Author Topic: E-Classic: Size of wood for burning  (Read 2528 times)
Offline spankyreal
« on: September 18, 2008, 03:11:14 PM »
Hello All,
I had my E-Classic delivered today.  The delivery men took a look at the wood I had on hand and suggested I split some of the larger full pieces.  Does anyone have any experience with burning unsplit wood in the E-Classic?  I have read online that the wood boilers would function using unsplit seasoned wood.  IS this not true?
Thank you
Offline Hackberry
Re: E-Classic: Size of wood for burning
« Reply #1 on: September 18, 2008, 03:53:43 PM »
The e-classic needs dry wood of 15%-25% moisture content.  I'm not taking any  chances with my first season of burning the e.  I've got 10 cords cut and split like you would have for a fireplace.  I also have 8 cords of round 6"-8" ready to go.  I plan on mixing them as the season goes.  With time we will all find out whats best.  Good luck, let us know when it's up and running.  Hackberry
Offline Tom Sawyer
    • Tom Sawyer Sawmill
« Reply #2 on: September 18, 2008, 04:29:02 PM »
That's something that they don't tell you in the brochure!
Offline Hackberry
« Reply #3 on: September 19, 2008, 04:01:38 PM »
I found the info in their brochure under How Combustion Works.  Look under stage one.  It says  wood of 15%-25% will burn better and give off more heat.  It does not say you have to use that dry of wood, but I'm guessing the boiler will work better if you do. Hope this helps. Hackberry
Online beenthere
« Reply #4 on: September 19, 2008, 04:44:34 PM »
The less water that has to be boiled out of the wood, the sooner that energy can go to heating.  Simple fact of the process.
Below 30% moisture content, at least the water is then not just free water in the wood cells.
Too often we hear the story that these outdoor wood boilers ""will burn green wood"".  That is true, but one just doesn't get much of the wood energy as heat. While burning green wood (considered green when above 30% moisture content), there is considerable smoke and smell coming from the stack.
The smoke and the smell tends to turn neighbors off and tends to incubate the petitions and laws that prohibit wood burning.
I let green wood dry before burning, and rotten wood lay in the woods.  My 2 :) :)
Offline antos_ketcham
« Reply #5 on: October 04, 2008, 09:18:05 PM »
I have found with my E-Classic that you don't want to use wood smaller than 6 inch or it smokes more. I have burned large unsplit rounds in it and it has worked just fine.
Pete
CB E-Classic 2300 Has anyone tried burning Hay or Straw
Started by dirtyedge on Firewood and Wood Heating
Last post January 09, 2009, 06:18:13 AM
by Jeff
How much wood have you used in your classic(4030,5036,6048) not the e-classic
Started by cb6048 on Firewood and Wood Heating
Last post February 27, 2009, 07:10:54 AM
by thecfarm
wood burning
Started by Jeff on General Woodworking
Last post January 05, 2008, 02:46:21 PM
by Jeff
How much wood are you burning?
Started by Firewoodjoe on Firewood and Wood Heating
Last post January 23, 2015, 07:38:50 AM
by kelLOGg
