KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: V plow for skidder  (Read 27070 times)
Offline TeaW
Re: V plow for skidder
« Reply #20 on: January 04, 2009, 09:01:30 AM »
 I use a V nose plow on my 440 JD when I have to . It is heavy but plowing it sits on 3 shoes and all your doing is pushing it. Have a bar welded to plow to push with blade chains up easy .Blade lifts it alright but it is heavy and load it to move it any distance. The bigger  V's lift the snow higher to get it back out of your road more. When the snow gets deep you put one side into the bank and lift it up and over, a bit of speed helps if you can get it. Haveing to plow snow once or twice a day sure does slow down production. Good luck.
TeaW
Offline Reddog
  • Forest & Urban woody plant management
« Reply #21 on: January 04, 2009, 09:10:53 AM »
I found a couple of plow halves from a 8'2" boss plow. Then welded them into a permenat V at 7' wide. I then used the quick hooks on my loader bucket to hold it on.
Some one mentioned using two meyer 7' blades and welding them together. That would work good for a 10'-12' range wide V.
Offline shinnlinger
« Reply #22 on: January 04, 2009, 10:33:13 AM »
Iron wood,
Was that a joke about not being left out in the weather?  A buddy found it in the woods hunting a few years back.  It is pretty rusted but gets the job done.  I found those shoes at the dump and modified them a bit to make them work.
Shinnlinger
Offline Ironwood
    • http://www.branchandburl.com
« Reply #23 on: January 04, 2009, 01:15:20 PM »
Yeah Shinnlinger,
 Your buddy put me up to this :D ;D. Na, it just looked lightly surface rusted. Usually if is left out for any amount of time it will deeply pit and even compromise the structure (I see them like that frequently).
     Ironwood
Offline shinnlinger
« Reply #24 on: January 04, 2009, 02:17:06 PM »
Iron,
One of the ribs is pretty toast, but you are right it is sound enough to Get-R-Done!!!
NOTE FROM JEFF! THIS IS THE 500,000th POST ON THE FORESTRY FORUM!
Shinnlinger
Offline Ironwood
« Reply #25 on: January 04, 2009, 03:00:18 PM »
One design flaws on the Meyers is the way the arched angles allows water in behind. If stored outside it takes it's toll.
 Ironwood
Offline VT
« Reply #26 on: January 04, 2009, 04:07:14 PM »
OK , getting the hang of stuff now.
VT
Next years
Good on .5 M
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #27 on: January 04, 2009, 04:14:49 PM »
The photo uploading system was amended in the last couple three days. Did you try in the last 3 days? Have you asked for help yet?
Offline VT
« Reply #28 on: January 04, 2009, 04:31:26 PM »
Gender: Male Ask ??
Ive got them now loaded on the Forum server. (2) Knife one is on some other puter.
Im getting there, Every forum has a different method, and not always the one were think of using.
 :D
VT
Offline shinnlinger
« Reply #29 on: January 04, 2009, 04:45:52 PM »
Jeff,
Do I get a prize???  Just kidding, this site is prize enough!  People actually respond to my stupid ideas..sometimes.....
Shinnlinger
Offline VT
« Reply #30 on: January 04, 2009, 05:04:11 PM »
shinnlinger, Please spill  the way you posted the Pictures of your tractor .
 Also how do you mark a subject post so you may watch it??
VT
And yes , Im male and asking  ::)
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #31 on: January 04, 2009, 05:12:17 PM »
Once a photo is in your gallery, you just go to your photo look underneath it, and copy the insertion code to paste into your post . You will see something like in this example photo;
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #32 on: January 04, 2009, 05:14:17 PM »
I see you gotthe photo into your gallery. Good job on that.
Offline VT
« Reply #33 on: January 04, 2009, 07:02:13 PM »
Kewl , thanks for the help Jeff
Got that down.
 I run 5-7 puters here , so some have differant stuff that is on them.
I will get to the knife one again and upload the chipper knife sharpening rules .
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #34 on: January 04, 2009, 08:38:12 PM »
On the top and the bottom of each thread is a notify button to sugn up for thread notifications
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #35 on: January 04, 2009, 09:31:03 PM »
 We have a 12 foot plow that we put on our 540 , put the blade in float position and go . It aint the quickess but will push a lot of snow . It is angled about the same as it was on the truck it came off of. A couple of passes and you get quite a wide road . Those oldplows are fairly easy to come by . Check out the local plow guys around your place . Most have a bone yard of there older stuff ....
   Marcel
Offline Ironwood
« Reply #36 on: January 05, 2009, 05:59:37 AM »
Well, since we are on the topic of modification, I will be recieving this 4 x 4 Military TUG soon. It is 4 wheel steer, powered by gas. I need something to drag logs around so as not to tear up my 24 HP JD tractor. I will likely put a skidder style winch on the back, removable backhoe, and BIG snow plow on the front. The engine is in need of some attention, so I will likely put a 3 cly JD diesel in it. Fortunately, there is a drive shaft between the engine and trans, which should make the switch easier. It has tractor trailer size tires, so tires will be fun to find something interesting, perhaps retread mudders ;D. Designed to pull 100,000 on pavement. I believe it is an American -Coleman  Here is another one I found   http://www.oshkoshequipment.com/details.cfm?ProductID=1&pid=11 Let the fun begin.
 Ironwood
Offline stonebroke
« Reply #37 on: January 05, 2009, 08:27:04 AM »
Boy you get all the neat stuff.
Stonebroke
Offline redneck
  • timberjack 208
« Reply #38 on: January 05, 2009, 09:43:50 AM »
That looks like it could plow snow!! :o
208 timberjack 353 detroit, case 580 super K backhoe, homemade bandmill, 357xp, 372xpg
Offline redneck
  • timberjack 208
« Reply #39 on: January 05, 2009, 09:46:48 AM »
Lets see some more pics of snow equipment from everyone. I just love looking at that stuff :)
utv with snow plow
Started by tree-farmer on General Board
Last post January 26, 2016, 08:36:15 PM
by Chuck White
RoBo plow
Started by Raider Bill on General Board
Last post March 07, 2010, 09:56:17 PM
by Brucer
Sten-o-mat Plow
Started by whitepe on General Board
Last post July 28, 2010, 08:16:54 PM
by Mark K
Snow plow brands and use
Started by sprucebunny on General Board
Last post December 07, 2005, 11:33:07 PM
by jayfed
