KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: M14 Foley Belsaw Sawmill  (Read 32968 times)
Offline first shirt
« on: August 05, 2008, 07:40:56 AM »
I recently assembled a M14 Foley Belsaw Sawmill with a direct drive PTO shaft.  My question is, will my Massey Ferguson 135 tractor be sufficient power for my mill?
Offline bandmiller2
Re: M14 Foley Belsaw Sawmill
« Reply #1 on: August 05, 2008, 09:48:31 AM »
First shirt,what size headsaw do you have,inserted or solid tooth??Normal sized logs ,bits kept sharp you should be ok.Much larger than the standard 40" blade in larger oak you will be wanting for power.If I recall belsaw claimed 35hp will do it.A light power plant keeps you honest with your saw maintenance.Frank C.
Offline Don P
    • Calculator Index
« Reply #2 on: August 05, 2008, 10:58:38 AM »
 :D That's a fact.
I'm running a 46" insert tooth blade on an old MF TO-35 in mine. I put a ground down tooth in every other slot and am underpowered but can make wood for my hobbies. I've given up on sawing locust but did recently make it through a large white oak sawing 16/4 x 12" stair treads with some grunting. That is the bare minimum, it will saw, you won't be dangerously overpowered  ;D
Offline HOGFARMER
  • Farming feeds the world.
« Reply #3 on: August 06, 2008, 09:50:03 PM »
I am also redoing a Foley Belsaw M-14 sawmill.  Recently I purchased an instillation and operating manual from Timberking for this mill.  In it was stated that on smaller diameter softwoods 25 horsepower would do the job.  On larger diameter high moisture hardwoods you could need up to 65 horsepower.  What type of foundation did you use for the mill?  Thanks!
Manual LT-30
Offline first shirt
« Reply #4 on: August 09, 2008, 09:01:12 AM »
I used concrete pillars, I am  still trying to fine tune everything.  One of my belts continues to run off the pulley i might have to buy a smaller belt or use a belt tensionor of some type.  Otherwise I am looking forward to milling some lumber, I have about 144 acres of oak, poplar and pine.
Offline bandmiller2
« Reply #5 on: August 13, 2008, 05:50:59 AM »
First shirt,seeing as your direct drive to your arbor,the belt that keeps coming off must be on the feed assy.Many times if the idler that pivits down on the belt to tighten it is not straight and level it will let the belt run out of its pulley.Check the alignment of boath the feed and gigback.Are the belts old worn or twisted??Frank C.
Offline woodhaven
  • Circular Saw Diehard
« Reply #6 on: August 13, 2008, 08:27:37 PM »
It's good to see all you guys rebuilding M14's or any other type of
circular mill. When I built mine I knew nothing about sawmills except
that I wanted one. I called Foley and ask what size tires and rims
the M14 had. From that I could figure what size everything else was.
I needed to know exactly what size something in the picture was and I
could figure anything. I still do that today. When I wan't to build something
I will call the mfg. and get the exact size of something in there picture and
 I can figure the rest.
Richard
Offline pierre
« Reply #7 on: October 02, 2008, 02:07:00 PM »
I run my m14 sawmill with a inter b-250, but i am not sure that i could saw some 20 feet logs. Its always full throttle.
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #8 on: October 06, 2008, 12:04:47 PM »
Gday
I ran my tabletop mill of a 135 mf for about 6 months on pine when i first built it 10 yrs ago . it was a bit light on for hp but did the job well ;) ;D runing a 36 dia 20 tooth insert saw . it was dang good on fuel tho  ;) ;D :D :D :D
now i run with a 44" 38 tooth insert with 80 hp it dose it easy  8) 8)
Chris
4TH Generation Timbergetter
Offline Joe Lallande
  • Belsaw M-14 powered by Oliver Super188D
« Reply #9 on: November 11, 2008, 07:39:13 PM »
I have the same mill and want to convert the flat belt drive to a pto shaft, any ideas? Joe Lallande at Howling Wolf Sawmill located in Alpena, MI.
Offline HOGFARMER
« Reply #10 on: November 12, 2008, 07:11:19 AM »
On my M-14 the PTO shaft hooks to the arbor shaft that the blade is mounted on.  You should be able to get it thru any farm machinery dealer if Timberking no longer offers it.  The original used shear pins to protect things.
Manual LT-30
Offline bandmiller2
« Reply #11 on: November 14, 2008, 07:32:20 AM »
Hogfarmer,do you have your foundation in yet??Winter is bearing down on us ground will get tight soon.Probibly 8 or so sono tubes filled with concrete to above ground level large bolt in each.Bolt down one of your 6x6 pt across and longer one legnthwise on top for stability bolt the metal legs to it .Belsaw is probibly the easiest mill to set up I've seen them just set on blocks and cut good lumber.Keep us posted Frank C.
Offline timberjackpa
« Reply #12 on: January 03, 2009, 07:53:10 AM »
first shirt                     I just bought a belsaw and was wondering what is the best way to use the direct pto shaft since the tractor shaft is clockwise and the blade shaft runs counter clockwise.   any information would be greatly apreciated
« Reply #13 on: January 03, 2009, 08:11:23 AM »
Gday
Timberjackpa Welcome to the forum mate  ;D ;D 8) pull up a pack for a spell there are plenty of Top Blokes and good advice to be had here on the forum  ;) ;D
With your mill is it a Left or right hand mill  ??? if your not sure an easy wat to tell is to stand facing the front of the saw in the operators position if the carriage is on your right side its a RH mil or left its a LH mill  ;) a right hander is easy just fit a pto slip clutch onto the end of the shaft hook your pto shaft to the tractor and away you go mate
 ifin its a left hand mill .Which Im thinking yours is  ??? :P you will either have to sett up a counter shaft with pulleys and a slip clutch which will come back out on the operating side of the mill  ;) ;D
Reguards Chris McMahon
Offline bandmiller2
« Reply #14 on: January 03, 2009, 10:18:59 AM »
I may be mistaken but I think all belsaw mills are right handed.The tractor is located on the back side of the mill so it works out right with a tractor pto.That leaves nothing in your way on the sawyers side, thats why its touted as a one man mill,you can cut and offbear easily.As per directions you build a modest table around the blade to hold the boards and for safety reasons.Frank C.
Offline SCSawyer
  • If Your Not Sawing Your Wasting Time.
« Reply #15 on: January 03, 2009, 06:29:40 PM »
Hello,
I had a saw something like a bell saw that was called a utilizer mill that ran off the pto that I pulled with my 330 international that is 34.5 hp it would open the gov. but as long as you didnt swing on the stick like a raped ape it did well and this is a gas engine.
Silas S. Roberts , Bluff Mtn. Timber
« Reply #16 on: January 03, 2009, 11:36:20 PM »
hello there..   thank you for the fast responses, and warm welcomes!  I can't get any info from anybody in my area. If i stand in front of the blade, the blade turns towards me at the carriage fowarder and reverser lever (operator station), and mill tracks are on the right of me. Meaning I have a right hand mill, right? the blade shaft has to turn counter clockwise.  Although the (flat) belt that runs from the blade shaft to the carriage shaft has a twist in it, meaning it has to run clockwise, could my tractor pto shaft power the smaller carriage shaft to run the big blade shaft? I just want to avoid having to buy a big flatbelt pto pulley and 70 ft. of flatbelt if I don't have to. I hate to pump you full of questions but I have one more question for you. If I do have to use a flatbelt, will a Balers flatbelt be strong enough for it? I found some at Tractor Supply Co. Thank you for your help, Tony.
« Reply #17 on: January 04, 2009, 05:57:46 AM »
Gday Tony
it sounds like you got a std Rh belsaw mill  ;) but Im a lill perplexed mate  ??? ??? :P you should be able to just hook the pto strait up to the end of the saw mandrel with out any dramas  ;) ;D Hmmm would you be able get some pics so we can see what we are looking at mate  ;) even just email them to me at heartlandtimber@aapt.net.au we will get this sawted out for you mate  ;) :D ;D
Reguards Chris
Offline bandmiller2
« Reply #18 on: January 04, 2009, 08:03:25 AM »
TJ,you have a right hand mill.Forget all about pulleys and flat belts if your going to run your belsaw from a tractor PTO.What you need is a direct shaft from the pto to the arbor at the back of the mill.That shaft should have ether a shear pin,slip clutch or boath.belsaw sold a drive shaft for that purpose.Some farm impliments use about the same thing and a shaft can be made up by most tractor dealerships.Usally your blade [headsaw] is tensioned [hammered] for 550 rpm to match the standard pto speed. Frank C. don't worry about too many questions.where ar you located?
« Reply #19 on: January 04, 2009, 08:51:24 AM »
Gday
Like you Frank im thinking it should be ready to rumble as is with just the addition of the pto shaft na slip clutch  ;) ;D but sawmillers being sawmillers  ;) :D she migh have been modified for another powerplant  :) Being a Rh it should bee quick and simple ;) ;D
Chris
Need a saw guide for a Foley Belsaw M-14 sawmill
Started by bobbydc on Sawmills and Milling
Last post October 28, 2010, 11:06:45 AM
by bobbydc
Foley belsaw m14
Started by michiganmilkman on Wanted
Last post February 14, 2016, 01:47:10 PM
by thecol
foley belsaw
Started by beav39 on General Board
Last post March 29, 2009, 08:40:28 PM
by rpg52
Foley's M-14 Belsaw - Could use a little help
Started by oklalogdog on Sawmills and Milling
Last post June 03, 2011, 02:30:38 PM
by captain_crunch
