Author Topic: CB Classic/E-Classic and corrosion inhibitor question  (Read 1583 times)
Offline antos_ketcham
« on: October 04, 2008, 09:23:37 PM »
Does anyone know why it is bad to have too high a level of corrosion inhibitor? I tried doing the test and couldn't get the sample water to turn pink and stay that way for a minute per the instructions. The manual says I need to drain water and add fresh water and retest. What is the concern with too much? Thanks. Pete
Offline rowerwet
Re: CB Classic/E-Classic and corrosion inhibitor question
« Reply #1 on: October 21, 2008, 11:55:12 AM »
from  what I could figure from doing the water test yesterday in my CB Maxim was that it puts the ph to far in one direction. like mabey to far toward base instead of acid, both of which will cause probs. but that is just my 2 cents.
josh
Husky 460, Fiskars x27, X7
E-Classic Central boiler corrosion inhibitor
Started by spankyreal on Firewood and Wood Heating
Last post September 24, 2009, 12:56:40 PM
by rowerwet
E-classic firebrick corrosion
Last post December 06, 2009, 08:06:27 PM
by ral
Central Boiler E-Classic 3200 or Classic 7260
Started by Crhall on Firewood and Wood Heating
Last post March 04, 2015, 01:10:44 PM
by Roger2561
How much wood have you used in your classic(4030,5036,6048) not the e-classic
Started by cb6048 on Firewood and Wood Heating
Last post February 27, 2009, 07:10:54 AM
by thecfarm
