wiring question
Started by Dan_Shade, January 06, 2009, 10:04:06 PM
Dan_Shade
What's the right way to go about suspending a cable from a junction box in a ceiling.  I want to run romex from the panel box, and have a stranded cable dropping down from the ceiling.
lots of dull bands and chains
logwalker
The electric supply house sell a wire hanger that grabs the cable like the old Chinese finger cuffs. It is the only way to pass code. Sorry I forgot the name.
farmerdoug
I stores I see twist lock plugs used with ceiling outlets.
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
kenneth
The finger lock device is called a Kellem. they come in many styles.
Dan_Shade
https://www.foxelectricsupply.com/content/products/ProductDetail.asp?qsCatID=25001&qsProductNo=LEVL7504
one of these things?
The ceiling is too high to put a recepticle there.  I want to drop the cable and install a twist lock plug
Dana
Dan, that's the correct part to use for strain relief.
Dan_Shade
and you drop it out of the bottom of the box?
Norm
That's what I use for our mill. We ran metal conduit along the rafters with these hooked on to the end. I've had it this way for 8 years without any problems.
dolittle
Use any convenient knockout on the box.  If you are mounting the box flat on the ceiling you can get a cover with a knockout also.
pigman
I am sure glad you  guys answered Dan's question before I did . On the question about "suspending a cable from a junction box in a ceiling" I was going to tell him to supend it vertical . ::)
Dana
Quote from: Dan_Shade on January 07, 2009, 06:48:26 AM
Dan, I'm not sure if you still need this answered? The Kellem usually is installed into the metal cover that is screwed to the box.
