Author Topic: 028 Stilh  (Read 2802 times)
Offline turkeyhtrb
028 Stilh
« on: March 08, 2009, 10:41:58 AM »
My old 028 is breaking down and won't run after it warms up. Just replaced the coil ($100). Still have the same problem any ideas???
Offline timber tramp
Re: 028 Stilh
« Reply #1 on: March 08, 2009, 10:55:53 AM »
  Lots of ideas ;) Is it getting fuel? Welcome to the forum.          :) TT
Cause every good story needs a villan!
Offline turkeyhtrb
Re: 028 Stilh
« Reply #2 on: March 08, 2009, 12:39:44 PM »
Fuel doesn't seem to be an issue--runs well for 8-10 min. then bogs down. will idle but sputters and stalls if you try to cut with it. After it cools down it will run well again for 8-10 min.. Could the new coil have been bad??? I love that old saw and hate to give up on it but it's almost to the point where shop visits are adding up to more then the cost of a new saw. I have a newer 280 but I like the old 028AV better.
Offline Al_Smith
Re: 028 Stilh
« Reply #3 on: March 08, 2009, 02:21:51 PM »
 That sounds typical of a failure of a clutch side crankcase seal . After the engine gets warm it causes the seal to leak drawing in outside air which causes the engine to lean out and loose power . Continued usage under this condition will ultimately lead to an engine failure caused by a lean burn condition .
Offline sablatnic
Re: 028 Stilh
« Reply #4 on: March 08, 2009, 04:13:11 PM »
It could be the filter opposite the needle-valve in the carburettor. Or the fuelfilter in the tank.
Offline turkeyhtrb
Re: 028 Stilh
« Reply #5 on: March 08, 2009, 04:24:21 PM »
Thanks everyone for all the suggestions. I wrote them down to ask my service guy. Guess I'll take my old freind for one last "ride". Have been going to pick up a little bigger saw so this may be the time.
Offline chipsfly09
Re: 028 Stilh
« Reply #6 on: March 08, 2009, 08:42:29 PM »
I have put a lot of hours on my 028 and 031s-- Have since upgraded-- any thoughts on what you are looking to replace your 028 with?  Should be lots of info and opinions on that here--  Good luck
Offline Long Look
Re: 028 Stilh
« Reply #7 on: March 10, 2009, 02:20:59 PM »
A few years ago I had a similar problem.  As a last resort, my local repair guy changed the spark plug and the problem disappeared.  It's a cheap fix if it works.
Offline sawasassin
  • Member*
  • hello everybody
Re: 028 Stilh
« Reply #8 on: March 11, 2009, 09:01:30 PM »
 Hello i had the same problem with my 028 a yr  or so ago  and tried everything and finaly asked an oldtimer and he told me to take the muffler apart and take the screen out and it will be caked in burnt oil clogging airflow , then take a propane torch and burn the oil off screen the screen will clear of black tar ,then put back together and works perfect ever since  i guess we all put a little to much oil in our mix.
Offline ladylake
Re: 028 Stilh
« Reply #9 on: March 12, 2009, 05:15:58 AM »
It could also be a clogged tank vent, try loosening the gas cap after it kills and see if it will start right away.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline barbender
Re: 028 Stilh
« Reply #10 on: March 12, 2009, 11:23:52 AM »
I've had tank vents do that before. When it dies, immediately crack your fuel cap open, close it back up and fire up the saw. If it starts and runs good for another few minutes that points to the tank vent. This happens a lot if your bar oiler is set too rich, or if you are running a light bar oil, lots of goo ends up on the vent and seals it off.
Offline barbender
Re: 028 Stilh
« Reply #11 on: March 12, 2009, 11:24:58 AM »
Like ladylake said ::) I need to pay more attention :)
Offline Jim Spencer
  • Washington, Mi
Re: 028 Stilh
« Reply #12 on: March 14, 2009, 07:53:40 PM »
Heh Turkey,
I had this problem with my 028 where it would run for a few minutes and stop and after sitting for a few minutes would start and run for a minute again.
I was talking to a guy who has been cutting timber for a living and told him about my 028 and he told me that in the carburetor and under the cover there is a small screen about 1/4" in diameter that was dirty and plugged.
I took off the carb and took the plate off and cleaned the screen and this was definatly the problem.   Never had another problem.  I am 74 and have been using chainsaws since I was a teenager cutting pulpwood.  Now have a 066, 029, and my favorite the 028 which I bought about 5 year ago for $50 at a garage sale.  The 028 is my favorite and the guy that sold it to me gets thanked every year when he has his garge sale. His face got red when I told him how easy it was to fix it because he knew it had this problem when he sold it to me.
Be sure to let us know what you find to correct the problem.
stilh saws
Started by redneck logger on Chainsaws
Last post February 11, 2009, 10:07:07 AM
by chevytaHOE5674
Stilh 029 Super
Started by bdsmith on Chainsaws
Last post July 19, 2017, 04:15:18 PM
by bdsmith
Stilh Ms 290 farmboss
Started by boboyee58 on Chainsaws
Last post May 17, 2018, 09:52:19 AM
by Weekend_Sawyer
Stilh Pro Chainsaw Boots?
Started by Great Big on Chainsaws
Last post March 01, 2009, 07:00:13 AM
by SwampDonkey
