Tally-I/O
Author Topic: Mouse Nest  (Read 3593 times)
Offline BAR
Mouse Nest
« on: August 18, 2009, 06:26:37 PM »
Hi,
I have a Woodmizer LT-27 with 18hp Kolher air cooled engine.  A couple of years ago when I got my mill out for the season there was a massive mouse nest under the air input guard.  No problem...I thought, but it turned out that the screen was was held in place by 4 bolts with the bolt heads inside and nuts outside.  As soon as the nuts were loosened, the bolts spun and I couldn't get the guard off.  Couldn't right away see how to to remove the nuts and then the guard!  Since I was in a hurry to start sawing, I made a tool from aluminum welding rod and worked for two hours to fish the debris out bit by bit.
Before I tackle this again, has anyone else had this problem and how did you handle it?
If I don't hear about a better way, I will cut out enough of the guard mesh to access the bolt heads, remove the guard, tack weld the bolts (or nuts) in place, and weld the mesh back together for future cleaning.   I wish someone from Kohler would explain the reasoning for this design, if there is a rational explanation.  Better yet, someone will point out something I  overlooked.  Make me feel stupid...please!
Thanks,
BAR
3340 Zetor with Allied Loader & Fransguard Winch, Woodmizer LT27T,
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Mouse Nest
« Reply #1 on: August 18, 2009, 06:40:14 PM »
I think you are on the right path about tack welding the nuts in place. That is one of those things that should have been done when it was built. Do you have a couple of pictures that you could post of this area?
Offline bandmiller2
Re: Mouse Nest
« Reply #2 on: August 19, 2009, 09:02:48 PM »
BAR,what you could do when you get the screen off is put the bolts in and put nuts on tight with lock tite then the screen with wing nuts.That would make it easier to remove the next time.Sometimes you can cut a screwdriver slot on the end of the bolt with a hacksaw to hold the bolt wile you chase the nut off.Frank C.
Mouse Attacks Cat!
Started by wesdor on General Board
Last post September 07, 2011, 12:53:41 PM
by thecfarm
Mouse troubles
Started by metalspinner on Technical Support Topics
Last post March 05, 2008, 07:15:05 PM
by Ernie
Mill Mouse
Started by warren46 on Sawmills and Milling
Last post October 18, 2016, 09:34:41 AM
by DeerMeadowFarm
Dirty Mouse
Started by Tom on Technical Support Topics
Last post August 28, 2009, 10:31:11 PM
by Tom
