Author Topic: husky 365  (Read 2330 times)
Offline turningfool
husky 365
« on: August 05, 2009, 07:59:10 AM »
my husky 365 keeps throwing the chain,no matter what i try..new chain and fairly new bar,bar looks good with very little wear and is still very straight /no twist..any suggestions?..note:running a 36" bar and chain and only used to cut large downed timber.
Offline Ed
Re: husky 365
« Reply #1 on: August 05, 2009, 08:37:12 AM »
Went through the same thing on a 394xp, turned out to be a broken chain adjuster.
Ed
Offline Rocky_J
Re: husky 365
« Reply #2 on: August 05, 2009, 04:17:32 PM »
You said you put a new bar and chain on it, did you look at the sprocket?  ???
Offline turningfool
Re: husky 365
« Reply #3 on: August 05, 2009, 05:12:54 PM »
sprockets like new
Offline beenthere
Re: husky 365
« Reply #4 on: August 05, 2009, 08:57:43 PM »
Only can imagine it is not adjusted right. (given that you say everything else is ok).
Offline rebocardo
  • Atlanta GA
Re: husky 365
« Reply #5 on: August 06, 2009, 02:55:49 AM »
Most likely the saw is bogging down running that big of a chain and while cleaning the chips it is being pushed off the bar, probably while you have it on it's side, usually near the nose. I encountered the problem once or twice while using my chainsaw mill.
Most likely you have taken off that little white plastic chain guide too.
Easiest solution is you can tighten the chain, run full skip (will not help much on a 36" bar ...), or run a smaller bar.
I assume you are running the oiler all the way out.
add. note:
What I have found helpful is before starting a large cut is run the saw a bit to clean out any debris in the rails and nose.
Offline 01crewcab
Re: husky 365
« Reply #6 on: August 06, 2009, 10:47:21 AM »
I wished I had a good answer. I think the idea of chips getting into the rail is feasible. I can't believe you're getting much chain speed running a 36" bar on a 4cube saw. Ideally 28" should be your max.
2100(2),480, 281, 181,372XPW, 460,435,350,61(4),51-Huskys
49SP, 630Super(3),670's(4), 830, 920, 930 Jonsered's
S-XL925 Homelite
SP125C, 790, 250, 1010 Macs
27Ton Troybilt Splitter
NRA Life Endowment Member
Viet Nam Vet
Offline Red 93 L1 #3383
  • Park District Mechanic
Re: husky 365
« Reply #7 on: August 06, 2009, 06:35:04 PM »
A 36" bar on my 5 cube Stihl 064 is alot, I couldn't imagine trying it on a 4 cube 365 unless the saw is modded.
Stihl's: 2-064AV's, 020T, MS 310
'93 Ford F-150 Lightning, '94 F-150 4x4, '92 F-150 4x4 '80 F-150 EFI 7.5L, '04 Expedition (Wife's)
Offline SawTroll
Re: husky 365
« Reply #8 on: August 12, 2009, 04:40:58 PM »
A 36" bar on a 365 is way out of line, even with skip chain.   ::)
But anyway, do you remember to pull the bar tip up when tightening the chain and the bar nuts (put the saw upside down, and gravity will do it for you)?
Also, remember to tighten the front nut first, and tighten them really well!
Information collector.
Offline SawTroll
Re: husky 365
« Reply #9 on: August 12, 2009, 04:43:16 PM »
One last point - are you sure that the mount pattern of the bar is the "large Husky" ?
Husky Prestique 61 (1980) Vs Husky 562XP
Started by Mikeinkaty on Chainsaws
Last post June 13, 2016, 06:09:49 AM
by SawTroll
Husky 543 xp
Started by DonT on Chainsaws
Last post September 26, 2017, 11:01:24 PM
by sawguy21
Husky 365?
Started by Knute on Chainsaws
Last post August 04, 2012, 09:03:48 AM
by Spike60
Husky 359
Started by stumpy on Chainsaws
Last post April 04, 2006, 08:14:58 AM
by barbender
