Tally-I/O
Author Topic: home built owb ideas  (Read 2027 times)
Offline old joe
« on: December 04, 2008, 11:49:46 AM »
Has anybody built their own design owb?  I'm not a great welder, but I think I can , with some good design advice. Any response will be greatly  appreciated. I have an almost unlimited supply of dead and down wood, and 5000sq'  in three buildings to heat  .       thanks   joe
THE NEW YANKEE TIL A NEWER ONE ARRIVES THEN I\'LL BE THE OLD YANKEE
Online beenthere
Re: home built owb ideas
« Reply #1 on: December 04, 2008, 12:27:16 PM »
old joe
This design you are after to heat water, and then pump it to the buildings?
I've a small wood 'boiler' inside to heat water, and it is a very simple design. Essentially a barrel within a barrel. I cannot replace it, so if it gives up I will approach a local welder to get the 1/4" steel rolled, then have it welded with no leaks, and use the same cast door that is on it now. It is simple and very effective. Has a 9 gallon water jacket around it.
Offline old joe
« Reply #2 on: December 04, 2008, 04:08:20 PM »
Thanks,     I've got a 500gal  propane tank for storage  and want to make  a heat exchanger  at the firebox  I'm going to try to convection feed the  tank .  What do you all think??
Offline logwalker
  • Got Logs??
« Reply #3 on: December 04, 2008, 09:07:55 PM »
I have been thinking about doing one as well. Use brick in the firebox on bottom and three sides for hotter firebox temps. Then pass the flue gasses thru a set of firetubes  and out the chimney. The one I use now is completely surrounded by water and never gets hot enough to burn completely. Joe
Offline old joe
« Reply #4 on: December 10, 2008, 04:32:12 PM »
I made the firebox out of a 30 gal. water pressure tank .  6 in. stove pipe out the top, 12 in door.  its about 18 in diameter
Next I'll build 2   6 tube collectors out of 2" galanized pipe and bury it all in a sand filled cement block box.
Home built bandmill - need ideas for making it into a trailer
Started by Timberline on Sawmills and Milling
Last post July 04, 2012, 10:17:37 AM
by shelbycharger400
Home built slabber
Started by flip on Sawmills and Milling
Last post October 12, 2018, 09:52:54 PM
by Kssawguy
Another home built log arch
Started by OH Boy on Forestry and Logging
Last post January 11, 2014, 09:00:59 PM
by Sixacresand
Woodmizer Built Home
Started by JohnG28 on General Board
Last post March 04, 2013, 12:08:19 PM
by JohnG28
