Arborwear
Author Topic: Garwood winch  (Read 33403 times)
Offline dancan
Re: Garwood winch
« Reply #20 on: September 16, 2008, 04:12:26 AM »
It's the load/tension thing that made me wonder , how was tension released in it's original application ?
pto's on most truck trannys are reversible.
Offline Larry
Re: Garwood winch
« Reply #21 on: September 16, 2008, 07:33:05 AM »
pineywoods, I agree with everything you said about using a hydraulic motor...only problem I was never smart nuff to figure out what size it would take.
moderate sized hydraulic
Could you point me to the right size motor to use on my 30,000 pound Garwood?  Does Surplus Center sell a motor that would work?  I think it would be an easy and worth while conversion for me to make.
Larry
Nine out of ten trees recommend wood for your building project.
Offline pineywoods
Re: Garwood winch
« Reply #22 on: September 16, 2008, 08:49:16 PM »
Surplus center would definitely have anything you need.  If you can get your hands on one of their catalogs, there's some charts in there that compares various hydraulic motors with electric and gas. what you need is low speed high torque. I could go out to the mill and read the data plate on mine, but it's DARK out there and there's SKEETERS. I scrounged mine off an old truck tire changer and don't know right off hand. It's about the size of a large tin can. Took me 2 tries changing sprocket sizes to get it like I wanted.
UPDATE  The data plate is long gone. It's 3 inch dia, 6 inches long 1/2 pipe ports. I would estimate 100-150 rpm with 8 gpm flow. Plenty stout. I have busted roller chains and winch cable, never stalled the motor.
Offline Tom_Averwater
  • Semi- retired Carpenter
Re: Garwood winch
« Reply #23 on: September 21, 2008, 05:29:49 AM »
Thanks for all of the replies .Now I have alot of of ideas to work with .
He who dies with the most toys wins .
Offline MikeON
Re: Garwood winch
« Reply #24 on: December 06, 2008, 08:41:32 PM »
The Vietnam era Deuce and a Half army trucks (M35A2) had Garwood 10,000 lb winches.  They were PTO driven.  The PTO had two forward speeds and one reverse.  A later version of the Deuce (M35A3) has the same winch with a hydraulic motor.
I have a Garwood 10,000 lb. winch that I would like to use on my 4610 Ford tractor .I would use the hydraulics on the tractor to power it.What speed do these winches run ? How big of a hydraulic motor would I need to run it?  Thanks Tom
Woodmizer LT40HD Super.  WM Single Blade Edger,  John Deere 4310 tractor, M35A2C Deuce and a Half truck
Offline Kodiakmac
    • Upper Canada Outfitters
Re: Garwood winch
« Reply #25 on: December 06, 2008, 10:35:59 PM »
Look, I'm an old dog who's been bush-whacking for longer than I want to admit...but you guys amaze me.  Really.
Any chance you could get together and come up with a simple design for a cheap, effective, home-made 3-point hitch skidding winch that any putz with average skills and a welder coud put together in a short time?  Seriously
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
440JD, Echo CS510, Stihl 051AV, Wallenstein wx980
Offline pineywoods
Re: Garwood winch
« Reply #26 on: December 06, 2008, 11:09:06 PM »
How about this ...
Runs off the tractor hydraulics
Offline mike_van
Re: Garwood winch
« Reply #27 on: December 07, 2008, 07:39:32 AM »
Kodiacmac, I made my own some 10 years ago. Started with an 8,000 lb. Tulsa winch off a wrecker. I had a hyd. motor driving it, but never got the right one. Too slow & not enough 'snot' I had it for sale for awhile, some lookers, no takers. End of this summer, I had it in my shop, went from hyd. to pto drive. The changeover was just incredible. I've skidded out 100+ trees since then with no problems. I lost my reverse drive by going to pto, I have to watch out I don't get in a spot where I can't backup or lower the hitch to let the strain off the cable. So far, so good.
  A few pics
     The last pic. shows the butt & part rootball from an oak I winched up a pretty steep bank. The cut is about 40", the whole piece some 7 ft long.
     The frame is channel iron from an old highline crossarm, galvenized, but it was free. I've got 125' of cable on it, twice I had to add on to reach a log.
Offline Ironwood
    • http://www.branchandburl.com
Re: Garwood winch
« Reply #28 on: December 07, 2008, 08:39:04 AM »
Guys,  ALL great ideas.
 Larry,
 I like yours on the ground, are there studs or cleats that bury in the ground if it starts to pull you in reverse? Just a thought. I think I may do a hybrid of the Larry and Mike Van units
   Ironwood
Offline Stephen Alford
Re: Garwood winch
« Reply #29 on: December 07, 2008, 08:12:19 PM »
The hydraulic winch has worked well for me . I have had it for about 17 years and because it is hydraulic it has been on more than one piece of gear.  Needs evolve and found myself needing the back of the tractor for other stuff and wanting the winch at the same time. Being able to use powered spool in and spool out with freespoll has been very useful. The thing I never got to incorporate yet is some form of fairlead to keep the cable coming on stright to reduce wear. Added a couple of yarding pics to the gallery. :)
logon
Offline beenthere
Re: Garwood winch
« Reply #30 on: December 07, 2008, 08:35:55 PM »
Stephen
Is that pulpwood you are bringing in?   or for firewood?
And do you just winch it in, or try to back out with it on the front like that?
Re: Garwood winch
« Reply #31 on: December 07, 2008, 09:25:23 PM »
Hey BT; our forestry sector has pretty much flatlined. Firewood is the primary product these days especially in any stand improvement work. Over the years that winch has pulled just about everything . Generally speaking the twitch is pulled together and hauled ahead. the tractor is turned and the wood sorted and hauled to the landing with the grapple. Then the slash is picked up and piled or spread depending on objectives. :)
logon
garwood winch
Started by stamper on For Sale
Last post May 11, 2013, 12:45:11 AM
by stamper
hough IH S7 skidder with carco 100 winch.how do I adjust winch? manuals attached
Started by roundbarn on Forestry and Logging
Last post February 15, 2016, 05:55:49 AM
by Logger RK
Timberjack 208 winch valve section for hercules winch
Started by redneck on Forestry and Logging
Last post June 11, 2017, 02:50:40 AM
by Neilo
440b winch driveline and winch questions
Started by ohiowoodchuck on Forestry and Logging
Last post December 31, 2016, 02:46:51 PM
by ohiowoodchuck
