Arborwear
Author Topic: overhang on gable ends  (Read 14936 times)
Offline sbishop
« on: June 11, 2008, 06:22:29 PM »
I would like to have 2ft of overhang on my gable ends to keep the rain/snow away from the cabin walls. Can i do 2ft of overhang with just the boards of the roof? or would it need support?
Sbishop
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: overhang on gable ends
« Reply #1 on: June 11, 2008, 07:17:54 PM »
Depends, on a lot of things, like roof snow load and the thickness of the boards.....
Offline sbishop
« Reply #2 on: June 11, 2008, 07:42:26 PM »
Jim, here's more details
roof will be a 8/12 pitch, boards will 1" t&g and oh ya....lots of snow here  ;D
Sbishop
Offline shinnlinger
« Reply #3 on: June 11, 2008, 10:12:31 PM »
Sbishop,
There was a thread here a while back on if you have rafters every few feet you can push it a bit and have you boards overhang horizonatly, but 2 ft is a bit much w/out returns
I used purlins and I have 3 foot of overhang for my straw bales.  What I did is put pockets in both sides of the rafter (8x10) with a 1.5"deep dado running between the pockets.  I then  notched the purlins (6x7)so that they ran in the dado but shouldered out in the pockets.
It is at this point so far.  I plan to hang a 2x10 "barge rafter"  Some might call it a a fascia board to connect all the purlin ends toogether running up the rake.  I hope that all of the purlins acting iin concert will handle the load.  I may need to run a return back to the bale walls, which will obvously be easier if you have a more conventional wall.
I cant vouch for the longevity of this design but it appears sound to this point.  My computer has been down for a bit and my photo edit software is AWOL, but I will try to get some pics here soon if you want.
Shinnlinger
Offline sbishop
« Reply #4 on: June 12, 2008, 05:56:42 AM »
I am planning on using 2x8 (rough) for common rafters. if 2ft is too much wihout support maybe i can extend the last row of logs on my walls so i can put a rafter on the outside the rear gable end...the front has a covered porch so there will be support
Offline Don P
    • Calculator Index
« Reply #5 on: June 12, 2008, 06:56:25 AM »
 18" is the limit for 2" thick t&g in the tables I checked here, and it had load limits based on species and grade.
I think you'll be happier with a barge/verge/fly/fascia board at the outboard end of the boards supported from either below or above. I usually frame a "ladder" over the wall with blocking framed every 2' perependicular between the fly and the first inboard common rafter.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #6 on: June 12, 2008, 09:38:23 AM »
One of my drawing programs automatically puts in framing based on the user's input. Here is a shot of a simple 8/12 roof with 2' over hang and 2x8 rafters 24" oc with the ladder which DonP has mentioned.
This program puts the ladder pieces in flat, and I'm not sure if that's the way it's done or if they are vertical. But this type of ladder assembly will help support large gable overhangs.
Offline sbishop
« Reply #7 on: June 12, 2008, 01:49:01 PM »
Jim, i've seen that setup in the books i have..i'll look at it tonight. Also i'm not sure if they are supposet to be flat or vertical!
Steve
Offline Radar67
  • Cuttin Wood Now For My House Later.
    • Stewart Photography
« Reply #8 on: June 12, 2008, 01:51:27 PM »
Everyone I've installed or seen installed has been flat. Too much wood cut out of the rafter decreases it's strength.
Offline shinnlinger
« Reply #9 on: June 12, 2008, 04:03:55 PM »
I left most of the meat in my rafters (only took 1.5" when I hogged out for the purlins, but if I was doing it again I might take more from the rafter and leave more in the purlin.  My thought on this is that you can support an end gable with a post or two or a window buck or something pretty easily and of course end rafters only get half the load.
Shinnlinger
Offline Don P
    • Calculator Index
« Reply #10 on: June 12, 2008, 06:57:31 PM »
I've done many flat ways ladders, it works in light snow country, if the load or if wind load is heavy or as the overhang increases they need to go up on edge. As the overhang increases you should think about cantilevering the blocking inboard further (2/3 of the ladder blocking inboard, 1/3 hanging out) and doubling up the rafter you tie the blocks to inside. You can check the ladder lumber in flat ways or edgewise bending for the span of the cantilever.
Offline Joel Eisner
  • Building my own house using timbers from the land seemed like a good idea at the time!
    • Boothe Mountain Retreat
« Reply #11 on: June 12, 2008, 09:33:11 PM »
We placed 4 ft gable end overhangs on our timberframe.  We used 4x6 timber roof brackets and they look great.  You can place 2x6 rafters on them.  They lined up with the fake rafter tails we applied to the eaves.
The saga of our timberframe experience continues at boothemountain.blogspot.com.
Offline sbishop
« Reply #12 on: June 23, 2008, 08:09:26 AM »
Thanks guys for all the responses, i think i will be framing it like Jim_rogers post.
Gable overhang Question, or how much overhang can I support with brackets
Started by mmhailey on Timber Framing/Log construction
Last post September 02, 2010, 08:58:11 PM
by Jasperfield
Suggestions for framing the gable overhang.
Last post October 28, 2011, 10:35:40 AM
by ballen
Rafter with overhang
Started by purple otter on Timber Framing/Log construction
Last post June 24, 2011, 05:41:16 PM
by Jim_Rogers
Doors on gable end or drip side
Started by brendonv on Timber Framing/Log construction
Last post July 09, 2016, 06:11:31 PM
by Dave Shepard
