Arborwear
Author Topic: Looking for a low vibration chainsaw  (Read 3619 times)
Offline straightree
  • Come again
« on: February 28, 2009, 01:36:55 PM »
I am looking for a new chainsaw, bigger than  what I have at present. It consists of a very small prunning Echo and a small Stihl, but as I am going into bigger trees, I need a bigger saw. I have tried Husqvarna 55 and have found it very smooth, and liked it. Nevertheless, looking at specs I see that Husqvarna 346 xp is rated better, vibration wise.
Is there anyone around that has experience with these models? Also woul appretiate if somebody knows of some model in the 3,5 HP range that has low vibration, specially if there is something in Stihl.
Thanks in advance
Offline wi woodcutter
  • United we bargain. Divided we beg!
Re: Looking for a low vibration chainsaw
« Reply #1 on: February 28, 2009, 01:42:15 PM »
The ms361 is real good saw. It will pull a 20" bar and chain just fine. Has low vibration and good power to weight ratio.
2-066's ms660 034av 076av huskee 27ton splitter CB5036
A guard dog needs food, water, shelter, walking and training.
My Smith & Wesson only needs a little oil!
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: February 28, 2009, 02:05:01 PM »
I've found that saws with spring suspensions were the lowest vibration saws I've used. The Stihl MS361 and MS441 are both spring, I believe. I haven't used the 441, but the 361 is a very nice saw to run.
Offline PAFaller
    • Berndtson Timber Management
« Reply #3 on: February 28, 2009, 07:59:12 PM »
Depending on dealer support in your area Dolmar makes a real smooth running saw too. I use a 7900 in my day to day falling activities here in PA, may be a bit big for your needs, but they make a 5100 model thats pretty snappy and smooth running. Just my 2 cents, Greg
It ain't easy...
Offline straightree
  • Come again
« Reply #4 on: March 01, 2009, 03:21:32 PM »
Thank you for all this very helpfull information!
Offline Quebecnewf
« Reply #5 on: March 01, 2009, 04:17:04 PM »
i have the 51 cc Makita which is a dolmar in blue and it is the best saw i have ever had
Quebecnewf
Offline woodmills1
  • the truth shall set you free
« Reply #6 on: March 01, 2009, 08:19:17 PM »
I agree that the sthil saws with springs rather than rubber mounts are very low vibration.
Offline LeeB
« Reply #7 on: March 01, 2009, 10:46:04 PM »
My new Stihl 361 is extremely low vibration. The DanG thing won't run, very low vibes that way.  >:(
Offline chevytaHOE5674
« Reply #8 on: March 01, 2009, 10:51:02 PM »
Most of the newer saws with spring anti vib systems are pretty good. The dolmar 6400/7300/7900 sure is a smooth platform, but so is the 361 and 441 stihls. Find some good local dealers that will let you try out certain saws.
Offline BCtimber
« Reply #9 on: March 02, 2009, 12:01:06 AM »
My 575 husky is by far the smoothest saw I have ever had.  Very nice
moved
MOVED: Looking for a low vibration chainsaw
Started by Jeff on Forestry and Logging
Last post March 02, 2009, 12:06:01 AM
by Jeff
Vibration
Started by Peter Drouin on Sawmills and Milling
Last post November 09, 2016, 11:13:18 AM
by Bandmill Bandit
Bar vibration
Started by bendjoseph on Chainsaws
Last post November 23, 2011, 08:03:40 PM
by Clam77
225 timberjack vibration
Started by Nemologger on Forestry and Logging
Last post May 05, 2013, 09:52:25 PM
by Nemologger
