Author Topic: Crate wood in E-classic 2300  (Read 1556 times)
Offline renegadecj
« on: December 08, 2008, 12:21:53 PM »
I have a crating company near my work who throws away a lot of 1x4 wood (pine) with small staples in it.  I used to burn some of it in my old OWB, but I don't know if the staples would cause any issues with the 2300.
Any ideas?  Would it work just like the old one, or should I worry about the small staples getting somewhere they shouldn't be?
Offline antos_ketcham
Re: Crate wood in E-classic 2300
« Reply #1 on: December 08, 2008, 07:07:20 PM »
Shouldn't be a problem from what I can tell. I was thinking of doing the same thing but with pallets. Pete.
Offline chugbug
« Reply #2 on: December 09, 2008, 08:50:47 PM »
So far pallets working great in my Mahoning OWB , I think they smoke more than regular wood , not sure why?? On weekends when I'm around thats all I burn , talk about free heat !!! My furnace does have a real heavy grate system for burning coal , that probably helps , the nails fall right through.
Offline MudBud
« Reply #3 on: December 11, 2008, 10:57:11 PM »
No problems at all. I burn chocks and other style of pallet wood with many staples and nails.  You should clean out the reaction chamber at least weekly and using a good magnet works really well. It has a tendency to build up right down the back side and pile up quickly.  I also removed both bars from the lower hole so the nails dont plug that off.
E classic 2300 wood ignition with propane problem
Started by muckamuck on Firewood and Wood Heating
Last post April 26, 2010, 10:14:29 PM
by spacedog
E-Classic 2300 wood only water temp sensor
Started by JJ on Firewood and Wood Heating
Last post December 15, 2014, 08:24:03 PM
by JJ
Wire brush to clean e classic 2300 propane wood ignition jet.
Last post February 28, 2011, 03:55:19 PM
by doctorb
E Classic 2300
Started by dkfearon on Firewood and Wood Heating
Last post September 10, 2011, 08:42:46 AM
by doctorb
