Author Topic: New Timber-Framed Framing Ponies  (Read 3689 times)
Offline sheneman
    • Timber Framing a North Idaho Cabin
« on: January 30, 2009, 12:31:41 PM »
Between projects this winter, I decided to build three timber-framed framing ponies in my shop using some timber scraps.   The basic design is simple, but I got the plans from Scott Stevens at Grand Oaks Timber Framing (http://www.grandoakstimberframing.com).
I created this 5-species framing pony from:
4x6 Engelmann Spruce bases
4x6 Douglas Fir legs
4x6 Ponderosa Pine top
3x6 American elm hardwood braces
1" Locust pegs
I like the way it turned out, so I thought I'd share it.
-Luke
Woodmizer 25hp LT15 with 6\\\' bed extension.
Logging with a Jeep Cherokee, a Warn Winch, and a Stihl MS 260
Offline DWM II
Re: New Timber-Framed Framing Ponies
« Reply #1 on: January 30, 2009, 05:18:49 PM »
I like them alot. with all that fir spruce and pine they should be a lot lighter to move around. Thanks for sharing the pics. :)
Stewardship Counts!
Offline shinnlinger
« Reply #2 on: January 30, 2009, 05:50:21 PM »
As disclosed in the other thread on horses, I am a fan of keeping my horses light and easy to move around and saving my energy for other things, BUT those are pretty nice and I could see a set or two in the shop.
What are the dimensions on those beautys?
Shinnlinger
Offline Brad_bb
« Reply #3 on: January 30, 2009, 06:05:58 PM »
Very nice!  You know the thing I have about the larger timber horses (or Clydesdales as one recently called them), is that they are heavy and awkward to move.  The large ones aren't for me right now because I don't want them occupying space when not being used, but the one thing they need is retractable casters.  I've seem a set on here or the TF guild forum with casters, but the problem is that if we put too much timber weight on the horses, the casters may fail prematurely.  So I'm thinking what would really be nice is a set of retractable casters and flip up and down with your foot.  They'd only be used to move the horse and would be retracted when weight is on the horse.  The horse would be resting on it's wooden foot as designed when it has timbers on it.  Another option would be a caster on a spring so that once say 50 lbs was applied, the caster would be fully retracted (spring compressed).  I just chose 50 lbs out of the air, it would have to be enough spring force to hold the horse up when no timbers are on it, but such that the weight of one timber would compress it.  Just some thoughts.
Offline zopi
« Reply #4 on: January 31, 2009, 04:57:36 AM »
Those are too pretty to use...go cut yourself a wide tabletop flitch and set 'em up on your porch for
a picnic table!
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline Raphael
  • Willing and able to do a boring job.
« Reply #5 on: January 31, 2009, 01:15:09 PM »
I agree, that contrast from the pegs and braces is far to nice to hide in the workshop.
... he was middle aged,
 --Godley & Creme
Offline sheneman
« Reply #6 on: January 31, 2009, 06:54:32 PM »
Shinnlinger:  The pine top is exactly 5' long.   I think the bases are 3' long.  Wide enough to work several timbers at a time, if needed.
The Spruce is really light.  I've never had trouble moving them around, but they can take up a lot of shop space.
Zopi:  I've actually toyed with the idea of making a table out of them instead of slowly destroying them in the shop.  I've got some large slabs of Elm that would make a great table top.  We'll see...   I'm almost done with my second framing pony.  Same design, but different species (more Spruce, no Fir).
Fun stuff!
Thanks for the comments!
Offline shinnlinger
« Reply #7 on: January 31, 2009, 07:09:30 PM »
HOw tall is it?  Is it comfy working 10x timbers???
Shinnlinger
Offline sheneman
« Reply #8 on: February 01, 2009, 02:13:21 PM »
Shinlinger:  The top surfaces of the ponies are 2'7".  This seems perfect for 8x8 and 10x10, etc.  Maybe a little short for 3" and 4" timbers, but I suppose those can be elevated.
I just finished another one made from scraps.
4x6 Engelmann spruce base and legs
4x7 Wany Ponderosa pine top.
3x6 American elm braces.
1" locust pegs
The framing ponies in the background of the following picture (the ones holding up that curved Elm timber) are 100% 4x7 Engelmann spruce with 1" white oak pegs:
Cheers,
 -Luke
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #9 on: February 02, 2009, 01:22:01 PM »
Take a draw knife to that bark and clean them up.... then they'll look real nice.....
Jim Rogers
Offline sheneman
« Reply #10 on: February 02, 2009, 01:45:06 PM »
Nah, I like the bark.
I'm sure it will fall off anyway, though.   ;)
-Luke
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #11 on: February 02, 2009, 03:53:12 PM »
If you take them outside during bug season and the bark is still on them, then you'll have some guests creating a home there......
Offline witterbound
« Reply #12 on: February 02, 2009, 04:17:09 PM »
They look like furniture.  I'd hate to use them, for fear of marking them up.
I'm a fan of heavier ponies for timber framing.  I just like something heavy to push against, I guess.
Offline Tom Sawyer
    • Tom Sawyer Sawmill
« Reply #13 on: February 16, 2009, 11:08:34 AM »
I did not know that American Elm looks so much like the walnut that I saw around here.  Very nice work :)
Framing plans for Jack Sobon's "Build a Classic Timber-Framed House"
Started by Lindrith on Timber Framing/Log construction
Last post January 24, 2007, 10:57:26 AM
by Jim_Rogers
Reinforced Timber Framing / Mock Timber Framing?
Started by Stuart Caruk on Timber Framing/Log construction
Last post January 14, 2015, 08:47:15 PM
by Gumneck
Timber Framed Cabinets
Started by Deadwood on Timber Framing/Log construction
Last post November 26, 2005, 06:03:41 AM
by SwampDonkey
Timber framed garage for VWs
Started by Rooster on Timber Framing/Log construction
Last post February 14, 2011, 08:42:09 AM
by mikerat
