Author Topic: winch and trailer to load logs  (Read 30974 times)
Offline SCSawyer
  • If Your Not Sawing Your Wasting Time.
« on: January 03, 2009, 06:10:38 PM »
hey guys just needing some ideas I have already bought a trailer and mounted a swing arm in the front center and I plan on mounting a winch to this so I can pic up all these free logs around any idea how big a winch i need ? ie.1500lb or what? Its just to much trouble to load the tractor un load take logs home go back load tractor again.
Silas S. Roberts , Bluff Mtn. Timber
Offline pineywoods
Re: winch and trailer to load logs
« Reply #1 on: January 03, 2009, 06:43:20 PM »
Assuming you talking electric winch ? Bigger is better, I'd go with at least 3000
Offline SCSawyer
« Reply #2 on: January 03, 2009, 06:59:36 PM »
yes electric 12 volt I didnt really know the weight of decent size logs to go by
Offline tyb525
  • Always learning.
« Reply #3 on: January 03, 2009, 07:04:59 PM »
There's a log weight calc in the forum extras. Of course you gotta factor in sliding resistance
Offline wtf
« Reply #4 on: January 03, 2009, 07:31:36 PM »
Don't know about the free logs (my free logs have dryied up ) but I'd go 8000 lb. You could parbuckle up the side or pull them up the end with a gin-pole, or if the trailer tilts, that works well too.
PS. you might look at electric over hydraulic also.
What
Offline tyb525
  • Always learning.
« Reply #5 on: January 03, 2009, 08:14:09 PM »
I pull logs up from the back, my sides are too high for it to be practical to pull them up over the sides.
Offline breederman
  • getting by the best way I know how
« Reply #6 on: January 03, 2009, 08:20:39 PM »
Search for DanG-DeadHeader log lifter here on the forum.
Together we got this !
Offline Ironwood
    • http://www.branchandburl.com
« Reply #7 on: January 03, 2009, 09:04:38 PM »
Definitely Fla Deadheader set up, simple stupid, cheap, effective. There it covered everything necessary for me to be interested ;D Really cool design.
 Ironwood
Offline sgschwend
  • My new Brand X sawmill
    • Brideck Enterprises Portable Sawmill Service, Washington
« Reply #8 on: January 03, 2009, 09:31:42 PM »
My experience with 12V lifting winches is that they lift far less than specified.  I wish I could say how much less, it is something like half or less.  So the 80000 pound suggested earlier is probably a good choice.
One last thing, be sure and set a large battery next to the winch and use big cables, don't skimp on the cable size.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #9 on: January 03, 2009, 09:54:27 PM »
Also, keep in mind that some winches are not made for lifting, just pulling!
~Chuck~
I LOVE MY SAWMILL
Offline jander3
    • Peeling Logs
« Reply #10 on: January 03, 2009, 09:58:56 PM »
I use a manual 1500# winch with a brake.   I can lift 800# without much effort.   The brake holds the load in place and prevents freewheeling.
Jon
Offline Warren
  • Whatever you do, work at it with all your heart, as working for the Lord.... Col. 3:23
« Reply #11 on: January 03, 2009, 11:08:49 PM »
I think most winches are rated for max pull with the first layer of cable on the spool.  As you add more cable to the spool (diameter increases) the pulling capacity goes down.
Winches are one area where I think it is better to err on the "Bigger is better" side of the equation....
LT40SHD42, Case 1845C, W&S Forklift, Baker Edger ...  And not near enough time in the day ...
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
    • My Blog: A Riving Home
« Reply #12 on: January 04, 2009, 12:14:18 AM »
If money's an issue, you may look into manual winches instead of electric.  I can mount two manual winches on my trailer and have used them to purbuckle several logs in the 3000-5000 lb. range with little effort.  I don't know what the winches are rated for, I got them for free from a friend.  I can tell you they are very heavy duty :).
Offline mad dog
« Reply #13 on: January 04, 2009, 06:55:03 AM »
        Chek out portable winch,You could use it in your wood lot,and 100's of other uses.
mad dog 78 acres,pasqualli tractor,L-15 woodmiser
Offline mike_van
« Reply #14 on: January 04, 2009, 07:18:33 AM »
You can pretty much double any winches pull by using a snatch block on the load.
Offline Dakota
  • Swing'en in South Dakota
« Reply #15 on: January 04, 2009, 10:48:47 AM »
you could do it this way.
Dave Rinker
Offline metalspinner
« Reply #16 on: January 04, 2009, 02:32:31 PM »
I've got an 8000lb electric on the front of mine and have yet to find a log that cannot be loaded.
Including this one...;D
With all the weight you are putting into motion, you do not want to be wondering if your winch can handle it while it's on the way up. ;)
Offline SCSawyer
« Reply #17 on: January 04, 2009, 02:54:07 PM »
Alright dan explain how this contraption works ?
Offline bck
« Reply #18 on: January 04, 2009, 04:01:09 PM »
I have a #9000 electric winch and like metalspinner I have yet to find a log it wont load. Just be sure to start with a fresh battery. I am using a 1000cca battery and can load several big logs with it but I wouldnt try (  :) again  :) ) for two trips without recharging the battery each trip.
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
« Reply #19 on: January 04, 2009, 04:40:26 PM »
I have a setup like Dakota.  It works great.  I use a 10,000# Warn winch and even though this setup doesn't do a dead pull, It grunts a bit on huge logs.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
How I load my 16' trailer.
Started by luvmexfood on Forestry and Logging
Last post April 16, 2017, 01:37:47 PM
by luvmexfood
How do you load em on the trailer?
Started by cwimer973 on Sawmills and Milling
Last post November 11, 2015, 06:51:28 PM
by Kbeitz
Trailer spring load
Started by Night Raider on Sawmills and Milling
Last post June 07, 2009, 07:24:36 AM
by bandmiller2
Max trailer load width?
Started by Qweaver on General Board
Last post October 25, 2016, 11:01:56 AM
by Qweaver
