Baltic Abrasives Technologies
Author Topic: engine remote kill switch  (Read 1468 times)
Offline first shirt
« on: January 25, 2009, 08:56:55 AM »
Any suggestions on where I can purchase a remote kill switch for my sawmill?  I have a M14 Foley Bell Saw which is powered by a Massey Ferguson 135 tractor. Thank you.....
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: engine remote kill switch
« Reply #1 on: January 25, 2009, 09:17:52 AM »
is your tractor gas or deisel?
If it's gas, you can wire a switch into the ignition to shut it off relatively easily.  If it's a deisel, you'll have to shut off the injector pump, or choke off the air intake.
I'm assuming this is a safety feature you are wanting to add to your mill?
lots of dull bands and chains
Offline bandmiller2
« Reply #2 on: January 25, 2009, 02:50:30 PM »
First shirt,just copy how the tractor shuts down, Ignition ,cable or solenoid and run it over where you can reach it.Whats handy is a remote dissconect for the PTO,rather than shutting down the tractor.Frank C.
Offline Slabs
  • It don't get no better than flyin' sawdust
« Reply #3 on: January 26, 2009, 07:53:39 PM »
Gasoline or Diesel is still the big question.
If gasoline, a remoted switch to short the points will do the job.  Remove the short as soon as the engine stops to avoid overheating the coil.
If diesel, may be a bit more complicated.  Some of the 135 diesels required the driver to lift up the kill handle and pull because there was a keyhole slot and an accidental shut down blocker on the shaft between the knob and fuel injector pump-not a cable as in some modles.  A gadget to hold the kill shaft up so that it will slide thru the keyhole and a cable to the operating position of the sawmill might work or might cause accidental shutdown due to vibration.  A good gadgeteer could come up with something.
Good luck
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.  Woodshop, metal woorking shop and electronics shop.
Stihl 025 kill switch
Started by outdoortype on Chainsaws
Last post May 01, 2005, 09:54:54 PM
by fishhuntcutwood
P41 kill switch problem
Started by Bobsaw on Chainsaws
Last post April 04, 2015, 02:57:47 PM
by Glenn
Stihl 020 AVP kill switch
Started by Jim Davis on Chainsaws
Last post February 18, 2016, 07:43:27 PM
by deerslayer
Makita 6401 kill switch
Started by gunscrew on Chainsaws
Last post April 08, 2016, 05:37:09 PM
by Stihlowner
