #3 on: March 31, 2008, 07:52:55 AM »
There is a rubber plug beside the muffler and the chain guard. It is where they drilled the oil passage. Sometimes I have seen these missing. There is not a part # for this plug.  ???
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
MS170 will not idle
Started by Newbie on Chainsaws
Last post June 02, 2010, 11:47:08 AM
by sablatnic
For Sale two ms460's and a ms170
Started by ohiowoodchuck on For Sale
Last post October 10, 2017, 07:44:13 PM
by ohiowoodchuck
More Problems With My Stihl MS170
Started by Bigfoot870 on Chainsaws
Last post November 02, 2016, 08:48:47 AM
by Bigfoot870
Mod MS170 to bar side adjuster
Started by rick carpenter on Chainsaws
Last post February 28, 2016, 06:24:29 PM
by rick carpenter
