Arborwear
Author Topic: jd 640 tranny oil level check  (Read 1078 times)
Offline aksawyer
« on: July 12, 2009, 06:49:11 PM »
I am looking at buying a John Deere 640 skidder and cannot find wwhere to check tranny oil level.Thanks for any info that you  all may have.
Offline 630 Tigercat
Re: jd 640 tranny oil level check
« Reply #1 on: July 12, 2009, 07:12:04 PM »
I think its a small door down by your feet when your sitting in the cab  if i remember correct
Offline Maineloggerkid
  • Earth first...Log the other planets later!
« Reply #2 on: July 12, 2009, 07:27:17 PM »
It depends on what model. Straight 640's and D models have the Hydrualic and tranny on the same stick. From the E models on up, the are behind a little door under the actual door on the right side. You will also find I believe 4 grease points as well.
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
Offline riggin rat
« Reply #3 on: July 13, 2009, 11:07:08 PM »
On a 640, sitting in the seat it would be on the right side, open up the engine panel and all the way up by what would be a firewall you will find a dipstick that is both hyd. and trans.
Check the level of your mill after spring thaw.
Started by Joe Hillmann on Sawmills and Milling
Last post April 14, 2015, 07:51:28 AM
by bandmiller2
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post September 17, 2016, 08:19:54 PM
by ScottAR
518 cat tranny
Started by coxy on Forestry and Logging
Last post November 14, 2014, 05:54:13 PM
by deastman
518 cat tranny
Last post February 17, 2013, 04:10:05 PM
by lumberjack48
