Arborwear
Author Topic: Cutoff saw for slab wood?  (Read 23086 times)
Offline Ron Wenrich
Re: Cutoff saw for slab wood?
« Reply #20 on: August 03, 2008, 06:33:15 AM »
We always called them a swing saw.  The old ones had a handle on the side and you just pulled it to cut slabs or board ends.  Weights would always keep it back out of the way.
You can buy a used newer model for $1-2000 with power.  I saw one that was a little more expensive with live infeed and outfeed.
Offline bandmiller2
« Reply #21 on: August 03, 2008, 06:47:58 AM »
Have any of you guys built a shear to cut slab ,if you have hydraulics no big deal ,no teeth to sharpen and their quiet.Frank C.
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #22 on: August 03, 2008, 09:42:00 AM »
I have a cornell slabsaw that works just like the one in the video link that Ron put on here. All these other saws require an operator. The cornell saw does not. You throw the slab in the trough and walk away. You can run your mill and cut the slabs at the same time. The only drawback is you need 3 phase power to run it. I have not used my slabsaw since I put a mulch grinder inline 5 years ago. I put the slabsaw in a barn and would like to clean the barn out for other uses.  The saw blade on my slabsaw is a carbide blade but I also have an inserted tooth blade that used the same teeth as my headsaw. Before I had the slabsaw we used a set of rollers and a block of wood for a stop and a man with a chainsaw and a rubber belt conveyor to carry away and stack the cut slabs . That worked ok but would never be able to keep up with the volume I saw today. As for the cornell slabsaw I out grew that too. The mulch grinder was the best thing I put in to get rid of all the waste. The problem I had with slab wood was that people would come in pick through the slabs make a mess while there kids ran playing over my log piles. I got rid of that liability when I got rid of the slab wood and now I sell everything instead of having a big pile of junk wood spread all over the place in the spring.
« Reply #23 on: August 03, 2008, 12:16:45 PM »
I think that it was in Moultrie that I saw a rig a fellow was trying to sell as a firewood saw.  It was still looking kind of home-made but he was proud of it.   He had a roller table set up with a bit of a frame on one end.  On this frame, he had attached a relatively small chainsaw.  It was hooked on there by the tip of its bar and was eithr spring loaded or cantelevered such that, when he turned it loose, the engine would swing to the top of an arc.
He would put a slab or small log on the roller bed and feed it off of the end. When it was the right length, he had stops out there, he would reach up and get the handle of the chainsaw, rev it up and pull the engine down through the slab or small log.  Yep, He had invented the "Chop Saw".  :D   But it worked.  :)
Offline cheyenne
« Reply #24 on: August 27, 2008, 08:19:19 PM »
 check out baileys they have what they call the smart holder for firewood for $100 bucks and it's the slickest tool i have. load it up with slabs, chop with chain saw. works great and it folds up for storage
Home of the white buffalo
Offline jpgreen
  • My Boy- Snoopy Dogbone Green
« Reply #25 on: August 27, 2008, 11:17:01 PM »
I've been wanting to build one of these.  Even one that I could cut chunks of wood fast that could be use to fuel a wood gasser.
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
Offline jpgreen
« Reply #26 on: August 27, 2008, 11:28:34 PM »
Offline beenthere
« Reply #27 on: August 28, 2008, 12:03:21 AM »
Interesting cut-off saw and splitter. At the speed shown in the video, the guy is going to freeze to death waiting for it to buck the log, and split the piece. Looks entirely too weak in the knees to last very long.
But interesting just the same, and glad you posted it.
Curious about the wood shear...as slicing across the grain of wood, as in a slab or a log, takes a lot of power and a pretty sharp, strong blade. There are some log shears out there, but thinking they work just for some of the softwoods.
Offline jpgreen
« Reply #28 on: August 28, 2008, 12:10:51 AM »
I couldn't get those videos to play, but from the size they looked kind of slow. A guy can always built up on power.
On the shear- I've been thinking more of a guitine(sp) as in french with a big heavy head cuttin' off type blade.  Pure mass would slice through small daimeter logs and branches like butter for making chunk wood blocks for a wood gassifier.
Do think one for firewood logs would definitly have to be beefy.
Offline StorminN
« Reply #29 on: August 28, 2008, 04:24:37 AM »
If I had the money, I think I'd get one of those Chomper firewood processors... it's a shear-based one... if you haven't seen it, check it out... very impressive.
For now, the direction I'm going with this cutoff saw is I've mounted a chain bar to an old electric chop saw head. It's a complete rough draft, just something I slapped together in a 1/2 hour... I wanted to see if the chop saw motor would be strong enough to pull the chain, and it is. I'll post some pics tomorrow...
-Norm.
Happiness... is a sharp saw.
Offline bandmiller2
« Reply #30 on: August 28, 2008, 06:54:53 AM »
Have any of you guys noticed the shear junk dealers use to cut long pieces to #1,its just a massive cast iron shear that runs constantly you feed into it.Have a belt feeding it at the right speed and let her go you'd have some a little shorter than the outhers. Frank C.
Offline jpgreen
« Reply #31 on: August 28, 2008, 09:41:11 AM »
Where can I see a pic of one of these, or what would they call that?  This is what I need to make chunks.
When you say "cut long pieces to #1",  what is #1? Rebar?
The only thing I've been able to find like this is a Laimet screw auger chipper and they are $20,000.
Offline jpgreen
« Reply #32 on: August 28, 2008, 09:42:18 AM »
-Norm.
Sounds great...  8)
Offline StorminN
« Reply #33 on: August 28, 2008, 03:38:24 PM »
Here's the video page for the Chomper...
Chomper video page
Here's a pic of the "rough draft" of what I've got going... this was just a quick & dirty check to see if the motor was strong enough to spin the chain well... (it did). I'm going to remove the handle and bolt another arm on the other side (left side of pic)... again, this was just a test.
-Norm.
Offline bandmiller2
« Reply #34 on: August 29, 2008, 07:34:58 AM »
JP,what I was refering to is #1 prepared steel i believe thats under 4'.I don't know the proper name every junk yard around here has at least one.Stop by any old junk yard and ask,mayby bring a slab or two and try it.I have never seen a new one probibly OSHA put them out of business.Frank C.
Offline redprospector
« Reply #35 on: August 29, 2008, 11:08:18 PM »
-Norm.
Norm,
I've got a 14" Chomper. The only thing it realy dosen't like is old dry brittle wood, just kinda shatters it (makes good kindling though  :D). The shear could be made pretty easily for chomping up slabs. Most wood will shear cross grain a lot easier than people think.
Andy
Offline gizmodust
« Reply #36 on: September 01, 2008, 06:45:11 PM »
I built one of these last fall, before Baileys offered it.  Difference is mine will take 2 12 slabs at a time.  If you're man enough to put it in, it'll hold it.  When I saw the one in Baileys, I snickered to myself.  A lot of good ideas coming in though.  It might take a bit to wrangle out the best one.
Always liked wood with alot of character
Offline cheyenne
« Reply #37 on: September 01, 2008, 11:21:13 PM »
BUT YOU AND I BOTH KNOW IT'S BETTER THAN SPENDING $ 5,000 GRAND OR BETTER.
Offline jpgreen
« Reply #38 on: September 01, 2008, 11:51:12 PM »
Can you post a pic of your holder?
Offline cheyenne
« Reply #39 on: September 02, 2008, 12:12:20 AM »
go to baileysonline.com
Cutoff Saw
Started by Skidder on Sawmills and Milling
Last post June 18, 2005, 02:39:49 PM
by Skidder
Slab wood
Started by Bruno of NH on Sawmills and Milling
Last post September 19, 2014, 01:34:27 PM
by Larry
What to do with your slab wood........
Started by Robert Long on Sawmills and Milling
Last post February 10, 2007, 06:03:11 PM
by mike_van
Slab Wood uses
Started by ATLGA on Sawmills and Milling
Last post June 26, 2011, 11:17:07 AM
by doghunter
