Author Topic: We're learning  (Read 1256 times)
Offline Ed_K
We're learning
« on: July 19, 2003, 06:55:46 PM »
 Well I learned that if you want lots of 2x4s, its faster to run the hemlock to a 12" cant and tricut it, then turn 90 deg and cut the 2x4s. I learned today that you don't want to take a job resawing 2x8s to 2x4s that were around a paint booth for a few yrs. 16 boards wiped out the blade :'(.
Ed K
Ed K
Re: We're learning
« Reply #1 on: July 19, 2003, 09:42:19 PM »
Welcome to the world of Reclaimed timbers.  That's the kind of material I was resawing except I was trimming the edges of 3x13's and then cutting the paint off of both wide sides and making two 5/4x12's.  I now what you are talking about wiping out blades. :)
Offline dail_h
  • G-Diddy and the Baby Hurlenator
Re: We're learning
« Reply #2 on: July 20, 2003, 01:29:54 PM »
   Resawed some beams once from out of an old shoe factory,the pile of busted blades was bigger than the pile of boards. Them idiots would drive them sewing needles into 'em,they'd take the teeth off just as fast as they went by.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Offline Ed_K
Re: We're learning
« Reply #3 on: July 20, 2003, 06:43:35 PM »
 Tom,
I put 8 2xs on, and sawed in half. The set was gone and tip of teeth where dull. Changed blades, set up 8 more, same thing. but the job is done after 3 blades. No more of that type of sawing for me, green wood is best.
Ed K
Ed K
A new learning
Started by whittle1 on Sawmills and Milling
Last post May 29, 2016, 10:29:28 AM
by whittle1
learning to saw
Started by edgerman24 on Sawmills and Milling
Last post August 28, 2014, 08:18:50 AM
by Jeff
Learning some
Started by Timo on Sawmills and Milling
Last post October 15, 2005, 02:15:21 AM
by Brucer
Learning one’s age! old now
Started by crowhill on General Board
Last post August 11, 2019, 03:52:08 AM
by Ianab
