Author Topic: Nine inch post oak vers four inch white oak..  (Read 1872 times)
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« on: October 31, 2008, 09:37:55 PM »
If you had a 9 or 10 inch post oak about 10 feet from a 4 inch white oak (DBH) what would be the best thing from a dollar stand point to do???  Both trees have good form and a good crown..right now....The white oak is starting to need some room to do any real good, but the post oak is going good already....What are the usages of post oak, besides post and ties..??  Hey SD I been planting my butternuts that I got form Dogy in the 1/2 inch hardware cloth...knew if I didn't put in on them now I probably would not....Tim
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Lanier_Lurker
  • Give that kid some grits!!
Re: Nine inch post oak vers four inch white oak..
« Reply #1 on: October 31, 2008, 09:57:08 PM »
My dad keeps bugging me about whether I have any 3 or 4 inch caliper white oak.  He wants to slice it down into strips and weave baskets or something with it.
If you have anyone similarly inclined in that area you might be better off sacrificing the white oak.
It seems that the post oak is much further along in age and size compared to the white oak.  However, a comparison of growth rate, general desirability, and ultimate size between these two species will have to be provided by someone more knowledgeable than I.
Perhaps Dodgy or WDH will weigh in.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: October 31, 2008, 11:31:53 PM »
I do not believe that the lumber is distinguishable in the trade.  There are about 20 white oak species all told.  If you had a 100 years to wait, I would probably select the white oak over the post oak.  The white oak will grow faster, and the form will be better.  If I was looking at it strictly from a shorter term economic perspective, I would take advantage of the larger post oak since it will reach merchantable size sooner.
There is nothing wrong with post oak.  It is just not quite as good as white oak.  But it is twice the size at this point, and that would mean something to me.
« Reply #3 on: November 01, 2008, 06:06:38 AM »
Thanks that  sort of what i was thinking...Tim
« Reply #4 on: November 01, 2008, 08:15:01 AM »
Are you certain that one of them must go?
« Reply #5 on: November 01, 2008, 09:06:18 PM »
I don't know any basket makers around here...I didn't even know baskets were made form white oak...but I guess they could be made out of a lot of things......In this instance I probably will leave the white oak at least for now, as it will have little effect of the larger post oak at this stage,, any thing can happen,  the post could get struck by lightening for all I know....My main concern was if the post needed to go,,,,so that not being the case, I probably leave both for now.....I know this was a relatively minor question, but I see  the same thing (or close to it)  mannnny times, and wanted a rule of thumb to use in the TSI....I have asked a forester that I know and trust to help me a little, but he has been sick and I don't know if he will get to it this year or not....I want the leaves on the tree for my benefit...when he comes....As I check out different areas I am glad to see a goodly number of white oaks in that 3_5 inch bracket that are in need of a little more sun....I can spend most of my free time this winter just releasing some of them....I was girdling a beech about 6 inches friday when I hit barbed wire...and I had the little mini boss cutting sooo good...Tim
10 inch X 4 Inch beams Coastal Douglas Fir
Started by ultraglide62 on Drying and Processing
Last post June 11, 2012, 10:36:24 AM
by metalspinner
Mortising 8 inch x 8 inch hardwood posts
Started by christopherw on Drying and Processing
Last post December 22, 2008, 07:55:28 AM
by Meadows Miller
31 inch to 25 inch Western Red Cedar on the Manual LT 35
Started by Ruffneck on General Board
Last post March 16, 2017, 02:50:23 PM
by Ruffneck
36 inch white oak
Started by brooksmill on Sawmills and Milling
Last post April 11, 2007, 10:30:51 PM
by toxedo_2000
