Baltic Abrasives Technologies
Author Topic: skip the ethanol  (Read 9177 times)
Offline shinnlinger
Re: skip the ethanol
« Reply #20 on: January 26, 2009, 03:09:21 AM »
Hi,
What if you had some small engines you suspected you "ethonolaled" in the fall and havent run in a while.   You did the ScottAR water to gas test and found them to be excessive water?  Would a simple drain and replace before running be a sufficient fix, or should you pull a valve cover and drizzle some more oil on the valve stems or something???
Shinnlinger
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #21 on: January 27, 2009, 12:44:17 AM »
Drain tank, change fuel filter, and maybe clean the carb out.
Oil change wouldn't hurt anything either...
If somthing don't sound right on startup, start inspecting...
Scott
[Magicman]
Offline bandmiller2
« Reply #22 on: January 27, 2009, 06:02:14 AM »
A little off topic but close.I've got four older deere 2cyl tractors that used to start first compression but with the newer gas their hard starting and once the plugs get wet game over.Seems theirs no light end to the gas now.Have any of you guys noticed this with your older rolling stock?Frank C.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #23 on: January 27, 2009, 11:50:36 PM »
Well there has been to major fuel changes since that motor was built. They liked the old leaded gas, You take away the lead and add a water absorbing additive to the fuel and they do not like to run the same. Try to find non ethanol supper and that should help. Off road gas for off road vehicles.
Offline Captain
« Reply #24 on: January 28, 2009, 06:40:13 AM »
Frank, I would think it is a fuel volitility issue.  Winter fuel (highter volatility) on a warm day any better?
Captain
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #25 on: January 28, 2009, 11:05:49 AM »
Quote
My dad had a John Deere riding mower with a 20hp kawasaki v-twin.  It dropped or bent a push rod 3 times in the last two years he was alive.  JD dealer kept accusing him of shutting it off at full throttle and causing a back fire.
My Zero-turn with the 25 HP Kawasaki backfires EVERYTIME I turn it off no matter what the throttle is set at.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline beenthere
« Reply #26 on: January 28, 2009, 12:54:59 PM »
Dr B
Check that the fuel shut-off is working...sounds like it is not.
Should have it if it is fuel injection.
Offline pineywoods
« Reply #27 on: January 28, 2009, 01:26:35 PM »
Quote
There is a fuel shutoff solenoid built into the carb. Shuts off the main jet when you turn off the ignition. It's probably stuck open with gum left from evaporated fuel or corroded from water in the ethanol.  Look on the side of the carburator.If you see a small wire attached, pull it off with the engine running. The engine should die immediately, if it doesn't the shutoff valve is stuck....
Offline bandmiller2
« Reply #28 on: January 29, 2009, 05:42:33 AM »
Cappy, even in warmer weather the tractors don't start like they used to.They put something in the fuel so it won;t evaporate into the atmosphere as easily.I'll try to find high test without alky and try that .DanG old tractors I don't want to spoil them,they'll want the good stuff all the time.Frank C.
Offline John Mc
« Reply #29 on: January 31, 2009, 02:37:08 PM »
The reason that some (not all) high test gas does not have ethanol in it is that when some states were considering mandating ethanol, various groups lobbied to make sure non-ethanol gas was still available. [Some piston aircraft can run on auto gas, but ethanol is definitely prohibited. It's a problem for marine use (ethanol eats some fiberglass fuel tanks, and many boat engines sit longer than cars between use, giving the ethanol more time to suck moisture out of the air). Two cycle engines have a tougher time with ethanol.] Premium gas was picked because it's already something of a "specialty gas" - and because few people run premium in their cars, so making it free stil tended to maximize the use of ethanol-laced gas.
Don't be fooled into thinking that all premium gas is ethanol-free. It's a function of what that state's regs say. And even in some states that allow ethanol free premium gas, they don't necessarily prohibit ethanol in premium gas.
I'm fortunate in my area - even though most gas stations have around 10% ethanol in everything they sell, there are one or two who get their gas from Canada without any ethanol, and a small airport that sells ethanol-free premium auto gas (they don't stock aviation gas). I make a point to buy all my chainsaw gas from one of these sources.
John Mc
Offline Ironwood
    • http://www.branchandburl.com
« Reply #30 on: February 02, 2009, 12:08:14 AM »
One more thing to worrry about ::) Ironwood
Offline Mad Professor
  • This place gives me a woody!
« Reply #31 on: February 04, 2009, 12:39:29 AM »
I've been running high octane in all of my gas equipment. I've been told that there is no ethanol in the high grades, but cannot verify. Mid grade is a blend of high octane and regular, so I avoid it also.
Don't know who told you that but all auto fuel sold in mASSachusetts is "oxygenated", a.k.a. "corn fed" up to 10% ethanol.
Ethanol will react with aluminum or magnesium (more so) so it will also eat up uncoated fuel tanks and carb parts.
Skip Or Non Skip Chain On A Ported 372 With A 28 Inch Bar ?
Started by gsrsol84mm on Chainsaws
Last post October 31, 2013, 01:05:26 PM
by ehp
Skip, Semi-Skip vs. Full Comp?
Started by Mark M on Chainsaws
Last post March 13, 2004, 09:13:28 AM
by Stan
Skip Planing
Started by WV Sawmiller on Drying and Processing
Last post April 13, 2018, 09:07:48 AM
by petefrom bearswamp
SKIP CHAIN
Started by KDJ on Chainsaws
Last post January 07, 2007, 09:44:29 PM
by parrisw
