Author Topic: Anyone know what NHLA Vehicle lumber is?  (Read 3259 times)
Offline oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
« on: June 09, 2009, 11:13:22 PM »
Saw an ad on Woodweb from some one looking for "NHLA vehicle lumber". Dont recall ever hearing this term before. Any idea what they are talking about? ???
Offline beenthere
Re: Anyone know what NHLA Vehicle lumber is?
« Reply #1 on: June 10, 2009, 12:05:22 AM »
okiemac
It is a special grade in the NHLA rules.
Are you interested in the specs?
Offline Cedarman
    • Cedarusa
« Reply #2 on: June 10, 2009, 07:18:00 AM »
Vehicle lumber is lumber that has been S2S.  It has to do with skips and chip outs. I think you can only have a total of 12" on a board to pass.
Offline oakiemac
    • Hickoryandoak
« Reply #3 on: June 10, 2009, 04:11:11 PM »
From the rule that Beenthere sent me it sounds like a lower grade/pallet grade that admits worm holes. I'll have to check into it more.
Offline beenthere
« Reply #4 on: June 10, 2009, 04:20:38 PM »
PM inspectorwoody, as he may be able to summarize it for you too.
Appears to be a structural-use grade, where strength is primary concern over clear-cuttings grade. And pallet lumber would be a good parallel.
Offline Cedarman
    • Cedarusa
« Reply #5 on: June 10, 2009, 06:54:18 PM »
Are we talking utility lumber or vehicle lumber?  The index in the grading manual only refered to a section that had to do with surfacing as far as vehicle lumber.  I didn't read the whole manual again to see if it referred to it in other places.
Offline oakiemac
    • Hickoryandoak
« Reply #6 on: June 10, 2009, 10:42:56 PM »
Cedarman-it is vechicle lumber. The part I read said nothing about surfacing but went into detail on what worm holes could be admitted.
Offline beenthere
« Reply #7 on: June 10, 2009, 10:48:53 PM »
There is a grade "Vehicle Lumber" in the special grades section (page 57 in my book)
Excerpts are:
Widths: 4" and wider, ..
Lengths: 8' to 16'
 ..rules apply to both faces of each piece as a whole of the rough or surfaced lumber...(i.e. no cuttings are measured or considered)
admit "holes" stain, streak, sound knots not over 1", season checks not materially impairing the strength of the piece and splits along the grain diverging less than 1" in 12"..... (i.e. structural integrity, which may be similar to what pallet lumber uses for specs)
Elsewhere in the rules are Utility boards No. 1, No. 2. and No. 3
This help?
Offline Cedarman
    • Cedarusa
« Reply #8 on: June 11, 2009, 06:29:56 AM »
My book is 1998 and page 57 just says use rough lumber rules and then a couple of lines about surfacing.  That is all I had to go on.
Offline beenthere
« Reply #9 on: June 11, 2009, 10:52:17 AM »
 :) :)  My copy is '90 so there must have been some changes made cleaning up some of the old special grades not likely used anymore, but maybe re-titled somewhere else. Do you have a pallet grade?  Or might that rule come under Construction/Utility grades?
Offline Cedarman
    • Cedarusa
« Reply #10 on: June 11, 2009, 04:12:08 PM »
No listing in the index for pallet lumber.  But did notice a listing for Bung lumber.  Now just what is that used for?
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #11 on: June 11, 2009, 04:20:58 PM »
i'm guessing barrels, but i have to chuckle when I hear bung lumber
that's a new term "bung grade" board, i can see me using it often  :D
lots of dull bands and chains
Offline beenthere
« Reply #12 on: June 11, 2009, 06:45:58 PM »
........  But did notice a listing for Bung lumber.  Now just what is that used for?
Making bungs, to plug bung holes, I'd imagine.
Wood barrels have holes for filling and wood bung plugs are driven in. Bung grade in this rule book is specific to either poplar or plain red gum.  No dote, punky and brashy wood, or excess burly and twisted grain is specified.
Offline inspectorwoody
    • Wieland and Sons Lumber Compan
« Reply #13 on: June 12, 2009, 10:48:55 AM »
It is now on page 61 (2007).
Says the same as Cedarman posted.
"Shall be inspected according to the rules for rough lumber. Slight skips,chipped or torn grain,the aggregate area not exceeding 12" long by the width of the piece will be admitted on one or both faces."
Offline beenthere
« Reply #14 on: June 12, 2009, 11:40:32 AM »
inspectorwoody
Hope all is going well.  Good to hear from you. Will see Burlkraft shortly at da Rox.  8)
In my old book I have that paragraph too, p64, under the Section "Inspection of Surfaced Lumber".
Has Vehicle Lumber been removed from the Special Inspection Grade section?  I should get a new book.   :) :)
But NHLA doesn't often make many changes in their rule book. :)
Offline Ron Wenrich
« Reply #15 on: June 12, 2009, 04:07:44 PM »
Here's the NHLA rulebook in PDF:
http://www.natlhardwood.org/pdf/Rulebook.pdf
This one's the 2003 version.  I found the 2007 version last year and downloaded it.  Apparently they have taken it down, since it isn't on their website anymore.
Offline beenthere
« Reply #16 on: June 12, 2009, 05:24:29 PM »
Thanks Ron
I see they did switch some things around. Page 71 has the fuller (more detail) description of Vehicle Lumber that I have on p57 of my copy of the older rule book.
They must have forgotten to put page 71 in the miscellaneous index in the back.  So they didn't drop Bung Lumber and Vehicle Lumber  :) :)
NHLA Lumber Grading course at PA Wood-Mizer
Started by MartyParsons on Shows, Events and Places to meet
Last post March 05, 2009, 10:16:38 PM
by MartyParsons
New vehicle or not? When do you decide to call it quits and junk your vehicle?
Started by Piston on General Board
Last post October 06, 2012, 03:23:12 PM
by Okrafarmer
question
NHLA Rules
Started by woodhaven on Sawmills and Milling
Last post June 27, 2003, 09:54:13 AM
by Ron Wenrich
NHLA rulebook
Started by Dan_Shade on Drying and Processing
Last post June 12, 2018, 05:24:28 AM
by Dan_Shade
