Author Topic: Outdoor Furnace Smoke Stack Questions  (Read 1813 times)
Online DR_Buck
  • Nuff said.....
    • Got Logs?
« on: November 17, 2008, 10:09:54 PM »
My CL6048 has two sections of smoke stack.  I think they're 4' each.  I also have a spark arrester cap on it. I removed the wire screen to prevent creosote from clogging it.   The dealer charged me $85 for the cap.   I'm getting a lot of ground level smoke.
Will removing the cap help prevent this?
Should I consider adding another 4' section of stack?
Should I put the cap on if I add the extra pipe section?
If I add another pipe section is guying necessary?  The manual recommends adding guying if more than 3 sections are used.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline OneWithWood
  • I am happy!
Re: Outdoor Furnace Smoke Stack Questions
« Reply #1 on: November 18, 2008, 12:14:37 PM »
We use two sections of pipe with no cap or screen.  The smoke disipation depends a lot on the wind characteristics of your installation site.  Are there any buildings or trees that are interfering with the wind pattern?  We had a large white pine in close proximity to our stove that would occasionally cause an issue.  Since I removed it we have not had any issues.
One With Wood
Offline tonto
« Reply #2 on: November 18, 2008, 07:40:14 PM »
I have a CB 5036 and my dealer told me not to put a cap on it so the smoke will dissipate better. When the damper opens, it looks like a 600 Cat or Cummings the way the smoke goes straight up. I have friends that have caps on theirs and they hold the smoke down low and get creosote real bad. My dealer told me to just cap the top with the plate that came with the chimney when the furnace is not in use.
Stihl MS441 & Husqvarna 562XP. CB5036 Polaris Sportsman 700 X2. Don't spend nearly enough time in the woods.
Which outdoor wood furnace?
Started by ohsoloco on General Board
Last post May 11, 2003, 03:15:15 PM
by Furby
Outdoor furnace install
Started by simonmeridew on General Board
Last post May 07, 2008, 12:12:16 PM
by Engineer
Outdoor wood furnace
Started by dewwood on General Board
Last post June 17, 2003, 09:39:19 PM
by dail_h
Started by JRC on Sawmills and Milling
Last post October 31, 2004, 04:40:55 PM
by Mark M
